Upgrade to Premium
Reply
  #1
Old 04-28-2017, 08:33 AM
0neoldfart 0neoldfart is offline
Currently: rigging instad of riding
0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute
Default M1100 / M9000 owners
I read a lot of threads about the weight of the M1100, and make no mistake, they aren't light. But there is a lot of things one can do that aren't a lot of $$$ to make it ride lighter and handle better. I own a 2013 Sno Pro Ltd 162 that I purchased new, and yes, I've spent some $$$ on it, mostly because I can't leave anything stock...
- 1st, the front track shock spring uses the same rate as the lighter M800 / 600 sleds, only a 115 lb/inch rate. Way too light for the big girl. You can go the Z-broz route, but Cat also offers springs from the Snocross sled that are significantly stiffer and make a dramatic change in weight transfer with out trenching. I used a 190#/in spring with 1.5" preload, giving me sufficient travel without coil bind (this happens when you have to much spring preload).
- 2nd, the stock skis are garbage. I've run PP's, 8" Slydogs, MODS, Pilot DS, Pilot 6.9's, Mohawks, USI triple threats, 7" Slydogs, and Grippers). My choice is the Grippers, followed by Pilot 6.9's without the outer carbide. I'm willing to sacrifice a little push in the corners to have a light front end.
- 3rd, ski alignment is absolutely critical on this sled. I run 1/8" toe out.
If you install a Kmod rear skid (I did) with Raptors, the front track spring is too light again, especially if rider weight is over 200 lbs. I sourced a spring from Fox with a 225#/in rate, and then you have the best of both worlds - a coupled skid when you want it, an excellent ride, and a playful front end (Big thanks to Kevin at Kmod for helping me out with this, his suspension knowledge and customer service are second to none.) Yes, you can crank the front track shock spring preload, but you are effectively reducing travel.
I'm not going to elaborate on the belt blowing / misalignment / hot clutches that these sleds are all labeled with, even though the vast majority don't have this issue, or it can be resolved fairly easily at a cost if you have one that is affected. Basically, if the sled has no turbo / exhaust blankets and is not vented, you are starting with an uphill losing battle. Sled wraps are pretty, but useless unless all you do is look at it in the garage.
Adding power to these sleds is easy to do, but unless you beef up the drive line and clutches, you will eventually have issues. Although you can add a PG / RG turbo to a two stroke, you will NEVER have the torque numbers that a boosted 4S has. And that torque is tough on drive line components, period.
This is my 2 cents.
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to 0neoldfart For This Useful Post:
blackjack85335 (11-30-2017), d1100t (04-29-2017), JustBoostIt (04-29-2017), Turcatbo (10-10-2017)
  #2
Old 04-28-2017, 12:11 PM
2013 M1100 Turbo 2013 M1100 Turbo is offline
Currently: Not set.
Basic Member
2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute
Default
I agree with what you said. They are heavy but once you dial them in they are a blast to ride. I totaled my 13 M1100T this season and had it dialed in exactly where I was wanting it. Did like you mentioned, got different skis, put extra preload on the front skid shock, roll over valve and exhaust (dropped 12 lbs). I didn't have a belt blower. In the 3.5 years I rode it I blew 2 belts one at 800 miles and the other at 1400 miles. Totaled it with 1500 miles on it.
Mid season, after totaling my sled, I bought a King Cat 9000 and only got to ride it once. I am having to go through the whole suspension setup again. The dealer didn't do a very good job at setting the shocks to begin with. The front skid shock only had 35 psi in it. I can already tell this machine is more nimble with the narrow front end and I cant wait to see what some weight reduction and suspension work can do. It will take me another couple of trip to experiment with the new float 3 evol shocks to get them where I want.
  #3
Old 07-04-2017, 11:24 AM
Nickhagen1 Nickhagen1 is offline
Currently: Not set.
Basic Member
Nickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud of
Default Front track shock spring
Went on zbroz site, found all kinds of springs. Now what size springs are on the fox float 3's? I have a 2014 M9000 ltd, never really messed around this much with them. I mean I'm sure I can call and they will know what to get me but if I at least have an idea of what to ask for it would help tremendously.
  #4
Old 07-04-2017, 01:14 PM
stahlecker stahlecker is online now
Currently: Not set.
stahlecker has a reputation beyond reputestahlecker has a reputation beyond reputestahlecker has a reputation beyond reputestahlecker has a reputation beyond reputestahlecker has a reputation beyond reputestahlecker has a reputation beyond reputestahlecker has a reputation beyond reputestahlecker has a reputation beyond reputestahlecker has a reputation beyond reputestahlecker has a reputation beyond reputestahlecker has a reputation beyond repute
Default
If you have coil over shocks in the skid I think this is what you want SKU: 101-YAM-CNTR. I could not find it as a cat listed product but I'm pretty sure they are the same. I would double check with zbroz.
Last season I switched to a Yamaha 135# spring on my Viper. It was all I could find at the time. It definitely helped but I will probably go to a heavier one this winter.
Last edited by stahlecker; 07-04-2017 at 01:16 PM. Reason: Correct my tablets auto correct mistakes.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M1100 vs M9000 nose dive Thread Starter — Cedarberry Forum — Arctic Cat: 1100 ProClimb Replies — 3 Last Post — 11-26-2016 01:17 PM
Thread — Arctic Cat M1100 Turbo/M9000 Fuel pumps Thread Starter — RACINSTATION Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 09-22-2015 10:54 AM
Thread — Spring riding on the M1100/M9000 Turbo! Thread Starter — RACINSTATION Forum — Arctic Cat: 1100 ProClimb Replies — 4 Last Post — 04-23-2014 04:27 PM
Thread — 2014 cat m9000 owners...lets hear it! Thread Starter — freeflorider Forum — Arctic Cat: Proclimb M Replies — 4 Last Post — 04-15-2014 11:30 AM
Thread — 2014 m9000 owners Thread Starter — freeflorider Forum — Arctic Cat: 1100 ProClimb Replies — 1 Last Post — 04-14-2014 08:21 PM
no new posts
