Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 12-18-2017, 04:48 PM
EastCoastSledder EastCoastSledder is offline
Currently: Not set.
EastCoastSledder is an unknown quantity at this point
Default Broken Crank. What should I do?
I have a 2013 SBA with 4800 miles and was removing the primary with a clutch puller when the PTO end of the crank snapped with very little force on the puller.
A buddy of mine was looking at it and thought the crank must have already been snapped from torque force due to the rings on the break.
I have never broken a belt on the sled and when I rebuilt the top end last season the crank bearings seemed to be in good condition. I also have a slp torque arm installed.
I am hoping to do a relatively cheap and quick fix so I don’t lose to much of the season. I saw that there are used cranks on eBay would they be worth getting or should I just bite the bullet and get new crank? Also is there any other problems I should look out for that would have caused the crank to break so it doesn’t happen again?
Any info from the experts on here would be much appreciated!
Rate this post: Yes | No
  #2
Old 12-27-2017, 07:22 PM
XCaSSAULT's Avatar
XCaSSAULT XCaSSAULT is online now
Currently: Go MN Wild!
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
Default
How did u remove the primary? Did u use a impact? Maybe it wasn’t torqued properly before and spung around in there a lot creating heat? Either way it’s not something u wanna mess with again. I’d consider the eBay route but I’d bring it to a good machine shop and have them spec it out. Good luck
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Broken crank on '11 M8 Thread Starter — Mafesto Forum — Arctic Cat: M Series Replies — 11 Last Post — 12-29-2013 10:52 AM
Thread — Broken crank? Thread Starter — STANG302 Forum — Arctic Cat: Powder Special and older Replies — 2 Last Post — 12-27-2010 01:27 PM
Thread — 08 D8 broken crank Thread Starter — t stone Forum — Polaris: IQ Replies — 27 Last Post — 02-12-2010 10:00 PM
Thread — Broken Crank Causes??? Thread Starter — Klimbing Kitty Forum — Arctic Cat Replies — 4 Last Post — 11-23-2008 07:40 PM
Thread — Broken crank Thread Starter — golfsnownut Forum — Polaris Replies — 4 Last Post — 03-17-2008 06:30 PM
no new posts
