Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 12-05-2017, 08:25 AM
Sno Junkie Sno Junkie is offline
Currently: Not set.
Sno Junkie has a reputation beyond reputeSno Junkie has a reputation beyond reputeSno Junkie has a reputation beyond reputeSno Junkie has a reputation beyond reputeSno Junkie has a reputation beyond reputeSno Junkie has a reputation beyond reputeSno Junkie has a reputation beyond reputeSno Junkie has a reputation beyond reputeSno Junkie has a reputation beyond reputeSno Junkie has a reputation beyond reputeSno Junkie has a reputation beyond repute
Default Axys Gearing
I have a 2017 Axys 800 155 with a BD Sidekick. I am using the clutching that BD supplies with the kit. I ride 6500-8500. I have been going through belts every 150 miles. I would like to gear mine down and see if it helps with the belt heat. I ride the trees. I am very very "choppy" throttle rider. I am not very good at letting it cool down. I am also about 250# with Avi pack on.
I'm confused on the info I am receiving. The TRS Clutch thread mentions that my stock gearing is 2.22. The info I received from TK1 is that my gearing is 1.96. TK1 is suggesting a 2.17. Obviously I think he knows his stuff and 95% trust what he is saying, but why am I seeing different here on the board?
Rate this post: Yes | No
The Following User Says Thank You to Sno Junkie For This Useful Post:
Chad steele (02-04-2018)
  #2
Old 12-05-2017, 10:03 AM
KAWGRN's Avatar
KAWGRN KAWGRN is offline
Currently: gone riding
KAWGRN has a reputation beyond reputeKAWGRN has a reputation beyond reputeKAWGRN has a reputation beyond reputeKAWGRN has a reputation beyond reputeKAWGRN has a reputation beyond reputeKAWGRN has a reputation beyond reputeKAWGRN has a reputation beyond reputeKAWGRN has a reputation beyond reputeKAWGRN has a reputation beyond reputeKAWGRN has a reputation beyond reputeKAWGRN has a reputation beyond repute
Default
driver size
__________________
19 SX 450 Yeti 129 SS
14 KTM450SX TS -LT
13 KTM XC 450 ARO 129
Sleds gone MAYBE for good
  #3
Old 12-05-2017, 11:45 AM
Currently: Not set.
Default
Quote:
Originally Posted by KAWGRN View Post
driver size
Are you asking what driver size I have or that the driver size changes the final ratio?
  #4
Old 12-05-2017, 08:09 PM
roughrider99's Avatar
roughrider99 roughrider99 is offline
Currently: the stutter button on the tnytro is too much fun!
roughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond repute
Garage
Default
1.96 is the drive ratio of just the belt drive and 2.22 is the Final drive ratio which takes into account the size/tooth count of driver. As have 7 or 8 tooth drivers effectively changes your gearing aswell
__________________
I ride where its steep n' deep
17' 800 T-axys LE
16' 600 axys pink ribbon (hers)
15' viper mtx 162 PC3
12' pro rmk (for sale)
97 wrx sti type r summer boosted toy!
  #5
Old 12-05-2017, 10:31 PM
Currently: Not set.
Default
Quote:
Thank you!
  #6
Old 12-06-2017, 12:13 AM
wellfed777 wellfed777 is online now
Currently: Not set.
wellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond repute
Default
lower gearing can be helpful for sure
but........... if you're going through belts every 150 miles
(2-3 rides) something is not right with your clutching
you might wanna try that TRS clutching
  #7
Old 12-06-2017, 09:19 AM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is offline
Currently: Power Clawing the Axys....
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
Default
Just remember that Tom's kits (TKI) ratio's are based off 8 tooth drivers.
( at least that is what I remember of the conversation)
I went through alot with him on ratios..till I just went with swapping my tiny stock 7's to 8's
I think you have alot more going on than gearing...Dive into your BD turbo dealer head, and see what they are setting them up at ..should be no secrets.
__________________
Dealers for:
Silber Turbos.
GGB Exhaust.
TKI.
F-N-I.
K-Mod.
2016 Axys 3" 162 P/C Track W/Silber Turbo/K-Mod Gen III/TKI
The Following User Says Thank You to Sage Crusher For This Useful Post:
  #8
Old 12-10-2017, 08:38 PM
ripnit ripnit is online now
Currently: working my a$$ off to take time off this winter to RIDE
ripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond repute
Default
First thing to check is clutch Alignment if you haven't aready.... Watched a friend take off secondary, set it on the floor, later put it back on and one of the alignment spacer was laying on the floor and he never saw it. Also check motor mounts.
__________________
18 Axys 800, 163, Stock.
16 Axys 800 Snowcheck, Boondocker turbo, kmod, 280 3.5 pitch 163 track.
12 Pro Rmk 800, Boondocker Turbo, 14 motor, 163 Axys 2.6 track.
04 827 RK Tek summit X 144, DJ clutch kit, cc y and pipe, super q can, BR TECH Thrasher side pannels and hood, USI Project X skis, 06 X seat.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #9
Old 01-09-2018, 09:50 PM
kraigsetag kraigsetag is online now
Currently: Not set.
Basic Member
kraigsetag is an unknown quantity at this point
Default
Go with the Vohk clutching my buddy was having same issue and going through belts and the Vohk clutching dropped his clutch temps dramatically and thus helping belt Life we knew his was way hotter than mine but now same temp or even cooler than mine
  #10
Old 01-10-2018, 02:46 AM
snowracer21 snowracer21 is offline
Currently: Not set.
snowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond repute
The Following User Says Thank You to snowracer21 For This Useful Post:
grahamindus (02-15-2018)
  #11
Old 01-10-2018, 12:12 PM
aksledjunkie's Avatar
aksledjunkie aksledjunkie is offline
Currently: Payin' the dough to play in the snow
aksledjunkie has disabled reputation
Click Here to Register
  #12
Old 01-10-2018, 02:51 PM
L. Perry L. Perry is online now
Currently: Not set.
L. Perry has a reputation beyond reputeL. Perry has a reputation beyond reputeL. Perry has a reputation beyond reputeL. Perry has a reputation beyond reputeL. Perry has a reputation beyond reputeL. Perry has a reputation beyond reputeL. Perry has a reputation beyond reputeL. Perry has a reputation beyond reputeL. Perry has a reputation beyond reputeL. Perry has a reputation beyond reputeL. Perry has a reputation beyond repute
  #13
Old 01-11-2018, 02:51 PM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
  #14
Old 02-04-2018, 12:13 AM
Chad steele Chad steele is offline
Currently: Not set.
Basic Member
Chad steele is an unknown quantity at this point
  #15
Old 02-15-2018, 02:22 PM
Tewstroke Tewstroke is offline
Currently: Part of the department of redundancy department.
Tewstroke has a reputation beyond reputeTewstroke has a reputation beyond reputeTewstroke has a reputation beyond reputeTewstroke has a reputation beyond reputeTewstroke has a reputation beyond reputeTewstroke has a reputation beyond reputeTewstroke has a reputation beyond reputeTewstroke has a reputation beyond reputeTewstroke has a reputation beyond reputeTewstroke has a reputation beyond reputeTewstroke has a reputation beyond repute
  #16
Old 02-15-2018, 02:25 PM
  #17
Old 02-15-2018, 03:34 PM
d8grandpa d8grandpa is online now
Currently: rocking the axys
d8grandpa has a reputation beyond reputed8grandpa has a reputation beyond reputed8grandpa has a reputation beyond reputed8grandpa has a reputation beyond reputed8grandpa has a reputation beyond reputed8grandpa has a reputation beyond reputed8grandpa has a reputation beyond reputed8grandpa has a reputation beyond reputed8grandpa has a reputation beyond reputed8grandpa has a reputation beyond reputed8grandpa has a reputation beyond repute
  #18
Old 03-18-2018, 10:46 AM
02sedona's Avatar
02sedona 02sedona is offline
Currently: Not set.
02sedona has a reputation beyond repute02sedona has a reputation beyond repute02sedona has a reputation beyond repute02sedona has a reputation beyond repute02sedona has a reputation beyond repute02sedona has a reputation beyond repute02sedona has a reputation beyond repute02sedona has a reputation beyond repute02sedona has a reputation beyond repute02sedona has a reputation beyond repute02sedona has a reputation beyond repute
  #19
Old 03-18-2018, 09:17 PM
sledhed's Avatar
sledhed sledhed is offline
Currently: I need room in my shop!!
sledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond repute
  #20
Old 03-19-2018, 10:18 AM
Teth-Air's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Axys PRO 3" Track Gearing Change Thread Starter — Randman Forum — Polaris: AXYS Replies — 11 Last Post — 10-30-2017 09:55 AM
Thread — Gearing down the axys? Thread Starter — Braaap12 Forum — Polaris: AXYS Replies — 9 Last Post — 11-17-2016 11:18 PM
Thread — Axys 3" Gearing 10-12K ft w/ Silber Thread Starter — CO 2.0 Forum — Polaris: TURBO Replies — 3 Last Post — 09-26-2016 10:32 AM
Thread — Ater a season of testing, Axys Pro gearing ok? Thread Starter — ggcustoms Forum — Polaris: AXYS Replies — 10 Last Post — 03-09-2016 01:00 PM
Thread — Axys Gearing Thread Starter — MSTRAYER Forum — Polaris: AXYS Replies — 7 Last Post — 02-22-2016 09:48 AM
no new posts
