Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 12-11-2017, 06:09 PM
trussell456 trussell456 is offline
Currently: Not set.
Basic Member
trussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond repute
Default 98 RMK cutting out/dim headlight problem
I have a 98 RMK 600 that seems to have an electrical issue. At or just above idle it keeps cutting out. Acting like someone pushes the kill switch down then back up before it shuts off, and sometimes does actually just shut down. When the sleds actually moving nothing like this occurs until coming back down to idle.
Also, the headlight is super dim, and a few times at idle (not at the same time as the cutting out) it would flicker on to as bright as it should be, then back to super dim. I'm no mechanic and don't really know where to start looking.
Does this just sound like a bad connection somewhere or more complicated than that?
Also, it seems to me like these two problems are not related as they never happen at precisely the same time.
Rate this post: Yes | No
  #2
Old 12-11-2017, 06:48 PM
Currently: Not set.
Basic Member
Default
So i figured out the headlight problem is the voltage regulator. But that shouldn't have anything to do with the engine cutting out right?
  #3
Old 12-12-2017, 11:19 AM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
Right, they are two separate electrical circuits. It sounds like the throttle safety switches which are in the throttle assembly are not operating correctly or throttle lever free play is out of spec. There should be .010" to .030" gap between throttle lever and throttle block at idle position.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #4
Old 12-14-2017, 05:37 PM
Currently: Not set.
Basic Member
Default
Ok thanks, that sounds like it might be the problem. Ill adjust it this weekend and see if it fixes it
  #5
Old 12-30-2017, 06:14 PM
Currently: Not set.
Basic Member
Default
so i got the throttle adjusted better and the cutting out disappeared. Also, purchased and installed new voltage regulator. Before the lights were just really dim, now with the new regulator it has blown two headlight bulbs. But not the taillight or dash lights. I haven't checked if the new regulator is not faulty, but seems weird it only blows the headlight
  #6
Old 12-30-2017, 08:39 PM
Currently: Not set
Default
Headlights seem to blow quicker than other bulbs for some reason. Coincidentally there is a thread in the Gen 2 section with a sled blowing headlights and he just replaced the regulator too. https://www.snowest.com/forum/showthread.php?t=438657 It would be the same regulator as what you have. I wonder if someone is selling faulty regulators.
__________________
  #7
Old 12-30-2017, 09:01 PM
Currently: Not set.
Basic Member
Default
Quote:
i was reading somewhere the aftermarket voltage regulators aren't very good. but an oem Polaris one is like $70. Guess ill check voltage tomorrow and go from there. Thanks for the good info on these couple threads retiredpop
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 02 rmk 800 headlight goes out or very dim when i squeeze brake lever Thread Starter — cranktwister Forum — Polaris: EDGE Replies — 5 Last Post — 12-21-2014 02:58 PM
Thread — Dim Headlight, No Dash, No heated grips or throttle and bogs above 3500 RPM Thread Starter — 06700RMK Forum — Polaris Replies — 5 Last Post — 03-16-2013 12:11 AM
Thread — dim headlight on 2001 xc 120 Thread Starter — Blu Du Forum — Youth Sleds Replies — 2 Last Post — 12-20-2012 08:13 PM
Thread — 07 d7 Headlight and gauges cutting out. Thread Starter — jdpbassman Forum — Polaris: IQ Replies — 2 Last Post — 01-24-2011 02:24 PM
Thread — Headlight goes dim! Help Thread Starter — irideabigpumpkin Forum — Yamaha Replies — 1 Last Post — 12-21-2008 01:05 PM
no new posts
