Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 12-01-2017, 01:08 PM
MtnRidr4Life's Avatar
MtnRidr4Life MtnRidr4Life is offline
Currently: Not set.
MtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond reputeMtnRidr4Life has a reputation beyond repute
Default Wossner vs Pro-X Pistons
Anyone know if Pro-X is a decent choice for pistons?
I know RKT and Bikeman both use Wossner. The place I had my crank trued at suggested putting in the Pro-X, which is half the price of the Wossner and comes with everything including the wristpin bearing.
If the Pro-X are good, I'm curious the performance difference between that the Wossner.
__________________
'09 Summit X 800 163x2.5, S36 kit, T-motion, Primary race clutch, HPS can
Rate this post: Yes | No
  #2
Old 12-02-2017, 06:42 PM
FEZ FEZ is offline
Currently: Mechanic for and Advisor to SHR
Basic Member
FEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond repute
Default
Yes, the Pro-X is a good piston and they use the Riken ring, which is an excellent ring.
SHR offers these pistons for the cast option and the RKT designed Wisecos for the forged option.
The Wossner's used by RKT and SHR are different than the "off the shelf" Wossners. The off the shelf Wossners are standard Wiseco copy's.
RKT no longer uses Wossner to manufacturer their pistons, they use Wiseco. RKT and SHR worked together to design this piston.
Each piston/pin is 86G lighter, if memory serves. I ran the original prototype Wiseco RKT piston in my '09 for 3 seasons. I also run them in my 15' as well.
You cannot go wrong with either IMO.
The Following User Says Thank You to FEZ For This Useful Post:
dingalingman1 (09-04-2018)
  #3
Old 02-20-2018, 12:19 PM
BBP BBP is offline
Currently: Not set.
Basic Member
BBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond repute
Default
So, what do you sell? Wiseco or Wossner? It seems like not too long ago, SHR & RKT were both pushing wossner & staying away from wiseco. Best thing since peanut butter. Which piston is 86gr lighter & lighter than what, stock? To improve crank balance on the 800R, do you want a lighter or heavier piston? Just curious about the weights, as I will be putting an 880 together soon & will need pistons. I know it's different, but the principles are the same. I'm also curious about what's different on the custom designed stock replacements. Thanks.
  #4
Old 03-13-2018, 04:15 PM
FEZ FEZ is offline
Basic Member
Default
SHR offers the Pro-X for the customer wanting to run a cast piston. We offer the RKT/SHR designed Wiseco for the customer wanting a lighter, forged piston.
Wossner became too difficult to deal with so the decision was made to switch manufacturers.
Call John @ 612.718.3861 for further clarification.
BBP (03-20-2018)
  #5
Old 08-19-2018, 08:28 AM
portgrinder portgrinder is online now
Currently: Not set.
portgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond repute
Default
back in the day when i was a sledder, the folks on here pedaling products called them siezeco's. were they that bad...i dont think so. never had an issue with a wiseco when they are set up properly
Anyhoo, i have run the wossners in other applications and they haven't missed a beat. some applications making 40% more torque than stock
if you have a unit you're going to keep around and it has some value, i would use a wossner. if you want to save some cash and are running pretty much stock, maybe try something else.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Skidoo Wossner piston kits Thread Starter — lancelarue Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 03-22-2017 01:17 PM
Thread — Wossner Polaris 800 Pistons Thread Starter — realbass Forum — Polaris: Pro-Ride Replies — 66 Last Post — 01-22-2015 08:01 PM
Thread — Wossner Piston Clearance Thread Starter — tratch2 Forum — Polaris: Pro-Ride Replies — 10 Last Post — 02-21-2014 08:08 AM
Thread — How to replace pistons on 800cfi and run in Wossner drop in piston kit? Thread Starter — Xileh Forum — Polaris: IQ Replies — 4 Last Post — 01-26-2014 12:32 AM
Thread — Wossner Vs. Wiseco Thread Starter — inkstreme_05 Forum — Polaris: Pro-Ride Replies — 20 Last Post — 01-24-2014 08:52 AM
