Upgrade to Premium
Reply
  #1
Old 01-07-2018, 08:23 PM
Redsledhead Redsledhead is offline
Currently: Working on sleds awaiting snow
Basic Member
Redsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond repute
Default Coolant Heip
I purchased a used 2014 800 Summit. Went up for a test ride and noticed that there was no coolant in the reservoir. Came home and added about a quart of (expense) skidoo coolant. The reservoir is empty again don't know if it was already low or not. there is a different smell from the exhaust . Don't see anywhere in the trailer where anything is leaking could it be burning coolant? what is the best way to start finding the problem? I put the sled on the trailer ramp to add oil so any air could escape and planning on adding more coolant , Just don't want to waste a lot on dollars on factory OEM coolant Amy help would be great.
Rate this post: Yes | No
  #2
Old 01-08-2018, 07:27 AM
Blk88GT's Avatar
Blk88GT Blk88GT is online now
Currently: THE CHASE IS ON!!
Blk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond repute
Default
My 16 never shows coolant in the reservoir. I've added it twice now, but it finds it's own level after a couple heat cycles.
Doesn't seem to be an issue and my dealer isn't concerned. They even warned me on my 14 that it would behave that way when I bought it. If you're really concerned, you can check your plugs. If you're burning coolant, they'll be the first indication.
__________________
2019 Freeride 154x3 w/SHOT
The Following User Says Thank You to Blk88GT For This Useful Post:
Redsledhead (01-08-2018)
  #3
Old 01-08-2018, 02:48 PM
Basic Member
Default
Added coolant to the sled sitting on back trailer ramp found a little drip. moved the sled to level ground and found that it is dripping at the clutch side by the heat exchanger. Where to start looking for the leak?
  #4
Old 01-09-2018, 08:21 PM
FEZ FEZ is offline
Currently: Mechanic for and Advisor to SHR
Basic Member
FEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond repute
Default
Check the front heat exchanger. There could be a hole/crack in it from a rock rolling through.
  #5
Old 01-17-2018, 04:08 PM
Spiced Wafer Spiced Wafer is offline
Currently: Not set.
Basic Member
Spiced Wafer has a reputation beyond reputeSpiced Wafer has a reputation beyond reputeSpiced Wafer has a reputation beyond reputeSpiced Wafer has a reputation beyond reputeSpiced Wafer has a reputation beyond reputeSpiced Wafer has a reputation beyond reputeSpiced Wafer has a reputation beyond reputeSpiced Wafer has a reputation beyond reputeSpiced Wafer has a reputation beyond reputeSpiced Wafer has a reputation beyond reputeSpiced Wafer has a reputation beyond repute
Default
i have a 2015 t3, my coolant was under my sled after the first stick this past weekend. thought it was overflow from my oil...anyway kept riding, got stuck again and my engine overheat light came on when i started the sled...got it back down to the road and it went out, and my bars showing the temp dropped. got to the road and looked at the bottle, nothing in it. added 1 liter of water, and after 30 minutes the bottle was empty again. heat would rise and fall depending on if i was on throttle or not...
took it to the dealer...
dealer said my bottle was warped and my cap was warped as well...getting them replaced under warranty...
personally, they didn't look bad, but we will see if that was the real issue or not when i get it back.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — where is my coolant going? Thread Starter — Braapist Forum — Arctic Cat: Proclimb M Replies — 26 Last Post — 02-15-2016 09:32 PM
Thread — Where to get coolant? Thread Starter — RobertTrivanovic Forum — Arctic Cat: TURBO Replies — 4 Last Post — 11-06-2014 07:48 AM
Thread — Polaris Dragon-n-Assault Coolant Bottle + SLP Coolant Bypass Kit F/S Thread Starter — 150+ or nothin Forum — Misc. Sled Parts Replies — 0 Last Post — 09-21-2011 01:15 PM
Thread — Coolant Thread Starter — ceder Forum — Ski-Doo: XP Sleds Replies — 12 Last Post — 03-18-2011 09:53 PM
Thread — Oil in coolant..Bad oil seal or something with the coolant impellar?? Thread Starter — snowmanx Forum — Performance/Modified Replies — 3 Last Post — 02-24-2008 04:35 PM
no new posts
