Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 12-31-2017, 04:35 PM
desertdirt desertdirt is offline
Currently: Workin hard all week so i can rip on the weekend
desertdirt has a reputation beyond reputedesertdirt has a reputation beyond reputedesertdirt has a reputation beyond reputedesertdirt has a reputation beyond reputedesertdirt has a reputation beyond reputedesertdirt has a reputation beyond reputedesertdirt has a reputation beyond reputedesertdirt has a reputation beyond reputedesertdirt has a reputation beyond reputedesertdirt has a reputation beyond reputedesertdirt has a reputation beyond repute
Default Found solution to no reverse and dying after a few minutes
Just thought I would share what I found on my 08 dragon 700. The first thing that happened to it was the typical voltage regulator failure. But after that it would start right up and run a little sluggish at the shop. No reverse, it would just die when you hit reverse. Then when I would get it to the trailhead to test it, it would run fine for a few minutes and it would bog bad and eventually wouldn’t even run if you hit the throttle. Then it would just start and die. Bring it home it would fire right up. I changed reeds, boots, swapped Ecu, coils, capacitor, and voltage regulator with a good sled and same story. I then checked the timing. It was at like 12 degrees, book calls for 18 and it’s not adjustable without a offset key so I tore it down to see if my keyway was bad. When I tore it down, I found the 5 trigger crank sensor wires were both ripped apart by the flywheel. I fixed them up and now all is well. My guess is that when that 5 point sensor goes bad it runs on the two point and that has less timing when it’s on that sensor. I never had a check engine light. So i guess the best test is to check timing. If it retarded then your probably running on the 2 point crank sensor. Hope this helps someone else
Rate this post: Yes | No
The Following 5 Users Say Thank You to desertdirt For This Useful Post:
Drewd (12-31-2017), retiredpop (01-31-2018), tryanattak (01-03-2018), volcano buster (01-01-2018), XCaSSAULT (12-31-2017)
  #2
Old 01-31-2018, 04:09 PM
NapaMatt's Avatar
NapaMatt NapaMatt is offline
Currently: Stocking shelves, Need Parts??
NapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond repute
Garage
Default
Some thing your sled maybe doing!
Volcano Buster@@@@@@
__________________
FOR SALE... SLP Pipe Set For Pro RMK 800... PM. Me for Details BRAND NEW 2013 ASSAULT PIGGY BACK FRONT SHOCKS FOR SALE!! $$650!!! Gas Tank From a 07 Switchback/ Seat Red and Black No tears. Plus fuel lines.
http://www.napaonline.com/
Theye Supply 1-507-533-6610
Auto Parts, Snowmobile, ATV, Truck and Trailer.. and
Shop Local!!
  #3
Old 01-31-2018, 04:10 PM
NapaMatt's Avatar
Garage
Default
Ill Add to that!!
Make sure the INNErR Fly wheel ring is TIGHT!!!
They are glued in to the fly wheel..
This comes loose works its way to the inside.. starts to rubs and cut wires!!! Happened to me!
__________________
Shop Local!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2010 M8- Dying, and going into reverse Thread Starter — MSundstrom Forum — Arctic Cat: M Series Replies — 7 Last Post — 01-11-2015 05:14 PM
Thread — i just found a solution to all of our illegal immigration problems Thread Starter — ragincajun Forum — Fouled Plug Replies — 4 Last Post — 09-10-2009 09:20 AM
Thread — If you have 10 minutes... Thread Starter — sixpointbull Forum — Fouled Plug Replies — 1 Last Post — 01-07-2009 09:41 PM
Thread — 5 minutes on 09 m8 Thread Starter — wasatchrider Forum — Arctic Cat Replies — 0 Last Post — 12-20-2008 12:17 AM
Thread — Golden, vandalism solution found Thread Starter — Spector Forum — Canada West (BC/AB) Replies — 12 Last Post — 12-17-2007 12:12 AM
no new posts
