Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 01-04-2018, 04:39 PM
snoblind04's Avatar
snoblind04 snoblind04 is offline
Currently: having a blast on my mpi turbo
snoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond reputesnoblind04 has a reputation beyond repute
Default Anyone want to share clutch setup?
Anyone want to share their clutch set up? I installed an MPI turbo on my 18 175. I just added weight to the primary and it runs good. However I smell the belt alot, so I'm looking for a little better setup. Thinking of trying the 168 ramps.
Rate this post: Yes | No
  #2
Old 01-04-2018, 05:42 PM
Chadly's Avatar
Chadly Chadly is online now
Currently: Not set.
Chadly has disabled reputation
Default
Reset your max RPM on your dash and see what you are coming up with. You should be keeping it under 8000 when you are pulling hills with it loaded up. Anything over 7900 is too much RPM.
  #3
Old 01-04-2018, 06:20 PM
ghost rider ghost rider is offline
Currently: videos
ghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond reputeghost rider has a reputation beyond repute
Default Mpi
I also run MPI turbo. Run Big Johns set up with his new ramps it's worth the $. Less belt heat, better shift out, better track speed etc. 8000 rpm give or take 100rpm works fine. Best sled and turbo combo I've ran yet
  #4
Old 01-04-2018, 08:37 PM
snoblind04's Avatar
Default
Well I think using the using the max rpm is kind of useless unless your way over. Unloading the track will cause it to go over. My rpm's are really good.
I will consider a clutch kit, just wanted to try something with parts on hand and easy to get.
  #5
Old 01-04-2018, 08:58 PM
bubblyjock bubblyjock is offline
Currently: Just waiting for the weekend!!
bubblyjock has a reputation beyond reputebubblyjock has a reputation beyond reputebubblyjock has a reputation beyond reputebubblyjock has a reputation beyond reputebubblyjock has a reputation beyond reputebubblyjock has a reputation beyond reputebubblyjock has a reputation beyond reputebubblyjock has a reputation beyond reputebubblyjock has a reputation beyond reputebubblyjock has a reputation beyond reputebubblyjock has a reputation beyond repute
Default
Quote:
What elevation and pounds of boost are you at?
__________________
2018 Summit 850- 165" w/Silber Turbo
  #6
Old 01-04-2018, 09:53 PM
snoblind04's Avatar
Default
I run 8000 to around 10500, boost? 6.5? the kit is supposed to change boost based on conditions.
Don't get me wrong this works good and I'm pulling good and consistant rpms, between 7900 and 8000. But I can smell the belt when working it.
  #7
Old 01-04-2018, 09:57 PM
Currently: videos
Default Mpi
Quote:
I ride between 7-10,000ft. I have 5 lb spring
Big Johns ramps loaded with #4 weight on bolt,clicker 2. 2017 gearing
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Share your 900 RMK Clutching and gearing setup Thread Starter — uSoTiNy Forum — Polaris Replies — 3 Last Post — 03-14-2017 02:02 PM
Thread — Clutch setup, 141x2.25? Stock clutch weight? Thread Starter — Al_Scrap Forum — Arctic Cat: Proclimb M Replies — 2 Last Post — 02-22-2012 10:54 AM
Thread — 09 Clutch issues? New to XP clutch setup!! Thread Starter — Summit8 Forum — Ski-Doo: XP Sleds Replies — 19 Last Post — 03-15-2011 05:35 PM
Thread — Anyone want to share there clutch set ups on their M1200 Thread Starter — 1100Cat Forum — Arctic Cat Replies — 2 Last Post — 04-02-2009 09:44 PM
Thread — M7 Clutch Setup Thread Starter — Cat Man II Forum — Arctic Cat Replies — 3 Last Post — 10-11-2008 04:02 PM
no new posts
