Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 08-24-2017, 04:39 PM
Logan_Martin27 Logan_Martin27 is offline
Currently: Not set.
Basic Member
Logan_Martin27 is an unknown quantity at this point
Smile 99 Polaris XC SP 700 Coolant Leak
There is a coolant leak on my 99 polaris xc sp 700 and it is coming from underneath the exhaust manifold. It is not the cylinder base gasket. But what could it be? Hoping for some good input.
Thanks: Logan
Rate this post: Yes | No
  #2
Old 09-01-2017, 02:51 PM
baden baden is offline
Currently: Not set.
Basic Member
baden is an unknown quantity at this point
Default
Quote:
Thanks: Logan
There is a water manifold below the exhaust that plumbs over to the water pump housing, see item 7 in the picture. There are two o-rings (item 6) that seal the ports to the manifold and two retaining brackets on the bottom side of the manifold that keep it snug to the block (item 8). Id start by checking those items.
http://www.babbittsonline.com/oempar...c1f4/crankcase
The Following User Says Thank You to baden For This Useful Post:
Logan_Martin27 (09-01-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Coolant leak around spark plug (polaris 95) Thread Starter — Mark1368 Forum — Polaris: GEN 1 and older Replies — 1 Last Post — 01-06-2017 05:12 PM
Thread — Coolant leak help Thread Starter — m8lovin Forum — Arctic Cat: M Series Replies — 5 Last Post — 11-30-2010 06:49 PM
Thread — coolant leak help Thread Starter — hellasnow Forum — Ski-Doo: ZX Sleds Replies — 4 Last Post — 11-29-2009 07:14 PM
Thread — 2002 Polaris Pro-X Coolant leak Thread Starter — Ride 13 Forum — Polaris: EDGE Replies — 4 Last Post — 11-16-2009 02:17 AM
Thread — Can't find coolant leak on M7- would it be OK to use radiator stop leak? Thread Starter — WYrider Forum — Arctic Cat Replies — 14 Last Post — 09-06-2008 08:20 AM
no new posts
