Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 01-03-2018, 09:58 PM
polarlis1998 polarlis1998 is offline
Currently: Not set.
Basic Member
polarlis1998 is an unknown quantity at this point
Default 1998 polaris indy trail tourning 488 f/c mods
I bought a 1998 polaris trail touring for 400 bucks. I’m just getting into mods and would like some tips on how to make this sled more off trail capable and lighter. One thing i would like to do is take the big bulky 2 up seat off and replace it with a smaller seat. I don’t want to spend too much money. Anything helps thank you in advance.
Rate this post: Yes | No
  #2
Old 01-04-2018, 09:50 AM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
Default
Not sure what your budget is but here are some suggestions:
Check Aaen's website to see if they offer a pipe for your model. They usually tout a HP increase along with weight loss.
Shaving and / or cutting the cylinder head is an option for more power as well but is dependent on elevation. You will need to find a competent shop that specializes in snowmobile performance for this.
The best bang for your buck will be to make sure the machine is maintained and tuned properly. I.E.
Clutches(cleaned, in servicable condition, belt deflection set, & tuned for proper engagement / max. RPM)
Carbs/fuel system(cleaned, new hoses, sync'd, & jetted properly)
Timing(set to spec. or more depending on tuning / plug reading)
Chassis(Ski alignment, track tension, suspension pivot points / lubrication, etc.)
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Merlin For This Useful Post:
polarlis1998 (01-04-2018)
  #3
Old 01-05-2018, 12:29 AM
BeartoothBaron BeartoothBaron is offline
Currently: Not set.
BeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond repute
Default
I started off with an old fan sled and similar questions. I ended up with a 600 RMK as my primary sled, but I've got another Indy Trail I'm working on building into an ultralight mod sled. Merlin covered a lot of ground, but I'll throw in my two cents.
First, I'd recommend saving your money on horsepower upgrades for now. You can make more power out of a fan sled, but only the 3-5 HP you can get from careful tuning is remotely cost-effective compared to upgrading to a liquid-cooled sled. There is more power to be made from exhaust, porting, bigger carbs, and so on, but that takes a lot of time, effort, and know-how. Beyond that, most people don't bother is because you've got heat issues when you try to push more power with a fan. It's a dead horse that gets beaten every time someone posts about a fan sled, but I bring it up for the sake of expectations.
You hit on easily the biggest thing you can do, which is lose unnecessary weight. Ditch any mirrors, luggage rack, and such add-ons. If you're willing to do some adapting and fabricating, you could fit a lightweight seat from any number of sleds (doesn't have to be Polaris); you might find something cheap perusing Craigslist. The other thing to look for is a set of plastic skis; those shed significant weight and typically perform better. They're not universal though, so make sure you know how you're going to fit them before you buy. Pretty sure you've got a longer track on that, so with some weight-shedding you should be able to manage off-trail if it's not too deep.
The Following User Says Thank You to BeartoothBaron For This Useful Post:
polarlis1998 (01-06-2018)
Reply
Bookmarks
Tags
1998, 488, indy, polaris, trail touring
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Sledheads check out my video, Polaris Indy Trail Fuji 488 1997 finished engine rebuil Thread Starter — DTA Forum — Polaris: GEN 1 and older Replies — 0 Last Post — 12-12-2012 11:34 PM
Thread — 92 Indy Trail 488 $850obo Thread Starter — caterpillarman Forum — Polaris (Swapmeet) Replies — 1 Last Post — 10-06-2009 05:52 AM
Thread — 1995 Polaris Indy Trail Deluxe 488 F/C owner's manual?? Thread Starter — Muhji Forum — Polaris Replies — 0 Last Post — 04-04-2009 06:43 PM
Thread — 1997 polaris indy trail 488 $800 Thread Starter — jiles03 Forum — Polaris (Swapmeet) Replies — 3 Last Post — 02-23-2008 12:06 AM
Thread — 1997 polaris indy trail 488 $1000 Thread Starter — jiles03 Forum — Polaris (Swapmeet) Replies — 1 Last Post — 02-05-2008 11:26 PM
