Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 09-06-2017, 10:46 PM
EOsnownut EOsnownut is offline
Currently: Not set.
Basic Member
EOsnownut is an unknown quantity at this point
Default 04' 900 1M chain case help
Hi all, ill start by saying I'm relatively new to sleds I've only been riding one season. I'm looking at a 2004 MC900 1M 159", a massive upgrade from last seasons Indy 500 LC 136".
So the guy I'm buying it from has said it seemed to be skipping teeth in the chain case due to running it dry last season and heating it up. He replaced the chain and the issue went away, but has since re surfaced.
I have photos of both the upper and lower gear/sprocket.
1st question, is that a logical scenario?
2nd, could there be something else causing the skipping, if so, what?
3rd, how difficult is it to replace the gears and chain?
4th, what gearing and chain should I go with if my riding style/area is mostly low elevation off trail riding?
Any advice or opinions would be extremely appreciated!
Hoping to get a hold of this sled for $900, which seems like a good price but I have no idea being new to sleds.
Thanks in advance for any info!
Rate this post: Yes | No
  #2
Old 09-07-2017, 07:49 AM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
flip it on the side and check the drive shaft bearings on each end of the shaft. I have had more then one go bad.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to kiliki For This Useful Post:
clutch (09-07-2017), Idcatman3 (09-07-2017)
  #3
Old 09-07-2017, 10:34 AM
Readymedic's Avatar
Readymedic Readymedic is offline
Currently: How is 18/19 lookn'??
Readymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond repute
Default
The drive bearings do go, but they are a simple fix.
Definitely needs new gears and and don't forget the oil. If he ran it dry, he was either an idiot or the gasket on the chain case cover leaks. Look for the fine rubber gasket. It's simply an O ring but a big one.
900 would be a good price as long as the engine is good. Make sure you do a compression test!!
  #4
Old 09-07-2017, 05:01 PM
Currently: Not set.
Basic Member
Default
Thanks for the responses, didn't expect to see any that quick!
Yeah Idk how he ran it dry but thats what he claimed to have done.
He says he replaced the rear axle, if thats of significance.
Can anyone tell me the part numbers for the chain case gears and chain?
I've read 18/40 70P is a good setup, but I'm okay with just putting stock back in there though. I'm open to suggestions too!
I do alot of deep powder hill climbing and back country riding locally. We're expecting 3+ft this season like last season.
  #5
Old 09-07-2017, 05:43 PM
Idcatman3's Avatar
Idcatman3 Idcatman3 is online now
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default
Good place for looking up part numbers:
https://www.countrycat.com/arctic-cat-parts
https://www.countrycat.com/arctic-ca...%7c%7e0738-939
26 1602-394 Sprocket - 43T
26 0602-453 Sprocket, 40T (Above 4,000 ft Alt.)
32 0602-973 Sprocket - 19T
23 0602-972 Chain - 72P
23 0602-968 Chain - 70P
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
The Following User Says Thank You to Idcatman3 For This Useful Post:
EOsnownut (09-07-2017)
  #6
Old 09-07-2017, 07:57 PM
Currently: Not set.
Basic Member
Default
So im assuming I'll want the 43 and 19, what chain? 72?
How difficult is the gear change?
Never been inside a chain drive before.
  #7
Old 09-08-2017, 08:44 AM
Idcatman3's Avatar
Currently: Not set.
Garage
Default
If I'm remembering correctly, that's right, the 72P chain. If you go down to the 40T lower sprocket, that's when you need the 70P chain. Changing stuff isn't too tough, just pay attention to how you take it apart, and put it back together the same way.
service manual with instructions is here:
https://support.countrycat.com/posts...service-manual
page 8-47 is where the chaincase without reverse is talked about.
__________________
EOsnownut (09-08-2017)
  #8
Old 09-08-2017, 08:52 AM
Currently: Not set.
Garage
Default
19/43 is a good stock set up do not go smaller than a 19 top gear. pay attention to the lower gear as it can be put in wrong. the gear has a larger offset on one side and this faces in. very basic set up i put the auto tension components in the trash an just use the jamb nut to take up the slack. only go finger tight on the bolt that takes up the slack.
  #9
Old 09-18-2017, 07:34 AM
sprockethead's Avatar
sprockethead sprockethead is offline
Currently: Not set.
sprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond repute
Default
The SnoPro racers run there sleds with no chaincase oil. Don't want the drag that the oil creates. They only run the sled for a short time and do heavy maintenance on there sleds after every race. Maybe this knuckle head had heard this and decided to do this with his sled. Not a good idea for a sled that is ridden hard for a day at a time. I would for sure change out the driveshaft bearing (lower one) and maybe even the jackshaft bearing (top one) depending on how it feels. If the driveshaft bearing is bad what you hear ratcheting my be the drivers on the track. The lower bearing does go bad if left neglected and can do damage to your sleds tunnel also. Good luck!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — WTB Tison Extended Chain case or Other long chain case Thread Starter — starfire Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 2 Last Post — 04-11-2011 05:45 AM
Thread — 900 Chain Case Thread Starter — hal8088 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 12-15-2010 12:39 PM
Thread — 03 900 1M Chain case cover Thread Starter — franny Forum — Arctic Cat Replies — 8 Last Post — 03-04-2009 01:29 PM
Thread — '06 900 RMK Chain case, gears, chain, and Brake Assembly Thread Starter — billg Forum — Misc. Sled Parts Replies — 2 Last Post — 01-06-2009 10:01 PM
Thread — Help, 900 RMK Chain Case Thread Starter — RMK900204 Forum — Polaris Replies — 16 Last Post — 12-30-2008 08:43 PM
