Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 11-17-2017, 09:08 PM
indyseven indyseven is offline
Currently: Not set.
Basic Member
indyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond reputeindyseven has a reputation beyond repute
Default LED Head Light Help
Hi guys, I know this question has probable been asked several times but I cant seem to find the right information I need. I want to put a LED head light on my custom built mountain sled but the stator only puts out AC voltage. I have installed a full wave bridge rectifier right at the headlight but I keep burning out the LED with high engine RPM. I thought that maybe i have a bad voltage regulator but the tach light doesn't seem to burn out (this is the only other bulb on the sled). what else do I need to do, constantly burning LED headlights out is getting costly. Any help is full appreciated guys!
Rate this post: Yes | No
  #2
Old 11-18-2017, 09:01 PM
Rosslbz Rosslbz is offline
Currently: Not set.
Rosslbz has a reputation beyond reputeRosslbz has a reputation beyond reputeRosslbz has a reputation beyond reputeRosslbz has a reputation beyond reputeRosslbz has a reputation beyond reputeRosslbz has a reputation beyond reputeRosslbz has a reputation beyond reputeRosslbz has a reputation beyond reputeRosslbz has a reputation beyond reputeRosslbz has a reputation beyond reputeRosslbz has a reputation beyond repute
Default
Must be from voltage spike at high rpm, you will need a resistor in-line. The resistor will have to be sized according to your led voltage input limit.
  #3
Old 11-22-2017, 07:45 AM
Currently: Not set.
Basic Member
Default
Bump
  #4
Old 11-22-2017, 01:17 PM
johnsodo johnsodo is offline
Currently: rip snowest
Basic Member
johnsodo has a reputation beyond reputejohnsodo has a reputation beyond reputejohnsodo has a reputation beyond reputejohnsodo has a reputation beyond reputejohnsodo has a reputation beyond reputejohnsodo has a reputation beyond reputejohnsodo has a reputation beyond reputejohnsodo has a reputation beyond reputejohnsodo has a reputation beyond reputejohnsodo has a reputation beyond reputejohnsodo has a reputation beyond repute
Default
use a cat regulator
  #5
Old 11-23-2017, 06:58 AM
Currently: Not set.
Basic Member
Default
Do you happen to know what Cat reg to use and the wiring process?
  #6
Old 11-23-2017, 12:19 PM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
Default
Did you remove the factory(incandescent) headlight when you installed the LED light?
If so, unless you installed a resistor(or similar load to the headlight) the voltage regulator will not likely be able to "burn off" the excess current & the resulting voltage may be too high for the LED light.
That said, I'm not sure why the other lights are still OK(haven't burned out)?
  #7
Old 11-23-2017, 02:12 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Default
You may have burnt out your voltage regulator from the low load already.... as stated above... you will need a 100W load (true 100W) or the regulator will not work well.
LED's are a challenge in the sleds.... some state that they have had luck... while the majority have had to jump through hoops to use them.
What is the Voltage input spec on the LED's you bought?
Are you using the kind with the fan on them... or the ones with the ribbon heat sinks (best)??
A load resistor would be best ... make sure you use a wire wound, aluminum heat sink'd resistor... in the 2-ohm range... 100W rating min. ... and you will need to attach it to the bulkhead in a way that transfers heat from the resistor to the chassis well.
Good luck.
__________________
Signature:
  #8
Old 11-24-2017, 06:55 PM
Currently: Not set.
Basic Member
Default
Thanks for the help guys. I purchased a new Arctic Cat 2 wire voltage Regulator today as I have read this is the way to go as far as voltage regs are concerned. One question I have is that the regulator with two wires replaces one with only one wire. Do I only hook up the yellow wire to it like factory Polaris or both yellow and brown from the stator. Also thanks Mountain Horse for the info on the resistor! i didn't know that the system wont work properly without load on it all the time. I have also read that a capacitor on the DC side of the full wave bridge rectifier will help smooth out the voltage and help with the flickering effect. Just not quite sure what size mf capacitor I would need to go with. If anyone has any suggestions based on what has worked for them I would truly appreciate it.
Thanks again for the help :0)
  #9
Old 11-26-2017, 01:57 AM
Currently: Not set.
Basic Member
Default
Bump
  #10
Old 11-28-2017, 12:10 AM
Currently: Not set.
Basic Member
  #11
Old 11-28-2017, 05:23 AM
Merlin's Avatar
Click Here to Register
Reply
Bookmarks
Tags
ac only, full wave bridge, led headlight, no dc
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 120 LED Head light Conversion Thread Starter — thumper450 Forum — Youth Sleds Replies — 2 Last Post — 10-14-2017 03:59 AM
Thread — LED light kits.... Thread Starter — kevinm7 Forum — General Snowmobiling Replies — 7 Last Post — 11-17-2015 02:37 PM
Thread — Led tail light Thread Starter — hockey10 Forum — Ski-Doo: REV Sleds Replies — 3 Last Post — 01-24-2013 11:14 PM
Thread — new LED head light o xp? Thread Starter — bullseye88 Forum — Ski-Doo: XP Sleds Replies — 6 Last Post — 12-19-2012 06:42 AM
Thread — LED Tail light? Thread Starter — Heypal Forum — Arctic Cat: M Series Replies — 3 Last Post — 11-03-2009 06:11 PM
no new posts
