Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 12-21-2017, 03:34 PM
peaceofwork peaceofwork is offline
Currently: Internet Rmkpro 800apprentiship
Basic Member
peaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond repute
Default Smoking vent tube down from power valve celonoid
I have an 09 dragon and the vent tube from the power valves goes to a celonoid then a open ended hose going to the belly pan . This hose blows a steady thick stream of smoke when the sled is running, any one know anything about this in an 09 dragon 800 ?
Rate this post: Yes | No
  #2
Old 12-22-2017, 06:29 PM
tryanattak tryanattak is offline
Currently: Waiting for snow
Basic Member
tryanattak is a splendid one to beholdtryanattak is a splendid one to beholdtryanattak is a splendid one to beholdtryanattak is a splendid one to beholdtryanattak is a splendid one to beholdtryanattak is a splendid one to beholdtryanattak is a splendid one to beholdtryanattak is a splendid one to beholdtryanattak is a splendid one to beholdtryanattak is a splendid one to beholdtryanattak is a splendid one to behold
Default
From what I understand that is a good thing. If it was not blowing exhaust out of it then your power valve purge hole would most likely be plugged and you would have the bogging issue so common in these sleds. There is an older thread that tells you to drill a 1/2" size hole in the shock tower and to run the hose coming from the solenoid through that hole so that you can see that it has a steady stream of exhaust coming out. I believe that thread is " power valve control solenoid ". I have been doing a ton of research lately on it because I happen to have that bog issue. So I would say you are good to go. Maybe some one more knowledgeable will chime in.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to tryanattak For This Useful Post:
peaceofwork (12-23-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — BDX power valve delete vs STM power valve system Thread Starter — jmeier1981 Forum — Arctic Cat: M Series Replies — 9 Last Post — 01-13-2014 06:39 PM
Thread — Power valve cable guide tube loose Thread Starter — titaniumbadger Forum — Arctic Cat: M Series Replies — 4 Last Post — 02-05-2013 08:11 AM
Thread — power valve vent hose Thread Starter — wi.switchback Forum — Polaris: Pro-Ride Replies — 11 Last Post — 03-15-2012 12:12 PM
Thread — vent tube valve Thread Starter — iddooer Forum — Yamaha: 4-Stroke Replies — 1 Last Post — 03-17-2010 03:14 PM
no new posts
