Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 12-02-2017, 08:35 PM
ippielb ippielb is offline
Currently: www.youtube.com/ippielb
Basic Member
ippielb has a reputation beyond reputeippielb has a reputation beyond reputeippielb has a reputation beyond reputeippielb has a reputation beyond reputeippielb has a reputation beyond reputeippielb has a reputation beyond reputeippielb has a reputation beyond reputeippielb has a reputation beyond reputeippielb has a reputation beyond reputeippielb has a reputation beyond reputeippielb has a reputation beyond repute
Default Huge stumble WOT from idle
09í m8, aerocharger turbo, boondocker control box.
Idling, smash it wide open, and it sits there bogging at around 4,500 rpm, slowly picks up then its normal.
Idling, feather the throttle, blipping it, then smash it wide open and itís a rocket.
Where does a guy look, tuning? Clutching?
Rate this post: Yes | No
  #2
Old 12-02-2017, 09:36 PM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
Turbo has to spool up. You could raise the engagement rpm...but smaahing it wide open on turbos doesn't work well. Tou also have a heated batch of air in the intake. I had problems getting on the pipe at all with my turbo until cold air intake...that helped a bunch. But, you cant just smash a turbo wide open in general.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to jim For This Useful Post:
Scott (12-02-2017)
  #3
Old 12-02-2017, 11:59 PM
WyoBoy1000's Avatar
WyoBoy1000 WyoBoy1000 is offline
Currently: Working,
WyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond repute
Default
Does it make a hollow woooooaaaat sound or more of a gurgle slobber sound.
Prob reeds though
__________________
Shhhh, its a secret
Assume = when you as$,u,me you make an as$ out of u and me. Think, ask, get the facts and then go forward.
  #4
Old 12-03-2017, 05:23 PM
Basic Member
Default
Quote:
Part I find confusing is if it anywhere above idle blipping the throttle, no boost, and smash it open it goes like snot. I have a jerry rigged cold air intake with white 3Ē pvc fittings lol. I found that helped a lot, but maybe itís just something I need to live with.
I guess going from a N/A race sled where I can go WOT from idle and have it sit at the power and spoiled me a bit lol, oh and having a speedwerx supercharger on my Proclimb wouldnít help either.
Quote:
Prob reeds though
Lol the wooooaaattttttt-ggggerrrrrrraaaaaaaaaaaaaaaaaaaaaaappp sound. Iíll stick my scope down in the throttle bodies to take a peak at the reeds, forgot I never checked this sled only my Proclimb I did.
  #5
Old 12-03-2017, 05:52 PM
WyoBoy1000's Avatar
Currently: Working,
Default
Look at reeds, sounds lean.
Try throwing a ton of fuel at the bottom in mid and wot
__________________
Shhhh, its a secret
  #6
Old 12-04-2017, 02:38 AM
Sunvang Sunvang is offline
Currently: Not set.
Sunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond repute
Default
I have to disagree. No problem going from idle to WOT on a turboed sled. Just need to have the right setup. Ive had several Polaris sleds with Boondocker, Silber and MTNTK turbo kits. Tune the fueling snd clutches well, and its no problem going from idle to WOT. Some turbo charghers use longer to spool, but it shouldnt bog, stumble or fall on its face.
Has the sled always been like this? What gen Boondocker fuel controller?
__________________
2019 Arctic Cat Hardcore Alpha 154" Silber Turbo
The Following User Says Thank You to Sunvang For This Useful Post:
Hardass (12-04-2017)
  #7
Old 12-04-2017, 08:31 PM
Basic Member
Default
3600 lo. 0
3600 md. -3
3600 hi. -10
5000 lo. 0
5000 md. -7
5000 hi. -13
Changed the negatives to positives and still did it. Engagement is around 4000rpm, when I crack it open it stops at like 4200 sits there, basically until boost comes in it seems, which take like 1 full second.
I never got around to checking the reeds. We had some snow here at home so I played around.
  #8
Old 12-04-2017, 08:37 PM
Basic Member
Default
Thatís what I was thinking, Iíve seen other turbos guys can go wot and itís a little slower then a stock take off, so thatís why I was confused.
Sled has been like this since I bought the sled I robbed the motor and turbo from.
I forgot to write down the generation of controller. Itís a pump gas no aux injectors, has the psi-h psi-l settings. Itís an all grey cover around the screen with red outlines buttons.
  #9
Old 12-05-2017, 02:13 AM
xpturbo600 xpturbo600 is offline
Currently: Not set.
Basic Member
xpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond repute
Default
The problem is the turbo veins...they are too tight. Open them by extending the adjustment rod into the turbine housing. An acid test is to make a change and if it gets worse, you went the wrong direction. What you are experiencing is excess back pressure choking the motor when the veins are closed that corrects as the veins open. The vein setting affects spool, but I found a looser setting is better all around than trying to eliminate every bit of lag since you do not ride from stop. Every turbo kit will lag a little from a stop because the turbo has to spool up since there is no load on the turbine at idle.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Idle rpm drop after WOT Thread Starter — TheBCSledder Forum — Polaris: IQ Replies — 48 Last Post — 03-27-2013 11:26 PM
Thread — M7 WOT stumble Thread Starter — fordpickupman Forum — Arctic Cat: M Series Replies — 7 Last Post — 03-22-2012 07:38 AM
Thread — New motor WOT stumble Thread Starter — Snowlover Forum — Polaris: IQ Replies — 4 Last Post — 06-08-2011 10:39 PM
Thread — So many "stumble" threads but... Off idle stumble? Thread Starter — dub Forum — Polaris: Pro-Ride Replies — 0 Last Post — 02-28-2011 12:36 PM
Thread — M8RG?? Can you hit WOT from idle? Thread Starter — Rms Rydning Forum — Arctic Cat: TURBO Replies — 0 Last Post — 01-13-2011 08:59 AM
no new posts
