Upgrade to Premium
Member Sled Builds A forum for building a project or mod sled.... Not just your common "Mods", but full on sled build projects.
Reply
  #1
Old 11-13-2017, 11:39 PM
brokenbones4 brokenbones4 is offline
Currently: Not set.
Basic Member
brokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond repute
Default Carbon fiber 1100 turbo
This spring I picked up 2013 1100 turbo, it is my first four stroke but I thought it would be a fun project, and something new to learn about. I have always owned skidoo's so I had a lot of reading to do about the cat. The sled came with a speedwerx multi tune, head studs, intake and had the factory updates done like the big fin secondary. I bought the c3 carbon tunnel fuel tank,and hood from a guy who was parting out his m8. From there it was a never ending shopping list of parts. First thing was the tear down. I liked the way the tunnel was just bolted to the bulk head. Made for an easy removal. When fitting the carbon tunnel there was a couple issues I ran into. The tunnel was designed for the m8 which has a different tcl, and the tab where the 1100 motor mount bolted could not be used. I had to cut the motor mount off of the 1100 tcl to have clearance. I ordered the osp brace to secure the motor in position and built my own engine snubber. The coolant lines where cut routed to the c3 heated boards. I installed the c3 belt drive which came with an upgraded jack shaft and new motor mount bushings. I could not believe the amount of parts I took out of the chain case! I added the heavy duty spring to the skid shock and gave the suspension a coat of white paint to match the tunnel.
Sent from my HTC One M9 using Tapatalk
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to brokenbones4 For This Useful Post:
Clark42 (04-03-2018), joshkoltes (11-14-2017), Reeb (03-25-2018), Snowmixer (11-14-2017)
  #2
Old 11-14-2017, 01:33 PM
Snowmixer Snowmixer is offline
Currently: Not set.
Snowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond repute
Smile
Looks like it has come a long way! How close is it to being ready to ride?
  #3
Old 11-14-2017, 01:52 PM
Currently: Not set.
Basic Member
Default
The new tunnel has more clearance with the front heat exchanger gone so the belly pan had do be trimmed. Lots of room for a new track. The hardest part of this build was cutting up the hood, again it was for the m8 so it needed holes for the intake and intercooler. I found a used set of black vented side panels which looked much better. Next I made a 2.5" stainless exhaust pipe. Much more room under the hood. I welded a piece of aluminum around the intercooler with some weather stripping to seal to the hood. Now all the are is forced through for better cooling. I upgraded to the 2016 front end and had my shocks shortened. I lowered the bars an inch with a new 3.5" riser. Made a new battery box to hold a 16 cell anti gravity battery. Only 3.4lbs. Went with the bdx lightweight seat. Now just need to hook up a boost gauge. And install a snow flap. Lots of custom parts made or modified to make it work. Putting aftermarket parts on other aftermarket parts doesn't always work.
5 out of 5 members found this post helpful. Rate this post: Yes | No
The Following 5 Users Say Thank You to brokenbones4 For This Useful Post:
Clark42 (04-03-2018), ReaperMotorsports (11-21-2017), Reeb (03-25-2018), Snowmixer (11-14-2017), Solby (12-20-2017)
  #4
Old 11-14-2017, 02:26 PM
boondocker97 boondocker97 is online now
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
Nice work!
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
The Following User Says Thank You to boondocker97 For This Useful Post:
brokenbones4 (11-14-2017)
  #5
Old 11-14-2017, 07:11 PM
Currently: Not set.
Basic Member
Default
One important note for anyone with an 1100. While working on the sled I noticed the wiring harness was tacky and oily looking. I just thought the sled had been rolled and oil had leaked out at some point. But the first time I started the sled after it was complete I noticed fuel dripping. I shut the sled off and looked for a loose clamp I might have forgotten. After a close inspection when I turned the key and the fuel pump pressured up I saw bubbles forming on the fuel pressure regulator. The fpr is crimped in the center holding the two halves together. That is where the leak was coming from. So I removed it and put it in the vice, crimping it tighter all the way around. Problem solved. So it turns out the adhesive from the tape dissolved because of gas being sprayed around. Would explain why so many 1100's caught fire.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to brokenbones4 For This Useful Post:
Scott (11-14-2017)
  #6
Old 11-14-2017, 08:06 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
Did I miss it? How much weight did you take off of it?
__________________
OEM parts from Free Agent
Ambassador for:
FB & IG: Scott Stiegler
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Check out these cool products:
  #7
Old 11-14-2017, 08:12 PM
Currently: Not set.
Basic Member
Default
This was with no fuel but have changed some parts since then. I will get more accurate finished weights soon and a wet weight.
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to brokenbones4 For This Useful Post:
justinkredible56 (12-13-2017), ReaperMotorsports (11-21-2017), Scott (11-14-2017)
  #8
Old 11-15-2017, 05:46 AM
d1100t's Avatar
d1100t d1100t is online now
Currently: Looking forward to the first ride on my 2018 M 800 CTEC
d1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond repute
Default Custom build
That's a lot of work!!!
Good job!
The Following 2 Users Say Thank You to d1100t For This Useful Post:
bigrig (11-15-2017), brokenbones4 (11-15-2017)
  #9
Old 03-17-2018, 11:11 AM
Matte Murder Matte Murder is online now
Currently: Resisting the urge to screw with people...
Matte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond repute
Default
I have an 1100T and I bought the C3 CF hood direct from them. It looks EXACTLY LIKE THE HOOD YOU HAVE. I wonder what’s different, just the mounts?
  #10
Old 03-18-2018, 10:35 AM
Currently: Not set.
Basic Member
  #11
Old 03-28-2018, 08:37 PM
Reeb's Avatar
Reeb Reeb is online now
Currently: Restoring my old race sleds....
Reeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond repute
Garage
Click Here to Register
The Following User Says Thank You to Reeb For This Useful Post:
brokenbones4 (03-30-2018)
  #12
Old 03-30-2018, 01:30 PM
Currently: Not set.
Basic Member
Reeb (03-30-2018)
  #13
Old 04-05-2018, 07:28 AM
kinger9 kinger9 is online now
Currently: Waiting for SNOW!
kinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond repute
  #14
Old 06-15-2018, 02:45 PM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Carbon Fiber king cat Turbo 3200 Thread Starter — mmsports Forum — Arctic Cat (Swapmeet) Replies — 9 Last Post — 03-20-2014 09:58 AM
Thread — Turbo 1200 Carbon Fiber chassis Thread Starter — powderlites Forum — Ski-Doo: TURBO Replies — 26 Last Post — 12-16-2009 09:27 AM
Thread — Carbon or fiber Turbo reed Thread Starter — brycter Forum — Ski-Doo: TURBO Replies — 12 Last Post — 11-30-2009 12:24 AM
Thread — WOW! '09 Dragon w/ Turbo & Carbon Fiber Thread Starter — C&C Sales Forum — Polaris (Swapmeet) Replies — 0 Last Post — 03-13-2009 01:13 PM
Thread — rx1 turbo hood black carbon fiber Thread Starter — vector_turbo Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 0 Last Post — 01-01-2008 02:02 PM
no new posts
