Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 04-30-2017, 11:45 AM
Rick E Rick E is offline
Currently: Not set.
Basic Member
Rick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond repute
Default '08 and'09 ski alignment question
These are both Summit 800R 154" track sleds.
Should we see "tow in" or "tow out" at the shovel tips of our skis?
Currently, both sleds are towed out at the shovel ends.
If towed in..... what is the target measurement?
If towed out..... what is the target measurement?
What is recommended over that of the factory setting?
Rick E.
Rate this post: Yes | No
  #2
Old 04-30-2017, 11:50 AM
eddy's Avatar
eddy eddy is offline
Currently: Dirt Bike Season!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
Default Alignment
We set them toe out 1/4". That is close to factory spec, look in the shop manual for the exact measurement and where to take it, there are some marks on the skis.
  #3
Old 05-01-2017, 04:03 AM
Currently: Not set.
Basic Member
Default
Quote:
Eddy, thank you for that!
The one sled in question ('09 800R XP) is the same sled that does not feel/ride the same as our '08 800R XP does. The '09's tow-out was excessive. I did bring it in!
Prior to this, the '09 front end would appear to shift/wobble back/forth some (erractic tracking as though the skis were catching deep hard-pack snow tracks), whereas the '08 tracked well without the shifting/wobbling.
I also had to flip the '09's RH/LH sliders over (these were upside down) causing the RH/LH spring ends to occasionally contact the hyfax and the track. Fortunately, there is no damage!
Now with the sliders flipped over (springs on top of them), this sled sits higher and should (in theory) have more rear suspension travel.
So....... after adjusting and bringing "in" the excessive tow-out, perhaps this sled will feel and ride better.
Our season is just about over, so I am not sure that I'll be able to test it out until this coming Fall!
Thanks again,
Rick E
  #4
Old 05-01-2017, 09:13 AM
winter brew's Avatar
winter brew winter brew is online now
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Just to add....make sure the spindle bushings/axle are in good shape. Its a good idea to remove, grease and replace if necessary at the end of the season. They tend to wear and seize if neglected and will make it impossible to get a good alignment.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Team LW 04 alignment tool question Thread Starter — go high fast Forum — Polaris: IQ Replies — 0 Last Post — 01-07-2015 02:20 PM
Thread — TRA Alignment question? Thread Starter — badapple Forum — Ski-Doo: XP Sleds Replies — 7 Last Post — 12-13-2011 12:07 AM
Thread — Track alignment question Thread Starter — Boston Racing Forum — Polaris: IQ Replies — 0 Last Post — 01-07-2011 05:23 PM
Thread — Clutch alignment question Thread Starter — hyperduc Forum — Arctic Cat: M Series Replies — 15 Last Post — 11-15-2010 07:23 AM
Thread — Over rev question,out of alignment? Thread Starter — Powderat Forum — Yamaha Replies — 18 Last Post — 12-02-2008 08:58 PM
no new posts
