Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 10-12-2017, 08:45 PM
KingofPaint KingofPaint is offline
Currently: Not set.
Basic Member
KingofPaint is an unknown quantity at this point
Default 2006 700 rebuild questions
Ok, I have an 06 700 that is blown up. Are there oversized pistons if I need to bore the cylinder? I haven't found any but I could be looking in the wrong spot.
Joe
Rate this post: Yes | No
  #2
Old 10-13-2017, 05:21 PM
Cerialsledder's Avatar
Cerialsledder Cerialsledder is offline
Currently: Flatlanderextraordinaire
SnoWest Badge Maker
Cerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond repute
Garage
Default
Carl's cycle use to make a Big bore kit for the 900 that made it a 975. I'm not sure if they produced one for the 700 or not. Might try googling carl's cycle big bore kit fusion 700 and see if that turns anything up
__________________
  #3
Old 10-16-2017, 10:14 PM
Currently: Not set.
Basic Member
Default
So it appears that I need to replace the cylinders with reconditioned ones. The best deal I have found is $245.00 a piece from US Chrome. Does anyone know of a better deal?
Also
This engine got hot...melty hot. Its sister sled which I also have has 675 miles on it so I will guess The 700 had that before it was ran without oil.
Is it possible the crank survived and what am I inspecting for?
Thanks
Joe
  #4
Old 10-19-2017, 10:08 PM
Currently: Not set.
Basic Member
Default
OK,
If your following this, Cylinders look good, small scuff on both pistons below ring land ex/int/front side. I am going to replace the rings, clean up the ports and bolt it back together after inspecting the crank although it seems solid. It seems to have got so hot because the impeller on the water pump gave up. The water pump housing was also "torn". It appears to have been run without water until gasket failure. If the 700's overheat like the 900's then the problem is most likely over heating not oil starvation. Both sleds I got failed at the same time while riding together so my guess is 10 miles on an icy trail.
Joe
  #5
Old 10-20-2017, 04:35 AM
SnoWest Badge Maker
Garage
Default
Quote:
Originally Posted by KingofPaint View Post
OK,
Joe
Sounds like whoever had the sled never did the radiator delete or they never ran the radiator and rear cooler in a series. That was the worst setup I have seen Polaris do because the coolant is going to flow down the path of least resistance and most of the time it ends up not flowing to where you are going to get the best cooling. I would talk the radiator and run scratches or run the rad and rear cooker in a series
Sent from my HTC on Tapatalk
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — FRONT SUSPENSION/STEERING REBUILD ON 2006 2500HD D-MAX QUESTIONS Thread Starter — mountainhorse Forum — Trucks and Trailers Replies — 16 Last Post — 12-07-2016 01:55 PM
Thread — 2006 700 rmk questions Thread Starter — jpline Forum — Polaris: IQ Replies — 2 Last Post — 01-07-2015 01:01 PM
Thread — Liberty 700 twin top end rebuild questions Thread Starter — dustball27 Forum — Polaris: EDGE Replies — 2 Last Post — 01-14-2013 10:43 PM
Thread — Rebuilding 2006 700 Rmk Motor I have a few questions Thread Starter — markdvorak Forum — Polaris Replies — 12 Last Post — 03-12-2009 10:40 PM
Thread — Rebuild Questions Thread Starter — specialk6r Forum — Arctic Cat Replies — 6 Last Post — 04-20-2008 12:32 AM
