Upgrade to Premium
Reply
  #1
Old 09-10-2017, 06:01 PM
m-ervin m-ervin is offline
Currently: Not set.
Basic Member
m-ervin has a reputation beyond reputem-ervin has a reputation beyond reputem-ervin has a reputation beyond reputem-ervin has a reputation beyond reputem-ervin has a reputation beyond reputem-ervin has a reputation beyond reputem-ervin has a reputation beyond reputem-ervin has a reputation beyond reputem-ervin has a reputation beyond reputem-ervin has a reputation beyond reputem-ervin has a reputation beyond repute
Default CFR Boondocker bars
Looking at the CFR Boondocker 2.0 bars for my 12 XF Turbo with the vertical steering. Any one add these bars? I want to keep my factory controls, and I like the new smaller feeling Cat gripes/heaters/ect. Basically I just want a turn key set of bars with out much issues. Any tips? I've read fill the bars with foam?
Thanks
Rate this post: Yes | No
  #2
Old 09-20-2017, 01:34 PM
0neoldfart 0neoldfart is online now
Currently: rigging instad of riding
0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute
Default Not sure...
Quote:
Thanks
I have a set of CFR bars on my M1100T. But not sure if there is enough area for all of the OEM garbage on the control surface area. I stripped mine down, just have an aluminum throttle block, grips, and brake lever. Filling the bars with foam will help keep some heat, as aluminum bars will rob heat from the elements quickly. I never did, just used RSI grips & heaters.
Probably cheaper to just buy a set of the accessory bars in the catalog, and a ton less work.
  #3
Old 09-20-2017, 04:33 PM
boondocker97 boondocker97 is offline
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
All the photos I've seen of the CFR bars on Cats with stock controls have the brake master cylinder mounted on the bar where the curve starts down. CFR bars are 1-1/8" clamp with a drop on them. So if you're looking for a straight replacement they won't work with your stock 7/8 clamp and riser height (the 1100 vertical steering isn't telescopic, right?). Unless the ends of your bars are open, putting foam on the inside of the bars for grip heater insulation is not going to help much as it is already a closed air space. You have to insulate between the bar and the element as that is where the heat transfer problem occurs. Heat is sucked through the aluminum and transferred to the outside air on exposed surfaces of the bar. Unfortunately that increases the grip diameter.
https://www.snowest.com/forum/showthread.php?t=435025
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
  #4
Old 10-04-2017, 08:05 PM
RACINSTATION's Avatar
RACINSTATION RACINSTATION is offline
Currently: Working too much
RACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond repute
Default
You can use a Rox riser to adapt from the stock post to the CFR bars. If you need help we should have everything you need.
__________________
The Racin Station
60 South 1st Street Driggs, Idaho 83422
Ph: 208-354-2777 E-Mail: racinstation@hotmail.com
The Racin Station is your TURBO MOD HEADQUARTERS
for Arctic Cat Proclimb 8000/1100 and Yamaha Vipers and Sidewinders!
TIMBERSLED FULL LINE DEALER!!!
Proclimb Carbon Fiber Vents
Your MDS weight headquarters
Team ProClimb secondary complete setups ready!
Reman M6,M7,M8 and M1000 cylinders in stock.
Jaws M8 Singles for the 2012-2017 in stock!
Jacobsen Rollover valves in stock for M1100Turbo and Viper/M7000!!
Camoplast 3" and 3.2" 174, 162 and 156 x15 tracks on hand now
  #5
Old 10-11-2017, 05:50 PM
Currently: Not set.
Basic Member
Default
Thanks for the response guys. I ended up going Cole Willford 252 bars. Thanks to Sled Solutions for the setup.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — CFR Bars Thread Starter — Snow4life Forum — Ski-Doo: REV Gen 4 Replies — 8 Last Post — 08-15-2017 03:05 AM
Thread — CFR Boondocker 2.0 Bars Thread Starter — RACINSTATION Forum — Handlebars/Risers (Swapmeet) Replies — 3 Last Post — 09-11-2016 12:03 PM
Thread — CFR bars and stock grips Thread Starter — catothom Forum — Arctic Cat: Proclimb M Replies — 3 Last Post — 12-21-2015 08:07 AM
Thread — Swap CFR Ski Rack for CFR Board Rack Thread Starter — Publiconion Forum — Misc. Snowmobile (Swapmeet) Replies — 0 Last Post — 08-03-2014 07:19 PM
Thread — difference between Dan Adams fly bars and Burandt's rsi bars? Thread Starter — vdog0531 Forum — Polaris: Pro-Ride Replies — 55 Last Post — 01-15-2013 05:14 PM
no new posts
