Upgrade to Premium
Reply
  #1
Old 06-30-2017, 05:59 PM
Nickhagen1 Nickhagen1 is offline
Currently: Not set.
Basic Member
Nickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud of
Default Adjustable fuel pressure regulators and purposes?
What is the purpose of an adjustable fuel regulator? Why do you want to change fuel pressure on a gas engine? Is it for atomization like in a diesel engine? Looking for people that have done this to their 1100 turbo and what/how works and why.
Thanks much
Rate this post: Yes | No
  #2
Old 01-09-2018, 04:37 AM
Currently: Not set.
Basic Member
Default
So, my stock regulator is leaking and cat has them on back order till February. Just curious if anyone has messed with them?? In the manual for the Suzuki engine, I believe it says run pressure around 30 psi?
Anyone know anything different or where to start? Any help will be appreciated.
Thanks nick
  #3
Old 01-23-2018, 03:41 PM
brokenbones4's Avatar
brokenbones4 brokenbones4 is online now
Currently: Not set.
brokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond reputebrokenbones4 has a reputation beyond repute
Default
Leaking regulator's are in my opinion why so many of these sleds burnt down. I bought my 1100t used last year and while rebuilding it I noticed fuel bubbles coming from the seam where the two halves of the fpr are pinched together. I removed it and put it in a vice to crimp the seam tighter, you can also us vice grips or a hammer. That fixed my problem.
__________________
If your not first!...your last!
The Following User Says Thank You to brokenbones4 For This Useful Post:
Nickhagen1 (01-25-2018)
  #4
Old 10-02-2018, 06:14 PM
MR.T MR.T is offline
Currently: Not set.
Basic Member
MR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant futureMR.T has a brilliant future
Default fuel regulators
After market fuel regulator out of a small car. chevy something I think. Arctic cat does not build fuel regulators. Same as fuel filters...go to NAPA and get all
  #5
Old 10-07-2018, 08:56 PM
Uncle Bob Uncle Bob is online now
Currently: Not set.
Uncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond repute
Default
The cat components on the two strokes are Bosch, definitely not low grade components. But the whole system is very basic The main purpose of increasing fuel pressure is to increase the amount of fuel dilivery without having to increase injector firing duration or leave the injector open too long causing a drop in fuel rail pressure to the injector down the line It is a very in presice fuel dilivery system
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Cheap Fuel Pressure Regulators? Thread Starter — drummerdave Forum — Arctic Cat: M Series Replies — 9 Last Post — 10-18-2015 08:39 AM
Thread — M1000 Fuel Pressure Regulators Thread Starter — montananate Forum — Arctic Cat: M Series Replies — 18 Last Post — 02-09-2014 05:47 PM
Thread — Fuel pressure regulators Thread Starter — ptofnortn Forum — Arctic Cat: M Series Replies — 3 Last Post — 03-27-2010 11:51 PM
Thread — Fuel pressure regulators.. Thread Starter — ptofnortn Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 51 Last Post — 01-14-2010 10:44 AM
no new posts
