Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 11-28-2017, 01:22 PM
HECKS's Avatar
HECKS HECKS is offline
Currently: Not set.
HECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond repute
Default Holey Moley
Well, this was an interesting find !
Pretty sure I missed installing the top rubber grommet from the stock muffler onto the GGB can when I installed it from day 1. (bottom one was installed) As it looks like it allowed the exhaust pipe support to pull back into the cross member and chewed through the aluminum.
Click image for larger version
ID:	288895   Click image for larger version
ID:	288896   Click image for larger version
__________________
16' Axys 163 x 3 Powder Claw / Jaws Pipe/Can
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to HECKS For This Useful Post:
compound 1300 (04-03-2018)
  #2
Old 11-28-2017, 01:41 PM
TheBreeze's Avatar
TheBreeze TheBreeze is online now
Currently: 850 down!
TheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond repute
Default
Yeah. I had that happen also when I was running a diamond s can on a stock pipe.
__________________
Team Optimator Youtube Channel. Check it out!
http://www.youtube.com/user/madam328?feature=mhum
  #3
Old 11-28-2017, 03:12 PM
damx damx is online now
Currently: Not set.
damx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond repute
Default
I have seen 4 brands of cans with the stock pipe do that.
The Following User Says Thank You to damx For This Useful Post:
EBartling (02-14-2018)
  #4
Old 11-28-2017, 09:23 PM
nomasittinright's Avatar
nomasittinright nomasittinright is offline
Currently: Building the axys
nomasittinright has a reputation beyond reputenomasittinright has a reputation beyond reputenomasittinright has a reputation beyond reputenomasittinright has a reputation beyond reputenomasittinright has a reputation beyond reputenomasittinright has a reputation beyond reputenomasittinright has a reputation beyond reputenomasittinright has a reputation beyond reputenomasittinright has a reputation beyond reputenomasittinright has a reputation beyond reputenomasittinright has a reputation beyond repute
Default
Diamond S started it on mine and the Boondocker sidekick is making it worse
__________________
2016 Polaris AXYS 155 3" BM Fab burly boards & bumpers TKI belt drive Boondocker sidekick Raptor shocks Zbroz 36" arms Rehab wrap
2013 Arctic Cat HCR 38" BM Fab skinny boards steering mod BMP can
  #5
Old 11-28-2017, 09:31 PM
sumtinwong sumtinwong is offline
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
Default
hmmm thanks for the post I have silber on mine and im going to look at it RIGHT NOW!
The Following User Says Thank You to sumtinwong For This Useful Post:
Crazyj700 (02-11-2018)
  #6
Old 11-29-2017, 11:48 AM
Z0600 Z0600 is offline
Currently: Not set.
Basic Member
Z0600 is an unknown quantity at this point
Default Holey Moley
My silber with the old (not sure how old) and the new style loud exhaust allows the pipe to rub on that crossmember slightly. It was worse with the old style though. They said stock sleds do it too. I'll be keeping an eye on mine for sure.
This is with their old style exhaust.
Old exhaust
New exhaust
  #7
Old 02-11-2018, 07:50 PM
Snopro_69 Snopro_69 is offline
Currently: Not set.
Snopro_69 has a reputation beyond reputeSnopro_69 has a reputation beyond reputeSnopro_69 has a reputation beyond reputeSnopro_69 has a reputation beyond reputeSnopro_69 has a reputation beyond reputeSnopro_69 has a reputation beyond reputeSnopro_69 has a reputation beyond reputeSnopro_69 has a reputation beyond reputeSnopro_69 has a reputation beyond reputeSnopro_69 has a reputation beyond reputeSnopro_69 has a reputation beyond repute
Default
Mine with can started it also. . I'm going to weld a Lil plate on those 2 sharp edges of the pipe support and put rubber on it. . That way there's a flat rubber surface on the cross member not those 2 sharp edges.
The Following User Says Thank You to Snopro_69 For This Useful Post:
ZRP Engineering (02-11-2018)
  #8
Old 02-11-2018, 11:12 PM
05rmksteve's Avatar
05rmksteve 05rmksteve is online now
Currently: Putting sleds together
05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute
Default
Noticed mine is also rubbing with a bmp pipe, can and y pipe. Think I'll just wrap the aluminum section that it's rubbing on with an old piece of radiator hose and some adhesive to keep it in place.
  #9
Old 02-12-2018, 02:17 PM
KStrand's Avatar
KStrand KStrand is online now
Currently: Next stop....togwotee
KStrand has a reputation beyond reputeKStrand has a reputation beyond reputeKStrand has a reputation beyond reputeKStrand has a reputation beyond reputeKStrand has a reputation beyond reputeKStrand has a reputation beyond reputeKStrand has a reputation beyond reputeKStrand has a reputation beyond reputeKStrand has a reputation beyond reputeKStrand has a reputation beyond reputeKStrand has a reputation beyond repute
Default
I just cut a couple little chunks out of an old belt and slide them in between with the pipe bracket in the grooves of the belt. Works great.
  #10
Old 02-13-2018, 10:01 AM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is offline
Currently: Waiting for my Polaris 850!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
Default
I have been using thick ribber house over the cross support. Going to clean up the pipe brace to give it some more room.
__________________
Full Throttle Customs
Alaska Silber Turbos Dealer
http://www.silberturbos.com/
  #11
Old 02-13-2018, 08:15 PM
Currently: Not set.
Click Here to Register
  #12
Old 02-15-2018, 10:19 AM
papafinger1's Avatar
papafinger1 papafinger1 is online now
Currently: reasonable man. LOL!
papafinger1 has a reputation beyond reputepapafinger1 has a reputation beyond reputepapafinger1 has a reputation beyond reputepapafinger1 has a reputation beyond reputepapafinger1 has a reputation beyond reputepapafinger1 has a reputation beyond reputepapafinger1 has a reputation beyond reputepapafinger1 has a reputation beyond reputepapafinger1 has a reputation beyond reputepapafinger1 has a reputation beyond reputepapafinger1 has a reputation beyond repute
The Following 3 Users Say Thank You to papafinger1 For This Useful Post:
Madtown (02-15-2018), mountainhorse (04-03-2018), TRS (02-15-2018)
  #13
Old 02-15-2018, 06:31 PM
MN 660 MN 660 is offline
Currently: Not set.
MN 660 has a reputation beyond reputeMN 660 has a reputation beyond reputeMN 660 has a reputation beyond reputeMN 660 has a reputation beyond reputeMN 660 has a reputation beyond reputeMN 660 has a reputation beyond reputeMN 660 has a reputation beyond reputeMN 660 has a reputation beyond reputeMN 660 has a reputation beyond reputeMN 660 has a reputation beyond reputeMN 660 has a reputation beyond repute
The Following User Says Thank You to MN 660 For This Useful Post:
owenbstory (02-22-2018)
  #14
Old 02-15-2018, 06:47 PM
The Following User Says Thank You to papafinger1 For This Useful Post:
AKFULLTHROTTLE (02-16-2018)
  #15
Old 02-20-2018, 01:46 PM
Madtown Madtown is online now
Currently: Riding a AXYS RMK
Madtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond repute
  #16
Old 02-20-2018, 04:27 PM
richracer1's Avatar
richracer1 richracer1 is offline
Currently: Doing the Sidekick Switch
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
  #17
Old 02-20-2018, 11:03 PM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is offline
Currently: Power Clawing the Axys....
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
  #18
Old 02-20-2018, 11:47 PM
icr icr is offline
Currently: on another forum
Basic Member
icr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond repute
  #19
Old 04-02-2018, 05:48 PM
guffy guffy is offline
Currently: Not set.
Basic Member
guffy is an unknown quantity at this point
  #20
Old 04-03-2018, 02:41 PM
HECKS's Avatar
Currently: Not set.
guffy (04-05-2018)
  #21
Old 09-01-2018, 07:48 PM
Colbymh Colbymh is offline
Currently: Staring at my Pro
Colbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond reputeColbymh has a reputation beyond repute
  #22
Old 09-01-2018, 09:48 PM
Currently: Not set.
  #23
Old 09-01-2018, 10:20 PM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — HOLY MOLEY SPAM!!!!! Thread Starter — Scott Forum — Forum Rules & Instructions Replies — 7 Last Post — 10-06-2015 02:57 PM
no new posts
