Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 04-19-2017, 09:56 AM
Rick E Rick E is offline
Currently: Not set.
Basic Member
Rick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond repute
Default '08 and '09 154" XP suspension differences ???
Hello again. I have a new question.
We have both a 2008 and a 2009 800R XP 154".
Both appear to use the same basic chassis.
Both have under 1,400 miles on them.
The '08 ride is very nice. It sits tall even though the spring adjustment is set low.
It handles rather smoothly, stays on track well, etc.
The '09 does not handle as well. It does not sit as tall.
Both the shock coil spring adjustment and the RH & LH springs adjustments are all the same on both sleds.
I enjoy riding the '08 more so than the '09, however, the '08 is my wife's sled.
I would like to make changes so that both ride similar if not the same.
I have noticed a few differences and I'm wondering if this could explain why the two ride differently:
Click image for larger version
Name:	08 and 09 suspensions.jpg
Rate this post: Yes | No
  #2
Old 04-19-2017, 10:37 AM
BIG JOHN's Avatar
BIG JOHN BIG JOHN is online now
Currently: making Summits bettersince 1997
BIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond repute
Default
same same
shocks are prolly suspect...
easy up grade on both is remove the skid, remove front skid mount plate (in tunnel) flip it and re rivet in place (keep center hole the same for reference)...now drill out new hole using bracket as the template (lower/rear hole) this takes about 50 lbs off front skis and the back of sled will not sag...
if an X sled rebuild stock shocks...
swap front skis, left to right and right to left this will help handling/side hill...
add the foot well mod and your cooking with gas on an old XP-BJ
__________________
sledheadracing.net
SLED HEAD RACING
612-718-3861
"The BEST BB motor I ever rode"
SHR860R/SHR880R carb/ETEC (REV/XP/XM)
SHR850 180 kit/SHR921 (gen4)
MPI/SHR 850 turbo/SHR adjustable weights/kits
  #3
Old 04-19-2017, 12:08 PM
ak ak is online now
Currently: Nothing
ak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond repute
Default
The spring sliders are up side down they should be like your 2008.
As far as the front shocks it looks to be in the right hole but the rails must be aftermarket. If you were to use the forward hole it would probably have less ski pressure.
  #4
Old 04-20-2017, 05:14 AM
Currently: Not set.
Basic Member
Default
Quote:
Originally Posted by BIG JOHN View Post
same same
shocks are probably suspect...
I will look into that..... however, it's not necessarily the dampening..... I'm thinking that it has more to do with the suspension springs.
(this sled sits slightly lower than the '08 does.)
Thank you....... but that will be for another time.
Right now I just want to learn why each sled feels so different from the other.
Both sleds have the skis installed identically. Each are in the narrow tracking position.
I like cooking with gas!
Quote:
That is what I was thinking.
As they are now (and each is set at #4), I would think that the '09 RH & LH springs are shy of their ability to lift!
I will be flipping them over.
As far as the front shock it looks to be in the right hole but the rails must be aftermarket.
Possibly!
Again, I was thinking along those same lines.
Thanks to both of you.
Meanwhile, if anyone else has a suggestion, please don't be shy!
Rick E
  #5
Old 04-20-2017, 06:51 AM
Currently: Not set.
Basic Member
Default
John, you have my curiosity sparked.
Could you post a few images that would give me a better idea as to the skid mount that I would be flipping over?
  #6
Old 04-21-2017, 10:46 AM
Currently: Not set.
Basic Member
Default
OK..... I turned the sliders over (RH & LH spring supports) which now creates more pressure against the skids causing the chassis to sit higher.
I'm hopeful that this will make an improvement.
Rick E.
  #7
Old 04-24-2017, 07:03 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Yep, flip over those spring slides on the '09, it is simply assembled wrong. Also check limiter strap settings, I would run them all the way loose on both sleds or upgrade to the '10+ geometry.
  #8
Old 04-24-2017, 08:29 AM
BIG JOHN's Avatar
Default
just look in the tunnel...there are only 2 front skid mount brackets...the rest is explained above-BJ
__________________
sledheadracing.net
SLED HEAD RACING
612-718-3861
  #9
Old 04-24-2017, 11:06 AM
Currently: Not set.
Basic Member
Default
Thank you guys..... I appreciate your suggestions and help! I'll take it all under advisement.
I appologize for so having many questions.
As for swapping skis....... you mean to actually swap left for right skis and visa versa......... not simply moving the spacer from inboard to outboard as to change the ski tracking width.......... correct?
New questions..... same basic topic re; the two sleds not responding the same:
#1......
My current skis (both '08 and '09 sleds) are BRP #505072177 as per raised numbers in the plastic.
The '09 skis could use replacement, so what different skis may I try?
What are the DS, DS2 and DS3 skis?
What year model skis will successfully work for these sleds?
We are not young riders and don't require top performance..... but.... the '08 800R 154" XP rides so much better than the '09 800R 154" XP . There has to be something that is not quite right with the '09!
#2.....
Front ski alignment re; tow in/tow out!
Should we see "tow in" or "tow out" at the shovel tips?
What is recommended over that of factory setting?
Rick E.
  #10
Old 04-24-2017, 02:27 PM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
  #11
Old 05-03-2017, 07:20 AM
BIG JOHN's Avatar
Click Here to Register
  #12
Old 05-04-2017, 05:53 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 2009 XP 154"suspension/track Thread Starter — Snoghost Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 10-07-2014 05:51 PM
Thread — 2099 XP 154" suspension Thread Starter — Snoghost Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 09-26-2014 04:39 PM
Thread — 08 154" suspension setup Thread Starter — Powder1 Forum — Ski-Doo: XP Sleds Replies — 6 Last Post — 11-30-2009 10:53 AM
Thread — 154" Summit Hillclimb Suspension Thread Starter — barkbuster001 Forum — Suspension/Shocks (Swapmeet) Replies — 2 Last Post — 08-18-2009 11:33 AM
Thread — Suspension setup for 09 XP Everest 154" Thread Starter — ski-doo25 Forum — Ski-Doo Replies — 0 Last Post — 02-09-2009 08:29 PM
