Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 08-28-2017, 09:49 PM
cunninghambc cunninghambc is offline
Currently: Not set.
Basic Member
cunninghambc is an unknown quantity at this point
Default 07 rev 800 carb turbo build
Done a Lot of research and finally decided strap a gtx2860 on my extra sled I'll post pics as I go and except any information anyone has to offer. I'll also answer any questions I can to help someone else that might want to turbo older sled And wants to save time searching all the forums for old boring carb turbo stuff lol. This will be run in michigan so low elevation just an off trail play sled
Rate this post: Yes | No
  #2
Old 08-28-2017, 09:55 PM
Currently: Not set.
Basic Member
Default Pic of the sled
The rktek head I am using and also have a turbo cpi pipe on the way
  #3
Old 08-28-2017, 11:44 PM
Currently: Not set.
Basic Member
Default
It's a duel ball bearing turbo not sure if I wanna use the stock injection pump and then have to mix gas or I already have a graylor pump I could put in a restrictor. Not sure what I should go with I like the thought of not having to mix fuel but I would need some type of sensor to be sure my electric pump is working if I go that route. What do you guys think? or anyone used a graylor pump before? How long did it last I know cpi used them on there kits bit that was along time ago lol
  #4
Old 09-05-2017, 02:18 PM
Currently: Not set.
Basic Member
Default
After doing more research the gt2860 I was going to use will be to small for low elevation so I'm using the gt3076 I already have. I also decided to use the injection pump to supply the turbo with oil
  #5
Old 09-06-2017, 01:02 AM
xpturbo600 xpturbo600 is offline
Currently: Not set.
Basic Member
xpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond repute
Default
You should talk to bryce at turbo performance. He has turbocharged a lot of carb skidoo 800 sleds. He has been there, done many. I think his tag on snowest is brycter. Do not reinvent the wheel. R&D is expensive.
Next, if you are running an 800, why do you think a 2860 is too small? In my opinion a 3076 is to big based on the mass flow generated by that motor under boost. That will be really laggy. We can discuss more if you want. You need to size the turbine housing for your horsepower output target then size the compressor wheel to match the massflow rate of the engine. Race motors rarely run 3076 turbos unless it is used in drag racing with anti lag 2 step capability. Or, in chute climbing where slow throttle response can be dealt with.
The Following User Says Thank You to xpturbo600 For This Useful Post:
cunninghambc (09-06-2017)
  #6
Old 09-06-2017, 01:21 AM
Currently: Not set.
Basic Member
Default
The standard gt3076 flows okay for the 800 at 14 psi with a 0.61 AR housing. The issue isnt the compressor flow, it is inertia of the wheel assembly. It is massive compared to a 28 series turbo which equates to lag. You get a similar mass flow on a 28 series turbo with a 0.86 AR. Also, the new gtx2867 gen 2 will outflow your gt3076 compressor wheel. So why go bigger? The only answers are a better map/emap pressure ratio and to scavenge more heat out of the exhaust. But, unless you run really high boost, that is unnesessary.
Let me ask...what power level do you want? Or, how much boost do you want to run? If your boost level isn't high enough to warrant the big turbo, your losing useability. Which is, in my experience, way more important.
  #7
Old 09-06-2017, 08:42 AM
brad4639 brad4639 is offline
Currently: Not set.
Basic Member
brad4639 has a reputation beyond reputebrad4639 has a reputation beyond reputebrad4639 has a reputation beyond reputebrad4639 has a reputation beyond reputebrad4639 has a reputation beyond reputebrad4639 has a reputation beyond reputebrad4639 has a reputation beyond reputebrad4639 has a reputation beyond reputebrad4639 has a reputation beyond reputebrad4639 has a reputation beyond reputebrad4639 has a reputation beyond repute
Default
As en ex-800 carb turbo owner I have a few words of wisdom I guess. First I'll start with, it was a happy day when I got rid of it lol. Don't let me deter you tho because boost is fun.
One thing I don't know about your build, is if you are planning on running race gas or not. In my case, I did not want to run race fuel so I had to put on an external waste gate to get the boost pressure down to 4psi (safe for pump fuel at sea level). I couldn't find an internal waste gate to get me down to 4.
Things maybe have changed a bit since I was doing carb turbo's but what are you doing to compensate for extra fuel when you hit boost? Powerjets, electronic fuel pump, and boost referenced fuel pressure regulator?
At the time I did mine, there was not many carb 800's running at sea level so I (with the help of CPI) had to do some figuring. I kept blowing my reeds apart from a lean back fire. I ended up using needle spacers from a Yamaha carb to get the right height.
The Following User Says Thank You to brad4639 For This Useful Post:
  #8
Old 09-06-2017, 08:50 AM
Currently: Not set.
Basic Member
Default
  #9
Old 09-06-2017, 02:40 PM
Currently: Not set.
Basic Member
Default
Brad those reeds look melted probably from extremely high intake temps caused from to small of of a turbo. What size turbo did you have on your sled? Yess I already have an msd fuel pump, automotive return style fuel pressure regulator. I will be reference of the pipe l.
Here is a pic of the air box I built for my zx chassis if it will fit I will use it.
  #10
Old 09-06-2017, 04:20 PM
Currently: Not set.
Basic Member
  #11
Old 09-06-2017, 04:33 PM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Click Here to Register
  #12
Old 09-06-2017, 05:43 PM
Currently: Not set.
Basic Member
The Following User Says Thank You to cunninghambc For This Useful Post:
rmk all the way (09-08-2017)
  #13
Old 09-07-2017, 01:08 AM
Currently: Not set.
Basic Member
  #14
Old 09-07-2017, 10:36 AM
Currently: Not set.
Basic Member
  #15
Old 09-07-2017, 01:16 PM
Currently: Not set.
Basic Member
  #16
Old 09-08-2017, 02:19 AM
Currently: Not set.
Basic Member
  #17
Old 09-09-2017, 07:07 PM
Currently: Not set.
Basic Member
  #18
Old 09-14-2017, 04:12 PM
Currently: Not set.
Basic Member
  #19
Old 09-15-2017, 02:35 PM
Currently: Not set.
Basic Member
  #20
Old 09-19-2017, 02:13 PM
Currently: Not set.
Basic Member
  #21
Old 10-09-2017, 12:19 PM
rmk all the way rmk all the way is online now
Currently: Boost in progress!
rmk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond reputermk all the way has a reputation beyond repute
  #22
Old 11-03-2017, 10:05 PM
Currently: Not set.
Basic Member
rmk all the way (11-04-2017)
  #23
Old 01-31-2018, 03:33 PM
turboinline4 turboinline4 is offline
Currently: Not set.
turboinline4 is an unknown quantity at this point
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Rev 600 carb turbo? Thread Starter — Nic Forum — Ski-Doo: TURBO Replies — 2 Last Post — 01-21-2017 09:35 PM
Thread — 05 Rev 800 carb removal Thread Starter — TABLEROCK Forum — Ski-Doo: REV Sleds Replies — 3 Last Post — 11-25-2013 04:41 PM
Thread — My REV finally fixed, clip on carb 04 rev 800 Thread Starter — Aktaco Forum — Ski-Doo Replies — 1 Last Post — 12-03-2012 11:15 PM
Thread — 06 rev turbo.carb questions Thread Starter — 03rev600mxzho Forum — Ski-Doo: TURBO Replies — 15 Last Post — 10-02-2012 09:54 PM
Thread — XP or REV for turbo build? Thread Starter — revx827 Forum — Ski-Doo: TURBO Replies — 11 Last Post — 03-23-2012 10:18 AM
no new posts
