Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 12-18-2017, 11:49 AM
luggnut luggnut is offline
Currently: 2016 M8000 162 Helium Sidekick turbo
Basic Member
luggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond reputeluggnut has a reputation beyond repute
Default 2016 M8000 Turbo team clutching?
I have a 2016 M8000 with the factory team clutches. Working on installing a silber turbo and planning on running 5psi at 9,000 ft and above. I already have the venom adjustable weights and would like to keep them if possible to keep cost down. What else is needed or recomended for clutching? Justin at silber said to add weight to the tips and set at 76g, stock primary spring, stock 48 straight helix, and a 180/300 secondary spring. Problem is I cant find that secondary spring anywhere, closest I can get is 180/260 from speedwerx. From what I can tell it looks like the bd sidekick just uses different weights, primary spring (which one?) and stock secondary. How is this setup working?
I would like to hear what anyone else is running and what has worked with a low boost turbo/supercharger with team clutches. Don't have alot of time on the mountain and dont want to waste it guessing on clutching!
Rate this post: Yes | No
Reply
Bookmarks
Tags
2016, clutching, m8000, team, turbo
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2016 M8000 LTD what clutching and gearing is working for you in 10K+ Thread Starter — Vort Forum — Arctic Cat: Proclimb M Replies — 0 Last Post — 12-14-2016 12:16 PM
Thread — 2016 Front End or 2016 Clutching/Jackshaft/gears Thread Starter — j.janke Forum — Arctic Cat: Proclimb M Replies — 25 Last Post — 10-27-2016 09:02 PM
Thread — 2016 M8000 SE,ES Thread Starter — rpmboy Forum — Arctic Cat (Swapmeet) Replies — 1 Last Post — 03-21-2016 02:42 PM
Thread — 2016 M8000 Seat on a 2014 M8000 Thread Starter — M8 Rider Forum — Arctic Cat: Proclimb M Replies — 3 Last Post — 01-30-2016 07:02 PM
Thread — 2016 Team Proclimb Clutching parts here! Thread Starter — RACINSTATION Forum — Arctic Cat: Proclimb M Replies — 0 Last Post — 12-02-2015 05:38 PM
no new posts
