Upgrade to Premium
Reply
  #1
Old 11-20-2017, 02:41 PM
2013 M1100 Turbo 2013 M1100 Turbo is offline
Currently: Not set.
Basic Member
2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute
Default 17 King Cat Exhaust
Just curious if anyone on here has put an aftermarket exhaust on their King Cat 998 Turbo yet? I am looking at either the GGB Mountain can or the CR Racing straight pipe. I have read around on other forums and hear people say things like "you must get a reflash for a free flowing exhaust to correct for A/F ratios". Both of the exhausts I am looking at say you don't need a reflash on their websites, but then I see stuff like mentioned above. Just checking to see if anyone has some first hand experience with either and what they chose to do.
I emailed Chad at CR Racing and he said during their testing they saw an A/F ratio of 12.2 and down to 11.2 on long pulls.
FWIW, I ran a GGB straight pipe on my M1100 Turbo for a little over a year and it ran amazing.
Rate this post: Yes | No
  #2
Old 11-21-2017, 02:07 AM
Prairie Dog's Avatar
Prairie Dog Prairie Dog is offline
Currently: Not set.
Prairie Dog has a reputation beyond reputePrairie Dog has a reputation beyond reputePrairie Dog has a reputation beyond reputePrairie Dog has a reputation beyond reputePrairie Dog has a reputation beyond reputePrairie Dog has a reputation beyond reputePrairie Dog has a reputation beyond reputePrairie Dog has a reputation beyond reputePrairie Dog has a reputation beyond reputePrairie Dog has a reputation beyond reputePrairie Dog has a reputation beyond repute
Default
I got a CR resonator pipe this year but haven’t put it on yet so not sure what it will be like
__________________
____________________________________________
  #3
Old 11-21-2017, 08:38 AM
8secolds 8secolds is offline
Currently: Not set.
Basic Member
8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute
Default
I have an 18 HC and I would not run a muffler on this sled without a tune. Some say you can some say you cant but the AFR is close to death without a tune. I would get a small tune and muffler as it turns this sled into an animal.
  #4
Old 11-21-2017, 09:47 AM
Currently: Not set.
Basic Member
Default
Quote:
What A/F ratio are you hearing or seeing? From the numbers CR Racing sent me it would be on the rich side.
  #5
Old 11-22-2017, 11:23 AM
Currently: Not set.
Basic Member
Default
If you go over to HardCore Sledder and browse the turbo cat forum you will see all the details on this setup. There is a great deal of info on that site for the turbo cats / Sidewinder. I think even Evo has a blurb on the website on the 998 engine with muffler and no tune.
  #6
Old 11-27-2017, 10:08 AM
Currently: Not set.
Basic Member
Default
I ended up ordering a GGB Mountain Can. I emailed GGB and they indicated only 7 to 10 HP gain. They indicated they also tested up to 10,000 feet with no need for a tune. I think I see how they got away with this. If you look at the pipe entering the "muffler" and the pipe leaving the "muffler" there appears to be a choke down at the exit. This keeps more back pressure in the exhaust versus a complete free flow system.
  #7
Old 12-07-2017, 10:36 AM
Currently: Not set.
Basic Member
Default
Well, I got my GGB Mountain Can installed last weekend. From the scale I had it drops around 8-9 pounds over the stock exhaust. It is noticeably louder at idle, but not quite what my M1100 was with a straight pipe. I have not opened it up yet but am leaving for Cooke next week Thursday and will have a chance to see what it sounds like under some WOT.
One thing on changing out exhausts, you should have a ball end T-50 torx bit to get 2 of the bolts out. I did not have one (only a straight T-50 bit) and ended up using a Vice-grips on them. They came out easy enough with the Vice-grips.
  #8
Old 12-09-2017, 12:12 AM
nw-sickboy nw-sickboy is online now
Currently: Not set.
nw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond repute
Default
I just got the Speedwerx can that you can run without a tune. Are folks ditching the heat shield that mounts on top of the old muffler?
  #9
Old 12-13-2017, 11:08 AM
Currently: Not set.
Basic Member
Default
Quote:
I kept the heat shield in place to help keep the turbo heat away from the plastics. Not sure if it helps that much, but I figured what the heck.
  #10
Old 04-19-2018, 12:33 PM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Default exhaust for 9000 turbo
Here is a good option for you. All stainless steel. 20-25 horsepower gains. Works with stock ecu or aftermarket ecu flashes.
All 16 gauge construction, with top quality welds. Polished and fits great.
http://www.bd-xtreme.com/index.php?i...roller=product
Click image for larger version
Name:	muffler 12-108 9000 turbo.jpg
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Arctic Cat ZR ZL King Cat M 800 900 Sno Stuff Rumble Pack exhaust silencer Thread Starter — 98woody Forum — Pipes/Cans (Swapmeet) Replies — 6 Last Post — 10-21-2013 03:20 AM
Thread — Speedwerx Exhaust Can King Cat or 1m 900 800 Thread Starter — cjbchopper Forum — Pipes/Cans (Swapmeet) Replies — 0 Last Post — 11-19-2012 03:22 PM
Thread — exhaust deflector for king cat ? Thread Starter — 2005 1m Forum — Arctic Cat: 1M Replies — 1 Last Post — 02-21-2011 04:56 PM
Thread — king cat exhaust valves Thread Starter — miner700 Forum — Arctic Cat: 1M Replies — 7 Last Post — 09-29-2008 09:51 PM
Thread — 2004 King Cat Mod--Priced to Sell! (Misc king cat/1M parts for sale also) Thread Starter — Kingt8r Forum — Arctic Cat (Swapmeet) Replies — 7 Last Post — 03-23-2008 05:58 PM
no new posts
