Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 12-25-2017, 02:07 PM
WY_Covert's Avatar
WY_Covert WY_Covert is offline
Currently: Where are the flakes?
WY_Covert has a reputation beyond reputeWY_Covert has a reputation beyond reputeWY_Covert has a reputation beyond reputeWY_Covert has a reputation beyond reputeWY_Covert has a reputation beyond reputeWY_Covert has a reputation beyond reputeWY_Covert has a reputation beyond reputeWY_Covert has a reputation beyond reputeWY_Covert has a reputation beyond reputeWY_Covert has a reputation beyond reputeWY_Covert has a reputation beyond repute
Default 2002 600
Is there a way to change the crank seals w/o splitting the case? The only reason I as ask is my pump will not move fluid cold like I have an air leak on my secondary compression. If I pour a touch of premix in it fires up first pull. Thanks.
Sent from my SAMSUNG-SM-G930A using Tapatalk
__________________
Cheers,
Shawn
Rate this post: Yes | No
  #2
Old 12-26-2017, 08:16 AM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default
No you have to split the cases in order to replace the seals as there is one in between the cylinders. Are you sure that its a vacuum problem? Have you took your fuel pump apart and checked it out? Very easy to do and I believe a rebuild kit for them are only $20.
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
  #3
Old 12-26-2017, 09:24 PM
WY_Covert's Avatar
Default
Quote:
I have taken the pump off and pulsed it. It pumps fuel easy. So it is secondary compression issue for sure. As long as i pour a shot in it it fire right off. Damn thing has 5500 miles on it.
__________________
Cheers,
Shawn
  #4
Old 12-26-2017, 10:39 PM
Seedie_Man Seedie_Man is online now
Currently: Not set.
Seedie_Man has a reputation beyond reputeSeedie_Man has a reputation beyond reputeSeedie_Man has a reputation beyond reputeSeedie_Man has a reputation beyond reputeSeedie_Man has a reputation beyond reputeSeedie_Man has a reputation beyond reputeSeedie_Man has a reputation beyond reputeSeedie_Man has a reputation beyond reputeSeedie_Man has a reputation beyond reputeSeedie_Man has a reputation beyond reputeSeedie_Man has a reputation beyond repute
Default
Did you check the reeds?
No vacuum if they are leaking
__________________
I have an inferiority complex, but it isn't a very good one.
  #5
Old 12-27-2017, 10:24 AM
WY_Covert's Avatar
Default
First thing I pulled was the boots and reeds. The reeds look good.
__________________
Cheers,
Shawn
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 2005 800 RMK, 2002 600 RMK, 1999 600 RMK & 2000 Spirit Trailer Thread Starter — 800 Escape Forum — Polaris (Swapmeet) Replies — 0 Last Post — 12-06-2011 08:52 PM
Thread — 2002 Polaris XC-SP 600 Thread Starter — Olie3170 Forum — Polaris (Swapmeet) Replies — 2 Last Post — 01-23-2010 11:44 AM
Thread — 2002 zr 600 xcountry Thread Starter — mudracer Forum — Arctic Cat: Powder Special and older Replies — 2 Last Post — 12-09-2009 01:56 PM
Thread — 2002 a/c 600 Thread Starter — mxzmod Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 10-14-2009 07:55 AM
Thread — is 2002 600 XC SP 600 Perc reverse same as an 2003 Thread Starter — Bmanmn71 Forum — Performance/Modified Replies — 2 Last Post — 02-06-2008 07:05 PM
no new posts
