Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 04-16-2017, 10:18 AM
roni87's Avatar
roni87 roni87 is offline
Currently: Not set.
roni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond repute
Default How to limit boost on a supercharger?
I want to run my super around minnesota. Right now I'm running the air to air/ serpentine belt speedwerx setup. I believe around 7 psi at altitude.
Apparently they don't offer a bigger pulley for the supercharger with the serp setup.
Is there a wastegate or blow off valve that can be installed to limit boost to 3psi?
I did run it around the yard for a few miles at the current psi. Put in a gallon of av to about 4 gallon premium and ran fine wot so I know I can get it to work at 3 psi.
Jeremy at sw said I'm on my own to make it work around here as the kit wasn't designed for below 5000ft.
Rate this post: Yes | No
  #2
Old 04-16-2017, 12:03 PM
d1100t's Avatar
d1100t d1100t is offline
Currently: Looking forward to the first ride on my 2018 M 800 CTEC
d1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond repute
Default Av gas
What about running straight av gas?
I've ran my turbo charged 800 on 8lbs of boost at 1400ft with no problems on straight av gas.
  #3
Old 04-17-2017, 09:29 AM
roni87's Avatar
Currently: Not set.
Default
For longer trips or trail rides would be nice not to pack av gas. Also it used way more fuel than my turbo pro at 7 psi. Lowering boost should help me make it between gas pumps
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to roni87 For This Useful Post:
d1100t (04-17-2017)
  #4
Old 04-17-2017, 09:57 AM
izzni's Avatar
izzni izzni is offline
Currently: Improving the NS1 Gauge System
izzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond repute
Default
Would putting too much weight in the clutch and reducing the top end RPM be an option?
__________________
Deluxe Gauge Software Reflash
www.NextStageGauges.com
The Deluxe Gauge Software Reflash enhances the stock Arctic Cat gauge to correct odometer inaccuracies, allow engine coolant temp to be displayed, add data logging, and many other improvements.
  #5
Old 04-18-2017, 07:26 AM
roni87's Avatar
Currently: Not set.
Default Pulleys
I might look into a custom pulley. Per prochargers recommendation 1psi of boost change is generally 1/10" diameter on the small pulley.
  #6
Old 05-02-2017, 08:41 PM
roni87's Avatar
Currently: Not set.
Default
Ordered up the POD 300 for my sled. This allows the monitoring of a bunch of stuff but mainly reads the boost pressure off the map.
1100 ft elevation
2.0 psi at 4100 engagement
8.5-9.0 psi Just before exhaust valves open ~7200 rpm
6.8 psi at wot 8170 rpm.
I wanted to lower the overall boost and eliminate the spike. I ordered a boost limiting valve and will be installing it via a silicone tee just before the intercooler.
Hope to have it down to 4psi max and it Will still build boost very early in rpms.
A smaller pulley could have got me down to correct psi but would have still spiked before valves open and wouldn't boost as fast off the bottom.
Demidoff (12-27-2017)
  #7
Old 07-07-2017, 08:18 PM
roni87's Avatar
Currently: Not set.
Default
Wound up buying a smaller bottom pulley for my sled. 5" instead of the stock 6.5" for high elevation.
Boost is now .2 at idle and around 4 psi max. Should work good for my home range in mn. Went with ibexx weights.
Had the sled in BC this summer and superchargers are pretty responsive when clutched right!
  #8
Old 07-14-2017, 08:34 PM
xpturbo600 xpturbo600 is offline
Currently: Not set.
Basic Member
xpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond repute
Default
Just for piece of mind, I wanted to share an idea. Boost is a measure of resistance to flow, not volume of flow. HP is a direct result of air mass not boost pressure. More flow equals more HP in most cases which leads to questions of detonation as dynamic compression increases.
The reason I say this is because you stated your sled had a boost spike and then it drops. To me, this is less concerning. A supercharger is linear in flow...it cannot spike boost like a turbo. Instead, the sled is simply telling you there is more resistance to flow prior to the exhaust valves opening. If resistance is reduced at the same flow rate, i.e. the exhaust valves opening, the only logical outcome is pressure in the system must decrease. I would not worry about it too much.
Finally, dont drop the boost too much since you bought a boosted sled for a reason. I ran 7 to 8 pounds on a turbo setup all day at 6500 feet on quality pump fuel. However, turbos create resistance to flow vs a supercharger. Happy riding!
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to xpturbo600 For This Useful Post:
Demidoff (12-27-2017), roni87 (07-18-2017), Scott (07-15-2017)
  #9
Old 12-27-2017, 06:04 AM
Demidoff Demidoff is offline
Currently: Not set.
Basic Member
Demidoff is an unknown quantity at this point
Default
Are you find any solves how to limit supercharger pressure? Can I see you fuel map for low altitude if it possible?
  #10
Old 12-28-2017, 09:14 PM
roni87's Avatar
Currently: Not set.
  #11
Old 01-07-2018, 06:40 AM
Currently: Not set.
Basic Member
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Boost limit on 100LL Thread Starter — cadmo Forum — Arctic Cat: M Series Replies — 7 Last Post — 09-22-2010 07:41 PM
Thread — ATTN!!!! Low elevation Low boost Supercharger customers Thread Starter — Heath@MPI Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 0 Last Post — 02-23-2010 03:35 PM
Thread — Limit Thread Starter — rynokron Forum — Suggestions and User Feedback Replies — 7 Last Post — 02-10-2010 09:04 PM
Thread — nytro boost limit question? Thread Starter — WKR Forum — Yamaha Replies — 11 Last Post — 10-13-2008 01:40 PM
Thread — GREAT BUY! 06 APEX w/ MPI Supercharger! Instant boost- a blast to ride! Thread Starter — nothin serious Forum — Yamaha (Swapmeet) Replies — 2 Last Post — 12-01-2007 11:43 PM
no new posts
