Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 04-29-2017, 03:59 PM
coryf89 coryf89 is online now
Currently: 13 ktm 450sxf. 17 yeti 129
Basic Member
coryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond repute
Default 2008 keeps fouling right side plug
what is the cause of this?
bought sled used. 2500 miles. fouled right plug first ride.
right piston was realllll bad, so we re did top end. $400 still ran bad.
dealership scanned it, had a few electrical codes, said stator is bad. 100%.
we replaced stator...$200. same thing! ran rough.
took it to a local pro. he said the wiring harness is bad. replaced that. $800, t rode for 5 miles.. same thing, right plug died.
please help!!! what could it be.
Rate this post: Yes | No
  #2
Old 04-29-2017, 09:07 PM
BBP BBP is offline
Currently: Not set.
Basic Member
BBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond repute
Default
DPM, fuel pump & spark plug boot would be the 1st things I would check.
  #3
Old 04-29-2017, 09:10 PM
BBP BBP is offline
Currently: Not set.
Basic Member
Default
I would also confirm that you have good spark & check the compression. Might also be a broken reed.
  #4
Old 04-29-2017, 11:30 PM
Skidoox's Avatar
Skidoox Skidoox is online now
Currently: Not set.
Skidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond repute
Default
What jet are you running?
What altitude are running the sled at?
  #5
Old 04-30-2017, 08:38 AM
Basic Member
Default
damnit, we had the jets out but I cant remember the numbers. we are at 1000-1500M.
compression seems fine via the pull start. brand new pistons.
reeds seemed fine via visual check.. not sure if they should be checked with a magnifying glass and feelers guages sorta thing.
spark seemed fine the one time we pulled plug, stuck it in the boot, grounded it, and pulled sled over.
spark plug boot and coil are the next things to guess/throw money at!!!
appreciate the advice/ tips... anything helps. keep the suggestions coming please and thanks.
bought the sled, used it once..this sucks!!!
  #6
Old 04-30-2017, 09:55 AM
Betterview Betterview is online now
Currently: Not set.
Betterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond repute
Default
When a sled is used I would not trust the number on a jet is true to the size. It is very easy to enlarge the orifice to compensate for low compression or an air leak. Put in a new jet the same size the other carb has and go looking for air leaks, carb boot, crank case seam, base gasket, including the seal behind the mag.
  #7
Old 04-30-2017, 12:06 PM
eddy's Avatar
eddy eddy is offline
Currently: Dirt Bike Season!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
Default Jets
Agreed on the used machine and jetting. Replace the pilot and main jets on both sides with stock. That stock machine with DPM and stock jetting runs perfect at that elevation.
The ignition is common to both sides, so other than a plug wire/cap, IMHO you are chasing a problem most likely not in the ignition.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #8
Old 04-30-2017, 02:35 PM
Skidoox's Avatar
Currently: Not set.
Default
I would test the DPM.
Or swap the DPM from a working sled.
  #9
Old 04-30-2017, 10:11 PM
Basic Member
Default
good answers guys. DPM seems to be a common answer..
ill order new jets and throw them in.
the mag side seal isnt perfect TBH... when replacing the stator, we did see isoflex that had leaked out to the stator case and pullstart assembly.
  #10
Old 05-01-2017, 12:11 PM
eddy's Avatar
  #11
Old 05-01-2017, 12:45 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Click Here to Register
  #12
Old 05-01-2017, 09:07 PM
Basic Member
  #13
Old 05-02-2017, 06:49 AM
Currently: Not set.
The Following User Says Thank You to winter brew For This Useful Post:
coryf89 (05-02-2017)
  #14
Old 05-02-2017, 07:12 AM
Rick E Rick E is offline
Currently: Not set.
Basic Member
Rick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond repute
The Following User Says Thank You to Rick E For This Useful Post:
coryf89 (05-03-2017)
  #15
Old 05-03-2017, 07:06 AM
Basic Member
  #16
Old 05-03-2017, 07:19 AM
Currently: Not set.
Basic Member
  #17
Old 05-04-2017, 03:18 AM
lynxmann lynxmann is offline
Currently: Not set.
Basic Member
lynxmann has a reputation beyond reputelynxmann has a reputation beyond reputelynxmann has a reputation beyond reputelynxmann has a reputation beyond reputelynxmann has a reputation beyond reputelynxmann has a reputation beyond reputelynxmann has a reputation beyond reputelynxmann has a reputation beyond reputelynxmann has a reputation beyond reputelynxmann has a reputation beyond reputelynxmann has a reputation beyond repute
The Following User Says Thank You to lynxmann For This Useful Post:
FEZ (05-09-2017)
  #18
Old 05-09-2017, 09:01 PM
FEZ FEZ is offline
Currently: Mechanic for and Advisor to SHR
Basic Member
FEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond repute
  #19
Old 05-10-2017, 08:04 PM
Basic Member
  #20
Old 05-12-2017, 05:29 PM
BBP BBP is offline
Currently: Not set.
Basic Member
The Following User Says Thank You to BBP For This Useful Post:
coryf89 (05-12-2017)
  #21
Old 05-12-2017, 08:58 PM
Basic Member
  #22
Old 05-15-2017, 08:11 PM
FEZ FEZ is offline
Basic Member
  #23
Old 05-16-2017, 09:44 AM
BIG JOHN's Avatar
BIG JOHN BIG JOHN is offline
Currently: making Summits bettersince 1997
BIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond repute
  #24
Old 05-17-2017, 05:54 PM
Basic Member
  #25
Old 05-18-2017, 07:18 AM
BIG JOHN's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Clutch side plug keeps fouling Thread Starter — 906 Bob Forum — Polaris: IQ Replies — 3 Last Post — 12-12-2010 09:31 PM
Thread — Plug fouling XP? Thread Starter — snengineer Forum — Ski-Doo: XP Sleds Replies — 22 Last Post — 04-12-2010 09:45 PM
Thread — Plug fouling Thread Starter — XP Mountain King Forum — Polaris: IQ Replies — 7 Last Post — 12-21-2009 08:03 AM
Thread — 583 fouling pto side plug Thread Starter — rmk-rider Forum — Ski-Doo Replies — 0 Last Post — 02-22-2009 09:56 PM
Thread — keep fouling pto side plug Thread Starter — redbull660 Forum — Ski-Doo Replies — 12 Last Post — 01-07-2008 05:59 PM
no new posts
