Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 03-26-2017, 03:48 PM
Van Zee Van Zee is offline
Currently: Not set.
Basic Member
Van Zee is an unknown quantity at this point
Default What is this?
I found this floating in oil tank of 600 etec. We have been riding sled and everything seems to work. So what is it, do i need it and how hard is it to fix?
The item I am talking about is in the picture in a Ziploc bag.
Click image for larger version
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #2
Old 03-26-2017, 04:50 PM
nuttyn01 nuttyn01 is offline
Currently: Not set.
nuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond repute
Default
Looks like the float mechanism for the low oil.
  #3
Old 03-26-2017, 06:36 PM
Currently: Not set.
Basic Member
Default
Any idea if it is a simple fix? Probably would be just fine without it, but if its simple I would sure put it back together.
  #4
Old 03-26-2017, 06:49 PM
xpspenziv's Avatar
xpspenziv xpspenziv is offline
Currently: boooasting
xpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond repute
Default
I would assume if it is the low level sensor just remove tank. Pull discharge fitting out of the bottom of the tank and repair or replace it.
The Following User Says Thank You to xpspenziv For This Useful Post:
Van Zee (03-26-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
