Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 04-06-2017, 06:51 PM
captjanes captjanes is offline
Currently: Not set.
Basic Member
captjanes is an unknown quantity at this point
Default 2005 800 switchback engine help
I have a 2005 800 switchback and I seized the motor due to a crank seal/bearing on the clutch side. After stripping down the engine and doing some research the engine is from a 2003 700 classic touring sled that the PO installed before I bought it. I am looking to go back to the 800 switchback engine.
I am wondering if anywhere online sells crate motors?
or what are my other options? not many scrap yards around here where I live.
Rate this post: Yes | No
  #2
Old 04-06-2017, 07:11 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
its the same bottom end as the 800 so you could probably rebuild it with 800 rods, pistons, cylinders and heads, from e-bay or the forums. your 700 head cover should work. double check the part numbers for everything on babbits parts finder or the like.
id consider keeping it 700, i think the rods are slightly bigger? and you already have them and the 700s last a lil longer.
  #3
Old 04-06-2017, 08:19 PM
05rmksteve's Avatar
05rmksteve 05rmksteve is online now
Currently: Putting sleds together
05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute
Default
[QUOTE=sno*jet;4071088]its the same bottom end as the 800 so you could probably rebuild it with 800 rods, pistons, cylinders and heads, from e-bay or the forums. your 700 head cover should work.
Its not that simple. The case would have to be machined for the longer stroke of the 800 crank and for the 800 cylinders to fit the 700 case.
The Following User Says Thank You to 05rmksteve For This Useful Post:
sno*jet (04-07-2017)
  #4
Old 04-06-2017, 08:22 PM
05rmksteve's Avatar
Default
I have a carls cycle big bore 910 for sale it's based off the polaris 800 ves motor.
  #5
Old 04-07-2017, 05:53 AM
Currently: Not set.
Basic Member
Default
Quote:
how much?
will the carbs on my machine now work with 700 or 800? I think they are the same I just need to change cdi unit.
  #6
Old 04-07-2017, 10:16 AM
05rmksteve's Avatar
Default
2000.00 + shipping for the motor, bored carbs, pipes, and ecu. The motor was rebuilt about 150 miles ago. New crank with the pto wide bearing, new rings, seals, gaskets and bearings. About 185-200+ hp depending on setup.
Yes you carbs will work and yes you would need an ecu for an 800.
  #7
Old 04-07-2017, 02:46 PM
Currently: Not set.
Default
^sounds like a good deal.
i maybe thinkin 600 to 700 swap then, thought bottoms were same, thanks.
  #8
Old 04-08-2017, 07:58 AM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is offline
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
Ebay has used 800 edge motors popping up frequently. Expect to tear it down and upgrade things though. Add a new PTO end bearing, new upper piston rod bearings and new rings. Naturally you will be replacing the seals, diaphragms and gaskets as well. It would also be good to drill out the oil drain hole that goes to the PTO bearings, that the factory never installed. the 04 and 05 engines with PERC and DET are similar. 03 may not have DET or PERC. 02 has no PERC, no DET and no compression release hole and are a bitch to pull start, but the parts can be interchanged to bring it up to 05 standards. There is an 02 800 edge engine on EBAY right now.
  #9
Old 04-08-2017, 08:57 AM
Currently: Not set.
Default
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2005 800 Switchback reverse issues Thread Starter — captjanes Forum — Polaris: EDGE Replies — 2 Last Post — 01-16-2017 08:38 AM
Thread — clutching switchback 800 2005 Thread Starter — switchyluke Forum — Polaris: EDGE Replies — 1 Last Post — 12-19-2015 01:21 AM
Thread — check engine light on 09 800 switchback Thread Starter — polaris all the way Forum — Polaris: IQ Replies — 1 Last Post — 12-07-2010 11:58 PM
Thread — 2005 polaris rmk switchback 800 151 Thread Starter — ggcustoms Forum — Polaris (Swapmeet) Replies — 0 Last Post — 12-01-2009 11:22 PM
Thread — 2005 Switchback 800 with 2 place enclosed trailer Thread Starter — lemaicc Forum — Polaris (Swapmeet) Replies — 0 Last Post — 02-22-2008 09:42 AM
no new posts
