Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 09-29-2017, 01:32 PM
Ethan Endres Ethan Endres is offline
Currently: Not set.
Basic Member
Ethan Endres is an unknown quantity at this point
Default Polaris Skis Fit all Polaris? Polaris RXL
Hi, I recently purchased a 1991 Polaris 650 RXL SKS, I was wondering if all Polaris skis are compatible with this sled because i am wanting to upgrade to plastic. Any other ideas on how to lighten this specific sled without investing too much would be great too, also its an old EFI so it has a battery even though its not an electric start.
Rate this post: Yes | No
  #2
Old 09-30-2017, 07:07 AM
volcano buster volcano buster is offline
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default
I bolted Polaris plastic skis to my '93 440 and '94 Indy Lite so your RXL should be similar.
  #3
Old 10-01-2017, 10:06 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
if the hood is the old fiberglass, you can put a newer plastic blend on and the nosecone (lighter). stay away from 97-98 domestic twin hoods those suck (brittle). take out the useless gauges and speedo cable and toss those in the garbage. i like to toss the whole headlight assembly. if you can do that without messing with the intake, bingo, next take the steel front hinges and mounting hardware off and re-locate those to the garbage can. find a lighter tie down method. i use edge hood straps frenched into the nosecone that stretch to a tab on the hood right where the stock hinges used to go. works great. just toss hood off to side easily when you need access, like all the new sleds.
remove swaybar unless you trail ride a lot.
look at your hyfax wear and see if theres some bogies you could do without.
love those RXLs!
  #4
Old 11-24-2017, 10:31 AM
VTMTcowboy VTMTcowboy is offline
Currently: Not set.
VTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond reputeVTMTcowboy has a reputation beyond repute
Default
I bolted a pair of Sidehiller 2 skis onto my 90 Indy 500 a few years back and worked well. I think the biggest limitation is the suspension as there aren't too many options left for the old Indy's. I know a few companies used to make some carbon fiber hoods and trailing arms back in the day. Those parts got to be available through forums, eBay, or Craigslist. Its cool to see others keeping the Indy chassis alive! Good luck.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — polaris rxl 700 Thread Starter — black magic Forum — Polaris: GEN 1 and older Replies — 3 Last Post — 06-27-2011 12:25 PM
Thread — polaris RXL Thread Starter — skidcat Forum — Parts/Accessories Replies — 1 Last Post — 12-18-2010 03:44 PM
Thread — WTB Polaris skis to fit 04 switchback. Thread Starter — JONESIE Forum — Skis (Swapmeet) Replies — 0 Last Post — 01-05-2009 11:09 AM
Thread — Powder skis that will fit my 01 Polaris XC700 edge Thread Starter — mifun3 Forum — Skis (Swapmeet) Replies — 0 Last Post — 10-03-2008 09:07 AM
Thread — Looking for help on old polaris indys(92 RXL) Thread Starter — red Forum — General Snowmobiling Replies — 2 Last Post — 01-17-2008 07:32 AM
no new posts
