Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 06-17-2017, 05:43 PM
lyspera lyspera is offline
Currently: Not set.
Basic Member
lyspera is an unknown quantity at this point
Default Pro Rmk motor in edge chassis
Thinking about fitting a Pro rmk 800 motor in my good old edge, anyone have some suggestions about it? is it much work? much modifications?
Rate this post: Yes | No
  #2
Old 06-17-2017, 10:19 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
Going the wrong way
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 06-17-2017, 10:56 PM
icr icr is offline
Currently: on another forum
Basic Member
icr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond repute
Default
It will be a lot of work and modifications.
I'd rather have an edge engine in a pro chassis.
  #4
Old 06-18-2017, 05:08 AM
NHRoadking's Avatar
NHRoadking NHRoadking is online now
Currently: Always waiting for more snow.
NHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond repute
Default
A lot of money to put a new motor in an old chassis. What's the point?
Who would buy it later on when you want to get rid of it?
  #5
Old 06-18-2017, 09:07 AM
Currently: Not set.
Basic Member
Default
The main reason why i want to swap the motor is because the edge 800 use alot of gas and oil, and maybe later on iam thinking of boosting it. And i have acess to a tig welder, and the edge chassis have plenty of space in the engine bay. or will it just be a real P.I.T.A to fit it?
  #6
Old 10-06-2017, 03:30 PM
MrIQR MrIQR is offline
Currently: Too many sleds, not enough time
Basic Member
MrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond repute
Default
Mounting it would be the tough part, the pro motor uses bolts that that go through the motor mounts horizontally and the edge motors have vertical motor mount bolts, if that makes since. Would take some clever thinking.
What would be a lot cooler is a 800ves with UBR900 top end in a pro chassis.
  #7
Old 10-12-2017, 03:20 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Currently: Never enough snow!!!
BILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond repute
Default
I had started looking into this a couple years ago, putting my old carls 910 into my pro chassis. There is a motor plate made just for it and it is easily done, I decided against it though. I am sure someone can make a motor plate to go the other way, pro motor in to edge chassis, wouldnt think it would be too hard.
__________________
Derek B.
2000 440 xc sp 136 (EDGE)
2003 800 RMK 162
2004 910 PRO-XR 121x1.75", Wheelie Machine!!!
2011 LRod 13.6 800 ProRMK 3"PC KMOD/Raptors kmod 37" arms Ti can
The Following User Says Thank You to BILTIT For This Useful Post:
MrIQR (10-12-2017)
  #8
Old 11-21-2017, 01:49 AM
crdude crdude is offline
Currently: Not set.
Basic Member
crdude is an unknown quantity at this point
Default
Quote:
Who makes the plate for this swap?
  #9
Old 11-21-2017, 07:32 AM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
Default
Agreed.
A custom built plate would do the trick.
I had started looking into this a couple years ago, putting my old carls 910 into my pro chassis. I am sure someone can make a motor plate to go the other way, pro motor in to edge chassis, wouldnt think it would be too hard.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 800 Liberty from EDGE chassis in Pro-ride chassis??? Thread Starter — RotaxKongen Forum — Polaris: Pro-Ride Replies — 14 Last Post — 10-03-2015 08:32 AM
Thread — XC motor in edge chassis, help Thread Starter — boondocker rick Forum — Polaris: EDGE Replies — 2 Last Post — 02-10-2011 10:30 PM
Thread — Edge chassis motor swap? Thread Starter — overtheedge Forum — Polaris: EDGE Replies — 3 Last Post — 12-29-2009 10:13 PM
Thread — edge motor in gen ll chassis??? need help Thread Starter — xcryda700 Forum — Polaris: EDGE Replies — 4 Last Post — 11-04-2009 11:18 PM
Thread — SnoTek Steering Post Edge/Edge RMK Chassis Thread Starter — BillyRayMtnRdr Forum — Misc. Sled Parts Replies — 2 Last Post — 08-04-2009 03:38 PM
