Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 01-01-2018, 07:51 PM
880summitxrs 880summitxrs is offline
Currently: Wishing I lived 1000mi west of here
880summitxrs has a reputation beyond repute880summitxrs has a reputation beyond repute880summitxrs has a reputation beyond repute880summitxrs has a reputation beyond repute880summitxrs has a reputation beyond repute880summitxrs has a reputation beyond repute880summitxrs has a reputation beyond repute880summitxrs has a reputation beyond repute880summitxrs has a reputation beyond repute880summitxrs has a reputation beyond repute880summitxrs has a reputation beyond repute
Default Rear skid setup on 7lbs
Running Silbers at 7lbs, 165 3in, I weigh 225 ready to ride.
Rate this post: Yes | No
  #2
Old 01-02-2018, 08:38 AM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
Default
Guessing stock suspension?
Its pretty overwhelmed with the Silber setup at 7 psi. At minimum crank the torsion bar all the way down (5 setting), suck the limiter up one hole and see where that puts you.
I am running aftermarket Fox stuff. Valved fairly stiff. Its better but even at 5psi I can't even see over the nose of the sled 1/2 the time.
Will be going to a Tom's kit for just this reason.
I'd also consider some stiffer torsion bars if I didn't have the means for the Tom's kit...
  #3
Old 01-02-2018, 09:49 AM
Default
Yes all stock, tried sucking up the limiter and torsion spring at 3. Also front shock spring is right in the middle. This did help with keeping front down bUT now trenches pretty bad even from being stopped on level ground. I don't get.
  #4
Old 01-02-2018, 09:57 AM
Default
Can a guy suck up the limiter to far and make it handle this way?
  #5
Old 01-02-2018, 11:02 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Short of a aftermarket skid, maybe experiment with HD springs or the Zbros coupling blocks.
Limiter sucked up will help some with keeping the nose down, but makes the handling a little tougher when not going uphill.
  #6
Old 01-02-2018, 11:09 AM
Default
That is exactly what I found but think I went way to far with limiter strap. Gonna try and let it back out and tighten rear torsion spring all the way and take some pressure off of front spring also. Just trying to keep the front down and not trench lol.
  #7
Old 01-02-2018, 01:43 PM
turboless terry's Avatar
turboless terry turboless terry is online now
Currently: Not set.
turboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond repute
Default
I hate sucking the limiter up. Losing what holds you on the hill. Rasmussen has the same philosophy as I do. His stuff is a little pricey but at the least, go to his site and read his ideas on suspension.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to turboless terry For This Useful Post:
mountainhorse (01-02-2018)
  #8
Old 01-02-2018, 05:42 PM
mountainhorse's Avatar
mountainhorse mountainhorse is online now
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Default
Contrary to the beliefs of many...Valving has very little to do with ski lift on a climb...It DOES change the rate at which they lift... but not the end result...
Spring force on the rear track has more to do with this... as does lowering front skid travel with sucking up the limiter strap... but then you are also modding the character of the skid and going to have a harsher, less compliant ride in the technical stuff where you may need compliance to keep you from loosing your sled... It's a balancing game.
The SPG ARC system can help with this and not give you the harsh ride.
Or... a complete K Mod suspension....
my 2¢
__________________
Signature:
  #9
Old 01-02-2018, 06:23 PM
Default
Let limiter out 1 hole from stock, torsion spring on 5 and just enough pressure on the front spring to keep it from rattling it helped a great deal. I am coming to conclusion that I'm gonna need some aftermarket rear skid updates especially if I continue to run 7lbs of boost. P.S. I'm addicted to this boost gig!
The Following User Says Thank You to 880summitxrs For This Useful Post:
Vkeven (09-12-2018)
  #10
Old 01-02-2018, 07:07 PM
Bendy Bendy is offline
Currently: Dooin the Snowdance
Bendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond repute
  #11
Old 01-02-2018, 07:09 PM
Click Here to Register
  #12
Old 01-02-2018, 09:25 PM
oldym8rider oldym8rider is offline
Currently: Not set.
Basic Member
oldym8rider has a reputation beyond reputeoldym8rider has a reputation beyond reputeoldym8rider has a reputation beyond reputeoldym8rider has a reputation beyond reputeoldym8rider has a reputation beyond reputeoldym8rider has a reputation beyond reputeoldym8rider has a reputation beyond reputeoldym8rider has a reputation beyond reputeoldym8rider has a reputation beyond reputeoldym8rider has a reputation beyond reputeoldym8rider has a reputation beyond repute
  #13
Old 01-03-2018, 09:36 AM
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — My proposed rear skid setup ?!? Thread Starter — Insaneboltrounder/sjohns Forum — Arctic Cat: Proclimb M Replies — 14 Last Post — 03-29-2014 01:06 PM
Thread — Rear skid setup Thread Starter — hybelkaninen Forum — Polaris: 900 Replies — 10 Last Post — 01-01-2014 11:42 PM
Thread — Timbersled Rear Skid Setup Thread Starter — iowarmk Forum — Suspension/Shocks (Swapmeet) Replies — 5 Last Post — 03-30-2012 04:52 PM
Thread — m8 rear skid setup help? Thread Starter — strong Forum — Arctic Cat: M Series Replies — 2 Last Post — 10-10-2011 08:22 AM
Thread — 2010 rear skid setup?? Thread Starter — Iceman56 Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 18 Last Post — 10-06-2010 01:28 PM
no new posts
