Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 12-12-2017, 03:28 PM
triple650's Avatar
triple650 triple650 is offline
Currently: Not set.
triple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond reputetriple650 has a reputation beyond repute
Default Jaws single pipe on 10-11 HO
Hello,
I just bought a used jaws pipe for the 10-11 800HO and from what jaws tells me, is that I don't need a fuel controller. Does anyone have experience with this? I am at sea level and will only be at sea level. Jaws said that all I need to do is a plug check just to be sure. I've read alot of discussions on here were people say that the non 800HO doesn't need it but the 800HO does. However I'm assuming this is for elevation, not sea level. I don't see how Jaws could be giving bad advice but I'd like to hear first hand from someone who has ridden with the Jaws y-pipe/pipe/can combo at sea level. I also have a bdx intake.
I'd like to hear your thoughts/opinions.
Thank you
__________________
2010 crossfire 800 LIMENINE wrap, 141 powerclaw
Rate this post: Yes | No
  #2
Old 12-12-2017, 06:11 PM
mbcat mbcat is offline
Currently: Not set.
Basic Member
mbcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond repute
Default Jaws pipe
No idea how much but you'll def need fuel, the slp pipe kit requires controller & jaws is more aggressive so...
  #3
Old 12-15-2017, 06:03 PM
Tmann Tmann is offline
Currently: Previously known as "Deadsled1"
Basic Member
Tmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond repute
Default
What all did you purchase? Just the pipe, or pipe and Ken, or Y pipe pipe and can? You will have a higher risk of burning down your sled at sea level then you would at elevation. You are pumping more air or denser air into the motor at sea level which could potentially give you a lean condition. Being that sled is all electronic, he should mix air and fuel consistently regardless of elevation. Which means you could potentially be running lean at sea level and equally as lean at elevation. If you are just running a new can you should not require a fuel controller if you are running a new pipe there is a good chance and you should get really good at reading your plugs if you do not put on a fuel controller
  #4
Old 12-16-2017, 11:21 AM
Currently: Not set.
Basic Member
Default Pipe
D&d recommended 10% fuel added from 7200-8250 on 2010 800hp with their y pipe & pipe.
  #5
Old 12-16-2017, 09:27 PM
Readymedic's Avatar
Readymedic Readymedic is offline
Currently: How is 18/19 lookn'??
Readymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond repute
Default
Who did you talk too? Tania answers the phone and she is very knowledgeable. She will be able to answer all of your questions.
If you want to talk right to the master, Greg, ask for him but make sure you have a pen and paper ready and make sure you know what you want to know...
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #6
Old 12-17-2017, 11:24 PM
triple650's Avatar
Currently: Not set.
Default
It was Tania but just through email. They advertise the pipe as not needing a fuel controller at sea level, but I just wanted to hear first hand from someone else who has ridden with it, as apposed to a controlled enviroment like a dyno. Like I said, I'm sure they've tested it out in the snow and know for sure. I wonder what's different between their pipe and other brands of pipes. Why does the jaws not need a controller while other do?
No matter what I'll be doing a plug test when I install the pipe, just to be sure. The Y-pipe and pipe came with a boondocker fuel controller but Jaws said they don't even have numbers for the controllers since their pipe doesn't need them. So we shall see how it works out.
__________________
  #7
Old 12-18-2017, 04:08 PM
Readymedic's Avatar
Default
Interesting...my opinion....if you go with a programmer, go with Boondocker. Don't go near PCV. I had one on my pipe and it took my ECU out..$ 2400!!!! Boondocker works differently from PCV.
  #8
Old 12-20-2017, 12:06 PM
triple650's Avatar
Currently: Not set.
Default
Quote:
Yea the pipe came with a boondocker, but if I don't need it why use it? I have no idea how to work it lol. I was hoping someone who has ran this pipe at sea level would give some insight. I guess the M series section is slowly dying lol. I should have the rest of my sled put back together this week so next week I'll be able to atleast do some testing since we hardly have any snow.
__________________
  #9
Old 12-27-2017, 08:48 PM
Stack's Avatar
Stack Stack is offline
Currently: Ready for the Snow!
MODERATOR: Paid Premium Member
Stack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond repute
Default
Not a lot of pipes on the 10-11 being run at sea level because there are just not a lot of gains to be had with any pipe on the 10-11. If you add it to porting or head mods it’s another story. I think RKtdk did some testing on this back in the day. Biggest gain is the weight savings from the can itself. SLP seemed to be most talked about, I know someone that ran a D&D setup and it was pretty solid, but this is the first chatter I’ve heard about the Jawz single on the 10-11! Lots of Jawz talk on the proclimb and Ascender platforms for sure. I hope it runs well for you, and hope you can give us feedback!
  #10
Old 01-25-2018, 02:43 PM
M9M5 M9M5 is offline
Currently: Taking donations for a new sled
Basic Member
M9M5 has a reputation beyond reputeM9M5 has a reputation beyond reputeM9M5 has a reputation beyond reputeM9M5 has a reputation beyond reputeM9M5 has a reputation beyond reputeM9M5 has a reputation beyond reputeM9M5 has a reputation beyond reputeM9M5 has a reputation beyond reputeM9M5 has a reputation beyond reputeM9M5 has a reputation beyond reputeM9M5 has a reputation beyond repute
  #11
Old 02-26-2018, 01:03 PM
Thunder101 Thunder101 is offline
Currently: making room in the garage :)
Thunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond repute
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2013 jaws pipe/jaws can no venting? Thread Starter — Ronker100 Forum — Arctic Cat: Proclimb M Replies — 1 Last Post — 02-11-2014 02:02 PM
Thread — Anyone have any details on the Jaws Single Pipe? Thread Starter — GlennRMK Forum — Arctic Cat: Proclimb M Replies — 39 Last Post — 12-14-2012 12:19 PM
Thread — Racin Station 800 big bore - Which pipe: Speedwerx single or Jaws twins? Thread Starter — Bearcat Forum — Arctic Cat Replies — 5 Last Post — 03-06-2011 08:43 PM
Thread — HAVE SLP SINGLE PIPE NEED TO KNOW WHERE TO MOUNT SINGLE EGT PROBE IN Y PIPE Thread Starter — walker Forum — Arctic Cat: M Series Replies — 6 Last Post — 01-27-2011 01:54 PM
Thread — WTB Speedwerx single & Y-pipe, Jaws F/dump can, 900 King Thread Starter — Ultra Forum — Pipes/Cans (Swapmeet) Replies — 0 Last Post — 11-24-2009 09:30 PM
no new posts
