Upgrade to Premium
Reply
  #1
Old 01-04-2018, 09:19 PM
cubby's Avatar
cubby cubby is online now
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default sled has a hicup
16 sp800 t3 with 100 miles on it last season then stored for summer with half tank of fuel and on a battery tender. I fire it up pull it in the shop and install BTLD quick clickers. Take it the next day and ride it and it has one hell of a miss to it. Like holding the throttle steady it jerks like a miss, then I WOT and it either comes out of it or falls on it's face till you stab the throttle again then it comes out of it and runs great at WOT. Any ideas? I just sucked all the fuel out of it at lunch and will put fresh 91 in it to see if that helps but anything else I should check?
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
Rate this post: Yes | No
  #2
Old 01-04-2018, 09:21 PM
BeachSled's Avatar
BeachSled BeachSled is offline
Currently: Not set.
BeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond repute
Default
Plugs
  #3
Old 01-05-2018, 07:25 AM
sledr4life's Avatar
sledr4life sledr4life is offline
Currently: Not set.
sledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond repute
Default
fuel filter?
  #4
Old 01-06-2018, 12:51 PM
Brando18299 Brando18299 is online now
Currently: Not set.
Brando18299 is an unknown quantity at this point
Default
Plugs and filter as mentioned above. And if you must store it with fuel in it at least stabilize it and run a little before putting away for summer if you didn't the last time.
The Following User Says Thank You to Brando18299 For This Useful Post:
butthead (03-11-2018)
  #5
Old 03-11-2018, 09:50 AM
butthead butthead is offline
Currently: Not set.
Basic Member
butthead has a reputation beyond reputebutthead has a reputation beyond reputebutthead has a reputation beyond reputebutthead has a reputation beyond reputebutthead has a reputation beyond reputebutthead has a reputation beyond reputebutthead has a reputation beyond reputebutthead has a reputation beyond reputebutthead has a reputation beyond reputebutthead has a reputation beyond reputebutthead has a reputation beyond repute
Default
try checking your rave valve
take off black rave cover
2 8m socket screws on
my sled were about 2 turns
each loose
bog gone
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to butthead For This Useful Post:
cubby (03-12-2018), Teth-Air (04-09-2018)
  #6
Old 03-14-2018, 08:02 PM
Currently: Not set.
Basic Member
Default
let us know if that fixed it for you
  #7
Old 03-30-2018, 07:19 PM
FEZ FEZ is offline
Currently: Mechanic for and Advisor to SHR
Basic Member
FEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond repute
Default
Also check the fuel pressure regulator in the tank. It can come out and cause a drop in fuel pressure.
  #8
Old 04-06-2018, 09:19 PM
Covelli44 Covelli44 is offline
Currently: Bummer season for me
Covelli44 has a reputation beyond reputeCovelli44 has a reputation beyond reputeCovelli44 has a reputation beyond reputeCovelli44 has a reputation beyond reputeCovelli44 has a reputation beyond reputeCovelli44 has a reputation beyond reputeCovelli44 has a reputation beyond reputeCovelli44 has a reputation beyond reputeCovelli44 has a reputation beyond reputeCovelli44 has a reputation beyond reputeCovelli44 has a reputation beyond repute
Default
Does this sled only have 100 miles on it?
  #9
Old 04-09-2018, 06:54 AM
cubby's Avatar
Default
The sled now has 500 miles on it. It has been fixed by the dealer under warranty.
__________________
2016 T3 154"
2013 Polaris 850xp
2015 Polaris 1000xp
  #10
Old 04-09-2018, 09:01 AM
Teth-Air's Avatar
Teth-Air Teth-Air is online now
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
Quote:
Can you please tell us what they found because my 12 is doing the same.
Thanks
__________________
Home of the "Cordless Teth-Air" and NEW "Laser Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
  #11
Old 04-10-2018, 09:35 AM
cubby's Avatar
Click Here to Register
The Following User Says Thank You to cubby For This Useful Post:
Teth-Air (04-10-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — SLED DECKS, SUPER CLAMPS, SUPER GLIDES, SLED RAMPS , SURE GRIP SLED DOLLIES F/S Thread Starter — JETJOHNSO Forum — Trailer/Transport (Swapmeet) Replies — 5 Last Post — 02-20-2014 02:55 PM
Thread — F/S SLED DECKS, SUPER CLAMPS, SLED RAMPS TRUCK STYLE Thread Starter — JETJOHNSO Forum — Trailer/Transport (Swapmeet) Replies — 2 Last Post — 01-28-2012 12:33 AM
Thread — 08 Ski Doo Summit nice good sled WITH SLED DECK Thread Starter — toyhunter Forum — Ski-Doo (Swapmeet) Replies — 5 Last Post — 08-15-2011 06:51 PM
Thread — what sled is a good sled for young girls to learn to cut a edge and side hill Thread Starter — d&mraceengines Forum — Arctic Cat: M Series Replies — 23 Last Post — 01-07-2011 02:06 PM
Thread — 2001 Summit 800 mtn. sled VE tunnel *nice sled* Thread Starter — dub Forum — Ski-Doo (Swapmeet) Replies — 7 Last Post — 04-05-2010 07:26 AM
no new posts
