Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 11-20-2017, 12:13 AM
Jugernot Jugernot is offline
Currently: Not set.
Basic Member
Jugernot is an unknown quantity at this point
Default 2003 Mountain Cat 900 with no steering
So, I happened upon a 2003 Arctic Cat Mountain 900 yesterday and long story short... I ended up buying it sight unseen for $500.
I got there today and handlebars were not connected to skis or steering linkage. From the looks of it, it looks like there is a washer/nut missing from the linkage to the bottom of the steering column. If so, how would one get the linkage to connect it up? It's directly under the engine with only around .75" of space to get to it... can I remove the pan under the engine (basically drill out the pop rivets, etc) to access the steering components? I sure hope the engine doesn't need to come out to put a single nut on the linkage?
Here is a video I took showing the two parts disconnected:
https://photos.app.goo.gl/rJhOmgI57jvJu8Xw2
Sorry for terrible angles, but I just can't get a great angle. First part of the video is the steering column moving freely... second part was me moving the ski linkage. There is a hole on far side (you can't see it in video) on the steering column knuckle that has a perfectly size hole for that linkage bolt. Seems to be too convenient not to mate up?
A bit of background on the sled (after I just said long story short above... ). The seller was a landlord who was tired of looking after a ex tenants snowmobile for the past 3 years. She'd been asking him to pick it up and he was blowing her off and basically abandoned it. She said "I just want it gone!" ... I asked if it ran and she said "Yes, my son started last year but noticed oil under the hood, so didn't want to run it long." Sure enough, it had some oil under the hood, but the tank was still full, so I'm guessing the previous owner was just shaky when filling because it seems like it's in decent shape. All fluids are where they should be (coolant, crank case, 2 cycle oil) The crank moves fine and all seems to be in good order other than a broken pull starter cord and steering.
I bought it as a project and figured worse comes to worse, it's seized up and I'd be a be able to do my first bottom to top engine rebuild! So far it does NOT look like it's seized up at all, but the previous owner didn't know how to fix the steering, so just stopped riding it. Hopefully this is a win for me?
Edit: so I'm sure this is the correct connection. Anyone know the size of nut I'd need? Looks very finely threaded... Would a Teflon but be suitable?
Rate this post: Yes | No
  #2
Old 11-20-2017, 10:26 AM
Idcatman3's Avatar
Idcatman3 Idcatman3 is online now
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default
The center bellypan section (#6 below) should come off with just some screws, no rivets. Unless someone put it on wrong...
You can get to that bolt from underneath, may even find the original nut floating around down there. (#16 below)
https://www.countrycat.com/arctic-ca...2003-175/58923
Parts diagram says nut should be 3/8-24 NF.
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
  #3
Old 11-20-2017, 10:38 PM
Currently: Not set.
Basic Member
Default
Sweet. It has definitely been taken off before... as there are 4 normal looking screws in it and the rest of the 20 or so are pop rivets.
Guess I'll start drilling em out and get to work!
EDIT: Ok, so it appears to have a second thicker skid plate attached to the center belly pan. This is the plate that was pop riveted on... I drilled through all rivets and removed all screws in the center bellypan to find exact what I needed and as you described Idcatman3. Just need to buy a nut tomorrow and I should be good to go! Any reason I can't use a teflon nut? From what I can tell the factory nuts are sort of... crimped on. I guess teflon is better than nothing.
  #4
Old 11-21-2017, 02:21 PM
sprockethead's Avatar
sprockethead sprockethead is online now
Currently: Not set.
sprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond repute
Default
If you're talking about a self-locking Teflon nut you should be ok. The Arctic Cat nut is self-locking too, just a different type.
  #5
Old 11-21-2017, 11:52 PM
Currently: Not set.
Basic Member
Default
Quote:
Yep, nylon locking nut. I put one on tonight and it seems like it'll work just fine. I was worried about the height of the nut and whether it was going to grip the threads (as they are fairly short). I did in fact find the factory nut, but didn't want to put it back on as it's already come off once.
I'm thinking now that I should have probably put some thread sealant on them... perhaps a red to make sure it doesn't back off again.
Thanks for the help.
  #6
Old 12-11-2017, 01:08 PM
Chief3Jeeps Chief3Jeeps is offline
Currently: Not set.
Basic Member
Chief3Jeeps is an unknown quantity at this point
Garage
Default Steering
You may want to use self tappers upon reassembly... I have to tighten up that steering nut annually as it will loosen with aggressive riding and yanking on the steering stem... Good Luck! Awesome sleds.
  #7
Old 01-09-2018, 08:13 PM
Currently: Not set.
Basic Member
Default
Quote:
I ended up putting locktite red with nylon locking nut on it. Haven't had a chance to take it out yet, but hoping it'll be fine. I'll take off the skid plates next summer and check it out.
Thanks!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2003-900 mountain cat,2004-900 king cat Thread Starter — joemama Forum — Arctic Cat (Swapmeet) Replies — 2 Last Post — 11-24-2012 11:37 AM
Thread — Mountain Cat 600/800/900 Steering post Thread Starter — RACINSTATION Forum — Handlebars/Risers (Swapmeet) Replies — 0 Last Post — 02-02-2012 10:00 AM
Thread — 2003 Arctic Cat Mountain Cat 900 151" Thread Starter — texasranger556 Forum — Arctic Cat (Swapmeet) Replies — 6 Last Post — 05-09-2010 10:55 PM
Thread — Need a 2003 Mountain Cat hood, windshield, steering post Thread Starter — texasranger556 Forum — WTB (Swapmeet) Replies — 2 Last Post — 10-26-2008 09:30 PM
no new posts
