Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 04-02-2017, 10:55 AM
julians julians is offline
Currently: Waiting on winter
julians has a reputation beyond reputejulians has a reputation beyond reputejulians has a reputation beyond reputejulians has a reputation beyond reputejulians has a reputation beyond reputejulians has a reputation beyond reputejulians has a reputation beyond reputejulians has a reputation beyond reputejulians has a reputation beyond reputejulians has a reputation beyond reputejulians has a reputation beyond repute
Question SAFETY CONCERN ?? 2017 G4-850 Fuel tank pressurized
Was out riding this weekend and took a break pointed slightly down hill. After a few minutes I started smelling gas and saw fuel pouring out of one of the holes above my left side shock (vent hole?).
I turned the sled up hill and it stopped then I released the pressure from the tank. I took a run up the the hill and when I got back to the bottom I opened my gas cap and the tank was pressurized again.
Is this normal?
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to julians For This Useful Post:
julians (04-03-2017)
  #2
Old 04-02-2017, 07:26 PM
Motodrew's Avatar
Motodrew Motodrew is online now
Currently: IG @Motodrew
Motodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond repute
Garage
Default
I've noticed sitting down on the seat applies pressure to the fuel tank. This constant repetition of sitting up/down likely is the reason for pressure buildup.
__________________
YT & IG : @Motodrew
http://www.boondockcolorado.com
The Following User Says Thank You to Motodrew For This Useful Post:
  #3
Old 04-02-2017, 09:47 PM
turboless terry's Avatar
turboless terry turboless terry is online now
Currently: Not set.
turboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond repute
Default
My wife's sled did the exact same thing one day. Turned it sideways and released cap and it quit. Haven't had mine do it.
The Following User Says Thank You to turboless terry For This Useful Post:
  #4
Old 04-02-2017, 09:52 PM
towerrigger towerrigger is offline
Currently: Not set.
towerrigger has a reputation beyond reputetowerrigger has a reputation beyond reputetowerrigger has a reputation beyond reputetowerrigger has a reputation beyond reputetowerrigger has a reputation beyond reputetowerrigger has a reputation beyond reputetowerrigger has a reputation beyond reputetowerrigger has a reputation beyond reputetowerrigger has a reputation beyond reputetowerrigger has a reputation beyond reputetowerrigger has a reputation beyond repute
Default
Same deal here. I took the valve out of the tank to inspect it. It allows air to come in but not out. It is the same green rubber valve they use in the oil cap. Every time I stop now I unscrew the cap and let the pressure out.
The Following User Says Thank You to towerrigger For This Useful Post:
  #5
Old 04-02-2017, 10:04 PM
NWaxys NWaxys is offline
Currently: ridecascade.com
NWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond repute
Default
I've filled mine up after a ride before and forgot that it's under pressure the cap blew clean off and up in the air as i unscrewed it
The Following User Says Thank You to NWaxys For This Useful Post:
  #6
Old 04-03-2017, 10:46 AM
BIG C BIG C is online now
Currently: Watching it melt!
Basic Member
BIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond reputeBIG C has a reputation beyond repute
Default
Mine was doing same thing for the first time yesterday in wolf creek pass, it was hot out so I don't know if that had something to do with it.
The Following User Says Thank You to BIG C For This Useful Post:
  #7
Old 04-03-2017, 11:50 AM
b-litt's Avatar
b-litt b-litt is offline
Currently: Not set.
b-litt has a reputation beyond reputeb-litt has a reputation beyond reputeb-litt has a reputation beyond reputeb-litt has a reputation beyond reputeb-litt has a reputation beyond reputeb-litt has a reputation beyond reputeb-litt has a reputation beyond reputeb-litt has a reputation beyond reputeb-litt has a reputation beyond reputeb-litt has a reputation beyond reputeb-litt has a reputation beyond repute
Default
The vent that is on the clutch side above the shock has always leaked on the XM and 850 from what I've seen. It only does it when it's sitting on a steep pitch pointing down. My XM seemed to do it worse though. You could watch it pour out. My 850 is more of a drip. The 850 is the first sled that I've noticed the cap flying off from pressure. Mine does it too....
The Following 2 Users Say Thank You to b-litt For This Useful Post:
Fire (04-03-2017), julians (04-03-2017)
  #8
Old 04-03-2017, 09:18 PM
Default
Thanks for the replies. I hadn't noticed it before so I wasn't sure if I needed to get it checked out. I was in the 50's so that may have had something to do with it.
BIG C (04-07-2017)
  #9
Old 04-04-2017, 06:20 AM
PaulAnd's Avatar
PaulAnd PaulAnd is online now
Currently: gen4 now please
PaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond repute
Default
My 850 smells like raw fuel alot.. usually facing downhill, Lots of pressure in the fuel tank even when not sitting on it..
I find myself unscrewing the fuel cap everytime I stop subconciously.?.
Did it facing uphill 1 time...
DOH!!!!!!
My XM did it also just not as bad
  #10
Old 04-04-2017, 06:39 AM
Evanbcx's Avatar
Evanbcx Evanbcx is offline
Currently: Waiting for snow
Evanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond reputeEvanbcx has a reputation beyond repute
Garage
Default
Anytime I take off my cap and not holding on to it tight it shoots out of my hands into the air
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Evanbcx For This Useful Post:
BIG C (04-07-2017)
  #11
Old 04-06-2017, 06:30 PM
HFH HFH is offline
Currently: Not set.
HFH has a reputation beyond reputeHFH has a reputation beyond reputeHFH has a reputation beyond reputeHFH has a reputation beyond reputeHFH has a reputation beyond reputeHFH has a reputation beyond reputeHFH has a reputation beyond reputeHFH has a reputation beyond reputeHFH has a reputation beyond reputeHFH has a reputation beyond reputeHFH has a reputation beyond repute
Click Here to Register
The Following 2 Users Say Thank You to HFH For This Useful Post:
BIG C (04-07-2017), Powderhound_202 (04-07-2017)
  #12
Old 04-07-2017, 07:00 PM
off trail mike off trail mike is offline
Currently: Have snow...need sled
off trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond repute
The Following 3 Users Say Thank You to off trail mike For This Useful Post:
christopher (04-08-2017), Daag44 (07-13-2017), ZRP Engineering (04-08-2017)
  #13
Old 04-07-2017, 08:01 PM
black z's Avatar
black z black z is offline
Currently: Not set.
black z has a reputation beyond reputeblack z has a reputation beyond reputeblack z has a reputation beyond reputeblack z has a reputation beyond reputeblack z has a reputation beyond reputeblack z has a reputation beyond reputeblack z has a reputation beyond reputeblack z has a reputation beyond reputeblack z has a reputation beyond reputeblack z has a reputation beyond reputeblack z has a reputation beyond repute
  #14
Old 04-07-2017, 11:41 PM
FearMyWrX FearMyWrX is offline
Currently: Not set.
Basic Member
FearMyWrX has a reputation beyond reputeFearMyWrX has a reputation beyond reputeFearMyWrX has a reputation beyond reputeFearMyWrX has a reputation beyond reputeFearMyWrX has a reputation beyond reputeFearMyWrX has a reputation beyond reputeFearMyWrX has a reputation beyond reputeFearMyWrX has a reputation beyond reputeFearMyWrX has a reputation beyond reputeFearMyWrX has a reputation beyond reputeFearMyWrX has a reputation beyond repute
Garage
  #15
Old 04-08-2017, 08:00 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
The Following 6 Users Say Thank You to mountainhorse For This Useful Post:
christopher (04-08-2017), icaminc (02-13-2018), Kingofthehilllpg (04-24-2017), Ol Boondocker (10-25-2017), SNOBI-WAN-KENOBI (04-20-2017), ZRP Engineering (04-08-2017)
  #16
Old 04-08-2017, 10:44 PM
Dazzler's Avatar
Dazzler Dazzler is online now
Currently: Not set.
Dazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond repute
  #17
Old 04-09-2017, 12:05 AM
paulharris paulharris is offline
Currently: want pow
paulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond reputepaulharris has a reputation beyond repute
  #18
Old 04-09-2017, 12:28 AM
Snowmixer Snowmixer is offline
Currently: Not set.
Snowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond reputeSnowmixer has a reputation beyond repute
  #19
Old 04-09-2017, 05:21 AM
stmike stmike is offline
Currently: Not set.
stmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond repute
  #20
Old 04-09-2017, 10:05 AM
The Following User Says Thank You to off trail mike For This Useful Post:
Daag44 (07-13-2017)
  #21
Old 04-09-2017, 04:32 PM
HFH HFH is offline
Currently: Not set.
  #22
Old 04-09-2017, 05:38 PM
diamonddave's Avatar
diamonddave diamonddave is offline
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
The Following User Says Thank You to diamonddave For This Useful Post:
  #23
Old 04-10-2017, 05:46 AM
Currently: Not set.
  #24
Old 04-10-2017, 01:51 PM
winter brew's Avatar
winter brew winter brew is online now
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
The Following User Says Thank You to winter brew For This Useful Post:
b-litt (04-10-2017)
  #25
Old 04-10-2017, 02:08 PM
b-litt's Avatar
Currently: Not set.
The Following User Says Thank You to b-litt For This Useful Post:
Devilmanak (12-28-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Installation and Review: Trail Tank High Capacity Fuel Tank Thread Starter — christopher Forum — Yamaha: Product Reviews and Installs Replies — 89 Last Post — 12-28-2013 09:24 PM
Thread — F/S yamaha RX1/Vector Turbo Fuel tank Modified stock plastic tank with pic! Thread Starter — paulharris Forum — Fuels/Oils/Lubrication (Swapmeet) Replies — 3 Last Post — 10-15-2012 01:41 PM
Thread — 1998 Polaris Indy RMK 700, Fuel tank/seat, oil tank, coolant tank Thread Starter — Gmiller Forum — Chassis/Tunnel (Swapmeet) Replies — 1 Last Post — 09-25-2011 09:57 AM
Thread — Fuel tank + Fuel Pump + Fuel Filter for 2006 900 RMK Thread Starter — Dogmeat Forum — Chassis/Tunnel (Swapmeet) Replies — 0 Last Post — 12-06-2010 07:48 PM
Thread — fuel tank recall?? How to remove fuel tank? Thread Starter — yz400ex Forum — Polaris: 900 Replies — 14 Last Post — 12-14-2009 06:46 PM
no new posts
