Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 12-02-2017, 05:44 PM
blown addiction blown addiction is offline
Currently: Ready to ride
blown addiction has a reputation beyond reputeblown addiction has a reputation beyond reputeblown addiction has a reputation beyond reputeblown addiction has a reputation beyond reputeblown addiction has a reputation beyond reputeblown addiction has a reputation beyond reputeblown addiction has a reputation beyond reputeblown addiction has a reputation beyond reputeblown addiction has a reputation beyond reputeblown addiction has a reputation beyond reputeblown addiction has a reputation beyond repute
Default 2015 mtx w MPI turbo question for the boost gauge
I'm finally getting a boost gauge installed on my sled, never had issues with the setup stock but wanted to see what I'm getting and will likely be going to do the Evo upgrade.
Question is there is a little nipple coming off the stock MPI airbox that has a little black plug on it. It is just above the turbo side intake tube. Can I just use that for my gauge and not worry about adding a tee down low and then worry about keeping the pressure tube to the gauge out of the way of all the heat. I figured this location should also give me the most accurate reading since it is right off the airbox before it goes into the throttle bodies.
Thanks
Rate this post: Yes | No
  #2
Old 12-03-2017, 11:08 AM
thamax thamax is offline
Currently: Not set.
Basic Member
thamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond repute
Default
That is nipple is for the mpi fuel regulator upgrade! Can be used for a boost gauge but you will not see vaccum at that port. There is ports on the throttle bodies that i prefer to use for a boost gauge
  #3
Old 12-05-2017, 02:32 AM
xpturbo600 xpturbo600 is offline
Currently: Not set.
Basic Member
xpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond repute
Default
Boost gauge needs plumbed into a common line pulling signal from behind each of the throttle bodies. To do it use 1/8" silicone boost line and tee each of the three lines in series, each from one of the two reference ports on the throttle bodies. Stock, the reference ports have little vaccum port nipples on them. Pull one off each throttle body and zip tie the rest. Zip tie all tee'd connections as well. If you source pressure from the place you discussed, then you are not reading boost. Boost is what the motor sees.
The Following User Says Thank You to xpturbo600 For This Useful Post:
Snowmixer (12-05-2017)
  #4
Old 12-05-2017, 03:31 AM
Default Thanks
Got it I will see if I can find the right ports.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2015 Viper MTX 153 MPI 190 Turbo Thread Starter — THE OUTLAW Forum — Yamaha (Swapmeet) Replies — 4 Last Post — 12-16-2017 06:57 PM
Thread — 2015 Yamaha Viper MTX 240hp MPI Turbo Thread Starter — homeboy Forum — Yamaha (Swapmeet) Replies — 7 Last Post — 12-01-2016 08:57 PM
Thread — 2015 Viper MTX MPI Turbo LOW MILES Thread Starter — troyhaaland Forum — Yamaha (Swapmeet) Replies — 7 Last Post — 01-14-2016 02:16 PM
Thread — 2015 VIPER MTX 153" MPI Turbo Kit Thread Starter — worklater Forum — Yamaha (Swapmeet) Replies — 6 Last Post — 11-22-2015 11:34 PM
Thread — 2015 Viper MTX 162 LE MPI turbo Video Thread Starter — Matt@MPI Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 6 Last Post — 03-11-2014 07:22 PM
no new posts
