Upgrade to Premium
Reply
  #1
Old 12-09-2017, 08:44 PM
Bradley T Bradley T is online now
Currently: Not set.
Basic Member
Bradley T is an unknown quantity at this point
Default M1100 Turbo Slipping Under Load
I am hoping someone can assist. I rode my M1100 turbo today and when the turbo kicks in hard, it feels like my drivers are skipping and you can feel it skip. It isn't engine related as I don't have this problem when I take the sled up to high speed slowly. It happens in power or when you hit the throttle quickly. If feels as if the chain is skipping on my gears. The sled has a lot of aftermarket items and is pushing 270 hp. I have already checked track tension and the track is not too loose. I have 1 deflection at 20 lbs.
I use a Dayco belt and rode with it all last year (only $65 from Autozone) and it didn't happen then. Any suggestions on what to look for? The belt looks new.
Thanks for the help.
Rate this post: Yes | No
  #2
Old 12-09-2017, 11:16 PM
Snowmow's Avatar
Snowmow Snowmow is online now
Currently: Not set.
Snowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond repute
Default
You chain is probably skipping. Inspect it ASAP
  #3
Old 12-10-2017, 10:11 PM
Spike89 Spike89 is offline
Currently: Not set.
Spike89 is an unknown quantity at this point
Default
X2 on chain.
  #4
Old 12-17-2017, 01:13 AM
blackjack85335 blackjack85335 is offline
Currently: Love my M1100
blackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond repute
Default Open it asap.
My chain case blew up first ride last year and almost shot a chunk of the case into my leg. I switched over to a belt drive and couldn't be happier. Very snappy and great sense of relief knowing I have no chain or gears and oil to worry about. Let us know what you find inside.
  #5
Old 12-18-2017, 11:41 AM
Currently: Not set.
Basic Member
Default
Thanks for your reply. I will let you know what I find. Quick question, where did you go to get the belt drive and approx cost?
Thanks again
  #6
Old 12-18-2017, 12:07 PM
Snowmow's Avatar
Currently: Not set.
Default
Quote:
Thanks again
Call TKI in Montana or C3
  #7
Old 12-18-2017, 01:30 PM
Turbo11T Turbo11T is offline
Currently: EVOLVING
Turbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond repute
Default
The chain is on its way out. Probably time for hyvo gears and chain. I had my chain break on my m1100t with very few miles. The torque of this engine is very good and the chain/gears/tensioner is very poor. Country cat sells an update kit with the gears/chain/tensioner. Get it before you need a chaincase as well.
  #8
Old 12-22-2017, 09:08 PM
Currently: Not set.
Basic Member
Default Possible Solution
So I have my sled at the dealer but they can't look at it for several weeks. Have any of you had an issue with the drivers breaking or slipping on the drive shaft, thus causing it to feel like it is slipping? I was thinking that something might be wrong with the drivers on the drive shaft. I have the white 7 tooth drivers now. Any suggestions?
  #9
Old 12-22-2017, 09:10 PM
Snowmow's Avatar
Currently: Not set.
Default
I’m really thinking it’s your chain.
Chain is more common then the drivers, unless your track was REALLY loose.
Is this sled under warranty?
  #10
Old 12-23-2017, 12:57 AM
Currently: Not set.
Basic Member
Default
I am not sure if it is under warranty but I think it should be since the dealer replaced the upper drive shaft late last year and had to open the gear case. Wouldn't it make a knocking noise if the chain was skipping? I really don't hear anything when it happens. Maybe the noise of my straight pipe is too loud...
  #11
Old 12-23-2017, 09:46 AM
Snowmow's Avatar
Currently: Not set.
Click Here to Register
  #12
Old 12-23-2017, 01:56 PM
Currently: Not set.
Basic Member
  #13
Old 12-23-2017, 03:28 PM
Snowmow's Avatar
Currently: Not set.
  #14
Old 12-23-2017, 05:55 PM
Currently: Not set.
Basic Member
  #15
Old 12-25-2017, 10:29 AM
Snowmow's Avatar
Currently: Not set.
  #16
Old 12-27-2017, 04:28 PM
Currently: Not set.
Basic Member
  #17
Old 12-27-2017, 07:29 PM
Snowmow's Avatar
Currently: Not set.
  #18
Old 12-28-2017, 01:45 PM
Currently: Not set.
Basic Member
  #19
Old 12-28-2017, 02:41 PM
Snowmow's Avatar
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — For sale like new Arctic cat m1100 stock turbo and stock m1100 turbo with manifold Thread Starter — PowersportpartsIdaho Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 12-12-2016 10:38 PM
Thread — For sale like new Arctic cat m1100 stock turbo and stock m1100 turbo with manifold Thread Starter — PowersportpartsIdaho Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 12-12-2016 01:48 AM
Thread — M1100/M9000 Turbo Stock Turbo Thread Starter — RACINSTATION Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 09-03-2015 12:43 PM
Thread — 07 600 track slipping under load Thread Starter — zgriff40 Forum — Polaris Replies — 3 Last Post — 02-24-2008 11:02 PM
no new posts
