Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 12-09-2017, 08:13 PM
1Mike900 1Mike900 is online now
Currently: Not set.
1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute
Default Removing jackshaft
Been looking thru the old threads, but couldn't find anything? I would assume to remove the jackshaft one would need to remove carbs/airbox etc... Question is does the aluminum shaft cover need to be removed to get it out? Does the bellypan need to be removed also? I have vent holes drilled in bellypan in that area almost dead inline. Could I slide it straight out, or do you lift over?
Thanks Mike
Rate this post: Yes | No
  #2
Old 12-21-2017, 10:35 PM
Dobber1 Dobber1 is offline
Currently: "Better than I deserve."
Dobber1 has a reputation beyond reputeDobber1 has a reputation beyond reputeDobber1 has a reputation beyond reputeDobber1 has a reputation beyond reputeDobber1 has a reputation beyond reputeDobber1 has a reputation beyond reputeDobber1 has a reputation beyond reputeDobber1 has a reputation beyond reputeDobber1 has a reputation beyond reputeDobber1 has a reputation beyond reputeDobber1 has a reputation beyond repute
Default
Give this a shot...should be similar?
https://youtu.be/oTaCz1HujOg
  #3
Old 12-25-2017, 12:09 PM
tmaiwa tmaiwa is offline
Currently: Not set.
tmaiwa has much to be proud oftmaiwa has much to be proud oftmaiwa has much to be proud oftmaiwa has much to be proud oftmaiwa has much to be proud oftmaiwa has much to be proud oftmaiwa has much to be proud oftmaiwa has much to be proud oftmaiwa has much to be proud oftmaiwa has much to be proud oftmaiwa has much to be proud of
Default shaft
Don't need to remove carbs or nothing. Remove chain cover, take off lower gear, 3 nuts behind gear that hold bearing cover in place same thing on clutch side. I remove secondary to give more room, 3 nuts on that side too. Shaft will come out. Of course, must loosen the track.
  #4
Old 01-28-2018, 10:47 AM
Currently: Not set.
Default
I was talking jackshaft, you are referencing drive shaft I believe?
  #5
Old 01-28-2018, 10:56 AM
deanross deanross is offline
Currently: Not set.
deanross has a reputation beyond reputedeanross has a reputation beyond reputedeanross has a reputation beyond reputedeanross has a reputation beyond reputedeanross has a reputation beyond reputedeanross has a reputation beyond reputedeanross has a reputation beyond reputedeanross has a reputation beyond reputedeanross has a reputation beyond reputedeanross has a reputation beyond reputedeanross has a reputation beyond repute
Default
You tube does have several jack shaft removal videos. Not sure if any for your specific sled or not?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — jackshaft help Thread Starter — Melfjord Forum — Polaris: Pro-Ride Replies — 0 Last Post — 12-14-2014 01:19 PM
Thread — Jackshaft Thread Starter — graham_r Forum — Arctic Cat: Proclimb M Replies — 22 Last Post — 01-19-2014 10:09 PM
Thread — Jackshaft Thread Starter — cekeys Forum — Ski-Doo: S-2000 and older Replies — 1 Last Post — 07-11-2012 06:48 AM
Thread — Jackshaft. Thread Starter — aksnopro Forum — Arctic Cat: Proclimb M Replies — 16 Last Post — 01-31-2012 09:09 AM
Thread — Jackshaft??? Thread Starter — dyrengd Forum — Polaris: 900 Replies — 6 Last Post — 12-08-2010 03:03 AM
no new posts
