Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 09-03-2017, 11:16 PM
Logan_Martin27 Logan_Martin27 is offline
Currently: Not set.
Basic Member
Logan_Martin27 is an unknown quantity at this point
Default Xc Sp 700 Backfiring Problems
Hey Guys,
My 99 Polaris Xc Sp 700 has a backfiring problem. I have cleaned the carbs and I have also replaced the reeds because they were bad and I read that bad reeds could contributed to a backfiring problem. The new reeds helped a little but it still backfires when idling and at take off. What could it be?
Thanks
Rate this post: Yes | No
  #2
Old 09-04-2017, 07:58 PM
minus40 minus40 is online now
Currently: tinkering
minus40 has a reputation beyond reputeminus40 has a reputation beyond reputeminus40 has a reputation beyond reputeminus40 has a reputation beyond reputeminus40 has a reputation beyond reputeminus40 has a reputation beyond reputeminus40 has a reputation beyond reputeminus40 has a reputation beyond reputeminus40 has a reputation beyond reputeminus40 has a reputation beyond reputeminus40 has a reputation beyond repute
Default
If it's popping in the carbs it's lean. Up the pilot or adjust the fuel screw. Keihin carbs are notorious for this. I used to adjust damn near daily. A neat trick was to use a welding rod, clean off the flux and hammer a flat end in it for a long screwdriver and store in the hood foam
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 09-04-2017, 08:12 PM
omernikski's Avatar
omernikski omernikski is offline
Currently: On Snowest
omernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond reputeomernikski has a reputation beyond repute
Garage
Default
Does it backfire after its at operating temp?
__________________
Nccco certified
  #4
Old 09-05-2017, 07:59 PM
Currently: Not set.
Basic Member
Default
It is actually running a little rich to be honest.
And it still backfires at idle even after riding for a while.
  #5
Old 09-07-2017, 06:51 PM
omernikski's Avatar
Garage
Default
Did you make sure you could see light through your pilot jets? Sounds like you may have partially plugged jets
__________________
Nccco certified
  #6
Old 09-07-2017, 10:40 PM
Currently: Not set.
Basic Member
Default
Yes I did. I cleaned my main and pilot jets very well. Do you think if my fuel/air mixture is off, if that could potentially be the problem?
  #7
Old 09-08-2017, 08:34 AM
omernikski's Avatar
Garage
Default
I just completely rebuilt the kehins on my 98. I think the fuel air screw is set at 1.5 turns. I'll verify it today. I also had backfiring at an idle till I syphoned out the old fuel and put fresh gas in
__________________
Nccco certified
0 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to omernikski For This Useful Post:
Logan_Martin27 (09-08-2017)
  #8
Old 09-08-2017, 09:06 PM
Currently: Not set.
Basic Member
Default
I just set the fuel/air screw to 1.5 turns today and that helped a lot. I have an exhaust leak so when I fix that, hopefully tomorrow, the backfiring should stop. Thanks for your feedback.
  #9
Old 09-09-2017, 07:38 PM
omernikski's Avatar
Garage
Default
Right on. Yeah the screws are at 1.5 turns. Once the temp drops more it should act better
__________________
Nccco certified
Logan_Martin27 (09-09-2017)
  #10
Old 09-09-2017, 09:02 PM
Currently: Not set.
Basic Member
  #11
Old 10-10-2017, 06:54 PM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 10-11-2017, 07:50 PM
retiredpop retiredpop is online now
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
The Following User Says Thank You to retiredpop For This Useful Post:
Logan_Martin27 (10-27-2017)
  #13
Old 10-12-2017, 09:13 AM
TRS's Avatar
TRS TRS is online now
Currently: Waiting for winter
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
The Following User Says Thank You to TRS For This Useful Post:
  #14
Old 10-17-2017, 12:00 PM
polaris bob's Avatar
polaris bob polaris bob is offline
Currently: Trying to figure it all out!
polaris bob has a reputation beyond reputepolaris bob has a reputation beyond reputepolaris bob has a reputation beyond reputepolaris bob has a reputation beyond reputepolaris bob has a reputation beyond reputepolaris bob has a reputation beyond reputepolaris bob has a reputation beyond reputepolaris bob has a reputation beyond reputepolaris bob has a reputation beyond reputepolaris bob has a reputation beyond reputepolaris bob has a reputation beyond repute
The Following User Says Thank You to polaris bob For This Useful Post:
  #15
Old 10-19-2017, 10:37 AM
Currently: Not set
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 07 Dragon 700 Backfiring, running rough Thread Starter — seth25 Forum — Polaris: IQ Replies — 5 Last Post — 01-17-2014 08:21 AM
Thread — 09 700 BD PG problems Thread Starter — snowman429 Forum — Polaris: TURBO Replies — 56 Last Post — 03-10-2012 10:13 PM
Thread — Problems 99 PS 700 Thread Starter — 570MC Forum — Arctic Cat Replies — 2 Last Post — 01-13-2011 11:20 PM
Thread — Need some help on backfiring 2008 700 Dragon Thread Starter — EKSleder Forum — Polaris Replies — 3 Last Post — 12-29-2008 12:54 AM
Thread — 02 700 Problems need help! Thread Starter — Ricta Forum — Polaris Replies — 7 Last Post — 02-07-2008 10:35 PM
no new posts
