Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 12-01-2017, 11:10 AM
ColoradoMtnman ColoradoMtnman is offline
Currently: Not set.
Basic Member
ColoradoMtnman has a reputation beyond reputeColoradoMtnman has a reputation beyond reputeColoradoMtnman has a reputation beyond reputeColoradoMtnman has a reputation beyond reputeColoradoMtnman has a reputation beyond reputeColoradoMtnman has a reputation beyond reputeColoradoMtnman has a reputation beyond reputeColoradoMtnman has a reputation beyond reputeColoradoMtnman has a reputation beyond reputeColoradoMtnman has a reputation beyond reputeColoradoMtnman has a reputation beyond repute
Default dragon fuel problems
morning sledders, 05 dragon 900 EFI Jets??
lots of questions used sled wont stay running sled sat 6 seasons trying to get to the injectors and clean the fuel system, bought used and previous owner wont share anything with me. front of sled pipes removed, throttle body, exhaust reeds cracked, going to change filters but cant find injectors yet fuel lines are on bottom of the motor and its like no other sled motors Ive seen. Whats next?? printing a service manual 360pages hope it helps not sure if manual is correct only one I could find online??
Need some advice and manuals for 05RMk dragon 900 166track
and a 04 800Polaris 151 thanks for the help. Newbie learning as I go
fuel tank recall?? should I be concerned? mushroom stops where replaced already..
Rate this post: Yes | No
  #2
Old 12-01-2017, 03:02 PM
Cerialsledder's Avatar
Cerialsledder Cerialsledder is offline
Currently: Flatlanderextraordinaire
SnoWest Badge Maker
Cerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond repute
Garage
Default
Easiest way to get the injectors out is the pull the engine. I haven't been able to figure out an easy way of pulling the injectors without pulling the motor. Sounds like the guy that sold it to you is real friendly....... Lots of great information here on the forum. don't be afraid to ask questions and the search bar up at the top is a very powerful tool.
__________________
The Following User Says Thank You to Cerialsledder For This Useful Post:
ColoradoMtnman (12-05-2017)
  #3
Old 12-04-2017, 03:20 PM
SixtySevenGT's Avatar
SixtySevenGT SixtySevenGT is offline
Currently: Building Sleds
SixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond repute
Default its like no other sled motors Ive seen (yup)
I agree easy way to the injectors is pull motor.
I'd start with removing the fuel Tank / Seat
Which needs to come off to pull the motor the easy way.
You can then see the injectors at least.
Check the fuel Pressure, use an Auto Injection Fuel gage. Use a Car battery power it up -
__________________
"Always Drink Upstream from the Herd"
The Following User Says Thank You to SixtySevenGT For This Useful Post:
Reply
Bookmarks
Tags
fuel, manuals, service
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — iqr problems fuel? Thread Starter — snowrace Forum — Polaris: IQR Replies — 3 Last Post — 05-21-2016 08:28 AM
Thread — Fuel Problems with XM's Thread Starter — Teddysledder Forum — Ski-Doo: XM Sleds Replies — 23 Last Post — 01-18-2016 09:04 AM
Thread — 900 fuel problems Thread Starter — polrmk900 Forum — Polaris: 900 Replies — 100 Last Post — 01-14-2015 07:50 PM
Thread — 08-d8 fuel problems? Thread Starter — POZZY Forum — Polaris Replies — 8 Last Post — 02-02-2009 09:27 PM
Thread — Fuel problems. HELP!!!!! Thread Starter — andy k Forum — Ski-Doo Replies — 0 Last Post — 01-30-2009 05:12 PM
no new posts
