Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 01-05-2018, 08:18 PM
Proteus88 Proteus88 is offline
Currently: Not set.
Basic Member
Proteus88 is an unknown quantity at this point
Question Noob Help: Backfire and Bog down when accelerating
Hi Everyone,
I bought my first snowmobile this week: 2006 Panther 370.
Within about 5 minutes of it driving fine (and after warming up for about 10-15 minutes) when I throttle to more than a slow speed it backfires once every couple minutes and loses acceleration (bogs?) for a split second.
I checked the spark plugs and noticed under the fuel pump there appears to be some fuel (leak?)
The previous owner disconnected and then reconnected the kill switch however the key does not stop the engine when turned to off (have to use kiss switch)
I wonder, could it be the leaky fuel pump line? Would there be enough fuel that it idles fine and drives slow great but when I accelerate it isnt getting enough?
This is my first snowmobile and I've never fixed one before so all suggestions appreciated, thanks!
Rate this post: Yes | No
  #2
Old 01-06-2018, 09:09 AM
Sledbrain2 Sledbrain2 is offline
Currently: Not set.
Basic Member
Sledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond repute
Default
could be staving fuel, if you are using all the fuel in the float bowl before the pump can fill it should act like its running out of gas. The back fire could also be an interment spark where gas vapors build up in combustion chamber when spark shuts off then fires. I would fix the leaky fuel line first, then move on to the wiring.
  #3
Old 02-04-2018, 03:50 PM
jackbombay jackbombay is offline
Currently: Not set.
Basic Member
jackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond repute
Default
Is the fuel pump is an aluminum disc about 2 inches in diameter and 1/2" thick? You can get rebuild kits for them, easy to instal, new diaphragms and o-rings.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2003 600 rmk bog/backfire-PLEASE HELP! Thread Starter — sledheader Forum — Polaris: EDGE Replies — 7 Last Post — 11-30-2015 08:43 AM
Thread — backfire bog no reverse 05 900 Thread Starter — rmkpaintking Forum — Polaris: 900 Replies — 8 Last Post — 02-27-2015 12:35 PM
Thread — Popping when accelerating hard Thread Starter — craighardy Forum — Arctic Cat: 1100 ProClimb Replies — 5 Last Post — 11-12-2012 09:26 PM
Thread — 900 bog/backfire/idle Thread Starter — yort600 Forum — Polaris: 900 Replies — 10 Last Post — 03-05-2012 12:50 PM
Thread — 2008 M8, off idle bog and backfire Thread Starter — M8fever Forum — Arctic Cat: M Series Replies — 5 Last Post — 01-29-2010 03:07 PM
