Upgrade to Premium
Yamaha: 4-Stroke Includes all Yamaha 4-strokes, Nytro, Apex, Phazer, etc
Reply
  #1
Old 12-12-2017, 02:34 AM
sumtinwong sumtinwong is offline
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
Default swamped 4stroker
I know this isn't a yammy {and yes I posted it in the cat section as well} but for questions on a 4stroke you are the guys that have the answers I need so hear we goooo!!!
buddy swamped his 2014 xf 9000 sp ltd in a creek and im thinking about getting the buy back{insurance claim} it will probably be about 1500$
the dealer said they could only make it run with starting fluid but they didn't even empty the water out the tank so theirs no doubt in my mind I can get it to run... my ??? is if any of you have dunked one of these 4stroker turbo sleds and successfully brought it back to life? if so were their any tricks/tips besides the basics that I need to know, were their any gremlins that showed up down the road? I have done this to a many of 2strokers{and a few 4stroker quads} but this will be the first 4stroker sled I've done so any thoughts on the deal would be appreciated
thanks in advance
Rate this post: Yes | No
  #2
Old 12-12-2017, 02:37 PM
Bendy Bendy is offline
Currently: Dooin the Snowdance
Bendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond repute
Default
Probably would have been fine until the retards fired it up with starting fluid! SMH
  #3
Old 12-12-2017, 03:08 PM
Mn T sled Mn T sled is offline
Currently: Not set.
Basic Member
Mn T sled is an unknown quantity at this point
Default
Sitting for a while with out getting it running not good .
  #4
Old 12-12-2017, 07:13 PM
motojunkie101's Avatar
motojunkie101 motojunkie101 is offline
Currently: Yamaha 4 stroke moderator
MODERATOR: Premium Member
motojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond repute
Garage
Default
I would be concerned with how long it sat and the dealers not draining and changing all the fluids right away.
__________________
Quote:
Originally Posted by Himark View Post
"hold still I saw this on Snowest"
Bad decisions make good stories
2015 Yamaha Viper 162 SE/MPI turbo
Days until I retire
  #5
Old 12-12-2017, 11:12 PM
Currently: Not set.
Basic Member
Default
yea im concerned about the fluids not being changed/flushed that's what im doing tonight! puled 5 gals of water and 5 gals of gas out the tank, put heat and vp injector cleaner and about 3 gals of fresh gas in it and primed the pump a few times to try to get the water out the lines. going to drain the oil in a few minuets and fill it with some cheap 10w30 {or the lightest weight oil I have on the shelf} and engine flush and see if it starts up so I can get to flushing the system. any ideas on what I can do to flush the turbo { rinse the bearings} I don't know if they are ceramic or not and don't know if it would make a difference...any thoughts?
thanks again.
  #6
Old 12-13-2017, 02:16 AM
Currently: Not set.
Basic Member
Default
well got it started up and it sounds new still but I would guess if theirs problems with the motor it will show up in a few hundred miles. the turbo still has a clean wind down when the sled is turned off so that's reassuring! but not counting my chickens yet . the oil needs changed a few more times but I ran through all the oil, engine flush and marvel mystery oil in the shop so its going to wait till tomorrow. the relay/fuse box was absolutely clean and dry in side it was pretty surprising! all the connectors/pins looked clean and good so I just blew off the back sides of the plugins with compressed air as I saw no corrosion...yet! if their is any thing else that any one can think of that might need checked or changed post it up!! thanks always!
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #7
Old 02-07-2018, 04:30 PM
Currently: Not set.
Basic Member
Default
just figured I would give an update on the swamp monster! still running good no new problems have popped up and actually just the opposite the other day I started it up and the display came on and is working again couldn't believe my eyes!
  #8
Old 02-07-2018, 04:51 PM
up-high's Avatar
up-high up-high is offline
Currently: New femur and a new knee and more metal in hip!!
up-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond repute
Default
You probably won't know if it's ok until you get it under boost. How long did it sit? I'd be worried about rust spots on the crankshaft/con rods.
__________________
65/121 It don't get any lighter!
BERRGG
It's Mountainhorse time now!!!
  #9
Old 02-08-2018, 07:49 PM
Currently: Not set.
Basic Member
Default
the thing sat a week before I got to finish the full cleanout on it. puled the plugs the next morning {after the dunk} and turned it over with some oil in the cylinders and that's as far as we wanted to get until the dealership got a chance to deem the thing a total loss {well 19.000$ in parts and labor} it seems to be running good so far but I still have my concerns on the long-term reliability! the owner said if I side his shop 25ft x 25ft its mine so even if it goes tits up after 2-3-4 thousand miles it was only about 2 days of work .... besides I ride 2smokers and that sounds just like what im used to
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — xf 9000 swamped in a creek Thread Starter — sumtinwong Forum — Arctic Cat: TURBO Replies — 7 Last Post — 02-07-2018 04:38 PM
Thread — Turbo 4stroker Thread Starter — ridehard1212 Forum — Arctic Cat: TURBO Replies — 5 Last Post — 01-05-2009 11:14 AM
