Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 12-12-2017, 02:22 AM
sumtinwong sumtinwong is offline
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
Default xf 9000 swamped in a creek
buddy swamped his 2014 xf 9000 sp ltd in a creek and im thinking about getting the buy back{insurance claim} it will probably be about 1500$.
the dealer said they could only make it run with starting fluid but they didn't even empty the water out the tank so theirs no doubt in my mind I can get it to run... my ??? is if any of you have dunked one of these 4stroker turbo sleds and successfully brought it back to life? if so were their any tricks/tips besides the basics that I need to know, were their any gremlins that showed up down the road? I have done this to a many of 2strokers{and a few 4stroker quads} but this will be the first 4stroker sled I've done so any thoughts on the deal would be appreciated
thanks in advance
Rate this post: Yes | No
  #2
Old 12-12-2017, 11:11 AM
89sandman's Avatar
89sandman 89sandman is online now
Currently: Meadow Muffin
89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute
Default
If they didn't even drain the tank they probably didn't pull the plugs and get the water out of the cylinders either, intake, or the crank case. I'd be most worried if they didn't pull the plugs and drain the cylinders Do you know if the engine sucked water when it got swamped?
  #3
Old 12-12-2017, 12:08 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
Worthless without pics!!
HAHA
__________________
OEM parts from Free Agent
Ambassador for:
FB & IG: Scott Stiegler
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Check out these cool products:
  #4
Old 12-12-2017, 02:15 PM
izzni's Avatar
izzni izzni is offline
Currently: Improving the NS1 Gauge System
izzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond repute
Default
If the gauge hasn't already crapped out it will within a few months. All of the electrical connectors will be busy corroding away too, since I'm sure there is water in the pin cavities. The motor would probably be fine if you change the oil a couple times. I'm sure the fuel pump is busy working up some corrosion too.
The sled probably won't be very reliable to put it midly. And it'll be a pain in the butt to diagnose the electrical issues.
__________________
Deluxe Gauge Software Reflash
www.NextStageGauges.com
The Deluxe Gauge Software Reflash enhances the stock Arctic Cat gauge to correct odometer inaccuracies, allow engine coolant temp to be displayed, add data logging, and many other improvements.
  #5
Old 12-12-2017, 09:12 PM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is offline
Currently: Making roll-over valve kits since 2008
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
Default
If it was still running when it when under, it may have sucked in some water and hydro-locked. If this is the case, it probably has bent rod(s).
If the water wasn't drained right away, there may be rust/corrosion on the crank, turbo shaft or other internal engine components.
By now, most likely it's just a parts sled.
__________________
Four Stroke Solutions LLC
Patented Roll-Over Valve Systems
ROV kits for M/XF7000/Viper, Sidewinder and King Cat with Quick-prime!
For Arctic Cat and Yamaha Sleds
Patents 8,225,766 8,528,516 9,303,537
http://fourstrokesolutionsllc.webs.com/
e-mail fourstrokesolutionsllc@hotmail.com
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to MTN_VIPER For This Useful Post:
d1100t (12-13-2017)
  #6
Old 12-12-2017, 10:58 PM
Currently: Not set.
Basic Member
Default
we popped the plugs the same night cleared it out. the dealer said they could make it run on starter fluid so "probably" no major engine problems.?.?. the oil is over full not by a lot but im sure its got water in it, draining the oil tonight so we will see. is their a cheap oil I can use to do my flushes I was going to use 10w30 just because its on the shelf and a engine flush. yep the gauge don't work and don't expect it to ever again as for the plugs/pins I was just going to disconnect spray with electoral cleaner dry and put a touch of die-electric grease on them. im wanting this sled to just be a trail sled {or go fishing} as their is a million miles of trails around me in northpole Alaska and I never ride alone so if it breaks down its easy to just tow it home or to a convenient place to load it up so im not scared to work through the problems as they arrive {I keep a turbo 800 2smoker for the mountains}
so does any one know if the turbo has ceramic ball bearings or conventional style? that might be a concern if they rust but im sure ill hear it coming if the bearings are shot. are the turbos in this sleds rebuildable or just replaceable??
thanks again for the comments and help!!
  #7
Old 12-13-2017, 02:14 AM
Currently: Not set.
Basic Member
Default
well got it started up and it sounds new still but I would guess if theirs problems with the motor it will show up in a few hundred miles. the turbo still has a clean wind down when the sled is turned off so that's reassuring! but not counting my chickens yet . the oil needs changed a few more times but I ran through all the oil, engine flush and marvel mystery oil in the shop so its going to wait till tomorrow. the relay/fuse box was absolutely clean and dry in side it was pretty surprising! all the connectors/pins looked clean and good so I just blew off the back sides of the plugins with compressed air as I saw no corrosion...yet! if their is any thing else that any one can think of that might need checked or changed post it up!! thanks always!
  #8
Old 02-07-2018, 04:38 PM
Currently: Not set.
Basic Member
Default
well I figured I would give an update on the swamp monster... all is running good no new problems have popped up and the other day the display turned back on and is working great all the buttons and displays are back couldn't hardly believe it! still no signs of corrosion no the plugs-relays or fuse box.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Grooming Report Orr Creek, Johnson Creek, Skate Creek Thread Starter — backcountrysnowbikes Forum — Washington Replies — 57 Last Post — 02-11-2016 11:09 PM
Thread — Enough for road riding...wolf creek pass,duschene,mill creek Thread Starter — hkollie Forum — Utah Replies — 3 Last Post — 12-05-2014 08:57 AM
Thread — 2012 800 assault $9000, 2012 pro rmk retro $9000 Thread Starter — 2007dragonman Forum — Polaris (Swapmeet) Replies — 3 Last Post — 12-27-2012 09:04 PM
Thread — LOLO CREEK to FISH CREEK (Spring Creek Road) Thread Starter — Scott Forum — Montana Replies — 10 Last Post — 02-05-2012 11:13 PM
Thread — Ryan Creek vs. Rutherford creek road to ice cap? Thread Starter — UBRultra Forum — Canada West (BC/AB) Replies — 3 Last Post — 03-22-2010 10:50 PM
no new posts
