Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 10-17-2017, 06:04 PM
trussell456 trussell456 is offline
Currently: Not set.
Basic Member
trussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond reputetrussell456 has a reputation beyond repute
Default 98 RMK Reverse Question
got a 98 rmk with the reverse lever on the right handlebar. Putting it in reverse works perfectly, but when you flip the lever back it stays in reverse. But once i shut it off and start it back up its in forward. Seems odd as the reverse engages perfectly every time. Any help would be appreciated
Rate this post: Yes | No
  #2
Old 10-24-2017, 09:59 PM
sled_guy's Avatar
sled_guy sled_guy is offline
Currently: In limbo
sled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond repute
Default
That's the mechanical reverse. When you flip the lever it compresses the spring in the chaincase and moves the gear. When you flip it back to disengage reverse the spring is supposed to push the gears back into forward. I'm betting you have a tight belt that is holding pressure on the driven clutch and putting a little bind on the gears keeping them from releasing with the spring. When you shut it off, the pressure is gone and then they pop back into forward position.
That's my guess.
Might be worth pulling the chaincase cover off and making sure everything is clean and then putting in fresh lube.
sled_guy
__________________
"Sorry, I thought you could ride"
2 out of 2 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Reverse question on 08 800 Thread Starter — bradyjay88 Forum — Polaris: IQ Replies — 3 Last Post — 11-13-2015 04:45 PM
Thread — secondary reverse question? Thread Starter — summ8rmk Forum — Polaris: Pro-Ride Replies — 13 Last Post — 02-22-2012 10:48 AM
Thread — Reverse question Thread Starter — SpencerA Forum — Polaris: GEN 1 and older Replies — 2 Last Post — 01-21-2012 04:25 PM
Thread — 08 reverse question? Thread Starter — harf69 Forum — Arctic Cat: M Series Replies — 6 Last Post — 04-21-2011 08:50 AM
Thread — Perc reverse question?? Thread Starter — fastlane Forum — Polaris Replies — 6 Last Post — 12-13-2008 03:17 AM
no new posts
