Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 04-26-2017, 04:14 PM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is offline
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default How to take 20 lbs off the back of your Edge
Step 1. Drill holes in the track to expel snow as it rotates
Step 2. Dupont Teflon Paint to slide rails and inside of tunnel https://www.amazon.com/DuPont-Teflon.../dp/B0031T82NO
Rate this post: Yes | No
The Following User Says Thank You to whoisthatguy For This Useful Post:
Mark's RMK (04-27-2017)
  #2
Old 04-27-2017, 05:50 AM
Mark's RMK's Avatar
Mark's RMK Mark's RMK is offline
Currently: Not set.
Mark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond repute
Default Dries?
Does it dry clear?
Do you apply annually to maintain or does it last longer than that?
Do you pull the skid to apply it to the skid frame and the inside of the tunnel?
We have a Yamaha Apex XTX (144) and it's terrible for snow accumulation on the skid.
Thanks.
__________________
2013 800 Pro RMK 155 ES, Burandt boards, Timbersled A-arms, NXT Level WS Bag, skid plate, VE belt guard, Team Tied Clutch, MTX wts, SLP Hot Air Eliminators, Mike Taylor Footwell Vents, Powder Keg tank/pack, Rox Flex Tec II Handguards.
Wife's Sled - 2012 Yamaha Apex XTX 144" EPS, Earth X battery, Yamaha Handguards, cable scratchers
2015 600 RMK 155, ES, skid plate, MTX wts
  #3
Old 04-27-2017, 09:35 AM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
"For best results, apply after each snow storm".
That statement from the manufacturer tells me it isn't very long lasting.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #4
Old 04-29-2017, 01:33 AM
Currently: Not set.
Default
It's pretty inexpensive and leaves a film that only comes off your fingers with a little scrubbing. That film likely prevents the adhesion of the snow. The impact of the snow likely wears it down. I only taped over my cooler before applying it on as much tunnel surface as I could reach with the spray. It dries clear but has that film. Takes no more than 60 seconds to apply so it is well worth the time and money. The snow falls off after a jounce or two and everywhere in your tunnel that you sprayed, will be clean of snow. It does not help to spray any part of the suspension, that I noticed.
Mark's RMK (04-29-2017)
  #5
Old 05-08-2017, 11:07 PM
peaceofwork peaceofwork is offline
Currently: Internet Rmkpro 800apprentiship
Basic Member
peaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond repute
Default
good one i noticed sometimes my sled loads up and looks like a lowrider i will have to give that a try
  #6
Old 05-14-2017, 06:14 PM
NHRoadking's Avatar
NHRoadking NHRoadking is offline
Currently: Always waiting for more snow.
NHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond repute
Default
In my experience, none of those paints, films, etc., really work. I did read an article years ago that said that carbon fiber worked, never tried it though.
  #7
Old 05-26-2017, 09:14 PM
Currently: Not set.
Default
I guarantee that this film works on the inside of the tunnel for one ride, and then you simply spray another coat on.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 22.8 lbs Thread Starter — mtn mike on boost Forum — Ski-Doo: XM Sleds Replies — 17 Last Post — 01-06-2013 06:57 AM
Thread — BD 11 lbs Thread Starter — rmk685 Forum — Polaris: TURBO Replies — 20 Last Post — 01-14-2012 07:24 PM
Thread — TCP CAMEL BACK WIDE FRONT END FOR 02-05 EDGE Thread Starter — RACER212 Forum — Suspension/Shocks (Swapmeet) Replies — 2 Last Post — 05-10-2011 09:38 AM
Thread — Just getting back into sledding. Best Edge mods for Newb? Thread Starter — Cheeto Forum — Polaris: EDGE Replies — 24 Last Post — 10-16-2009 11:05 AM
Thread — F/S Light Weight Edge Arms 4.2 LBS Thread Starter — Fasterrbyfuzzy Forum — Suspension/Shocks (Swapmeet) Replies — 4 Last Post — 09-28-2008 04:12 PM
no new posts
