Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 01-05-2018, 04:16 PM
volcano buster volcano buster is offline
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default In need of fuel pump
2010 600 cfi-4
I'm experiencing some loss of fuel at WOT after a length of pull, either down a long road or on a steep hill. I put the gauge on the schrader valve and show 53#. Specs are 58-60# I believe. I have pulled the pump/pickup and checked that everything looked visually fine.
Any reason to drop over $500 for the Polaris unit with the intake or would a pump only replacement work fine?
I am finding two options:
Genuine Walbro pump - https://www.highflowfuel.com/i-23899...ategory:335702
Quantum pump - https://www.highflowfuel.com/i-23899...2008-2010.html
Obviously some price difference, but a heck of a lot cheaper than OEM with all the giblets.
Thoughts?
Rate this post: Yes | No
  #2
Old 01-05-2018, 04:21 PM
XCaSSAULT XCaSSAULT is offline
Currently: Go Wild!
Basic Member
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
Default
I assume you’ve replaced the filter? Maybe replace the sock in tank as well even if it looks fine.
  #3
Old 01-05-2018, 04:27 PM
Currently: Not set.
Default
I have been changing the fuel filters out about every 600 miles.
No "sock" in the tank. It has two pickup points that act as back-flow valves. When I pulled the unit out of the tank, they were holding fuel.
  #4
Old 01-05-2018, 05:01 PM
Currently: Go Wild!
Basic Member
Default
No sock in tank?! Wow I’d imagine you’d have to have some filtering before the pump. Maybe it fell off and is in the tank? What’s he diff between those two pumps in your links? Im cheap so there’s no way I’d give polaris $500, I’d go with one of those two options
  #5
Old 01-05-2018, 05:47 PM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
Default
Sorry VB, I've got no experience either with this particular application but I'd be willing to try the jobber pump cause damned if I'm going to give Polaris $500 for the assy.
Not sure what problem you're having but I wonder if 53 PSI is actually low enough to cause an issue. I know you mentioned the specs. were 58 - 60 PSI but sometimes you can get away with lot less than factory specs. before you notice a runnability issue.
Just a thought.....
  #6
Old 01-05-2018, 07:40 PM
Currently: Not set.
Default
I fibbed a little. This is a Carl's 660.
It happens when I have been WOT for a period of time and acts like it is dropping a couple injectors (or something) and I have to back out of the throttle and give it a chance to catch up again. Going up the road isn't a big deal but climbing isn't always done at the most opportune time. I'm thinking 52-53# is a possibility as to why it starts to fall down at WOT.
  #7
Old 01-05-2018, 07:44 PM
Currently: Go Wild!
Basic Member
Default
New plugs gapped right? Fresh gas? Clean ves?
  #8
Old 01-05-2018, 07:45 PM
Merlin's Avatar
Default
That makes sense.
Big bore & accompanying tune might not be as tolerant to lower fuel pressure.
  #9
Old 01-05-2018, 07:54 PM
Currently: Not set.
Default
Quote:
Yep, yep and yep
  #10
Old 01-05-2018, 10:01 PM
TRS's Avatar
TRS TRS is online now
Currently: Waiting for winter
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
  #11
Old 01-05-2018, 10:31 PM
SRXSRULE SRXSRULE is online now
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to SRXSRULE For This Useful Post:
mountainhorse (01-06-2018)
  #12
Old 01-05-2018, 10:49 PM
Currently: Not set.
  #13
Old 01-06-2018, 12:58 AM
LoudHandle LoudHandle is online now
Currently: I'd rather snowshoe than be caught on a SKIDOO! I'm not feminine / gay enough to ride SkiDoo either.
LoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond repute
The Following User Says Thank You to LoudHandle For This Useful Post:
  #14
Old 01-06-2018, 01:17 AM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
  #15
Old 01-06-2018, 01:53 PM
diamonddave's Avatar
diamonddave diamonddave is offline
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
  #16
Old 01-06-2018, 02:48 PM
Currently: Not set.
  #17
Old 01-07-2018, 12:16 PM
  #18
Old 01-07-2018, 03:09 PM
73 Starfire 73 Starfire is offline
Currently: Not set.
Basic Member
73 Starfire has a reputation beyond repute73 Starfire has a reputation beyond repute73 Starfire has a reputation beyond repute73 Starfire has a reputation beyond repute73 Starfire has a reputation beyond repute73 Starfire has a reputation beyond repute73 Starfire has a reputation beyond repute73 Starfire has a reputation beyond repute73 Starfire has a reputation beyond repute73 Starfire has a reputation beyond repute73 Starfire has a reputation beyond repute
  #19
Old 01-07-2018, 03:12 PM
Currently: Not set.
  #20
Old 01-13-2018, 03:35 PM
Currently: Not set.
  #21
Old 01-13-2018, 03:57 PM
Currently: Go Wild!
Basic Member
  #22
Old 01-14-2018, 10:40 AM
  #23
Old 01-14-2018, 10:44 AM
  #24
Old 01-15-2018, 08:29 AM
Currently: Not set.
  #25
Old 01-15-2018, 08:00 PM
Merlin's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Where can I get a fuel pump and could a weak fuel pump be affecting performance alot Thread Starter — cumminshp Forum — Arctic Cat: M Series Replies — 15 Last Post — 11-29-2012 03:01 PM
Thread — Fuel pump and oil pump wiring? Thread Starter — BigAir Forum — Arctic Cat: TURBO Replies — 5 Last Post — 02-27-2012 11:02 PM
Thread — 2007 Skidoo fuel tank w/fuel pump 600 SDI Thread Starter — aktrucker Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 1 Last Post — 12-11-2011 01:15 PM
Thread — Fuel tank + Fuel Pump + Fuel Filter for 2006 900 RMK Thread Starter — Dogmeat Forum — Chassis/Tunnel (Swapmeet) Replies — 0 Last Post — 12-06-2010 07:48 PM
Thread — WTB AC: Fuel Pump, Oil Pump, Lower A-Arm Thread Starter — cokingcat Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 12-16-2008 12:38 AM
no new posts
