Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 03-24-2017, 02:56 PM
Seabass152 Seabass152 is offline
Currently: Not set.
Seabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond repute
Default TPS adjust with MTNTK kit
Any of the MTNTK turbo guys adjust TPS yet? Checking to see what had to be taken off or not to gain access . Thanks
Rate this post: Yes | No
  #2
Old 03-24-2017, 03:49 PM
sledhead9825 sledhead9825 is offline
Currently: Not set.
sledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond repute
Default
Quote:
Got it done with only removing the Muffler
  #3
Old 03-24-2017, 04:32 PM
Davajn Davajn is online now
Currently: Braaaaap - Polaris Ambassador Sweden
Davajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond repute
Default
I removed muffler, moved turbo out of the way and fuelrail. Injectors can be left in the intake and the cooling and oil hoose for the turbo doesnt need to be disconnected.
The 2.5mm allen key for the set screw need to be bent a little.
  #4
Old 03-25-2017, 11:41 PM
Currently: Not set.
Default
Quote:
How did you get to the idle adjuster? I tried for a bit but couldn't get anything on the lock nut. Need to bend or find the right 8mm.
  #5
Old 01-29-2018, 09:48 PM
Currently: Not set.
Default
Any new tricks out there?
  #6
Old 03-31-2018, 10:02 PM
roughrider99's Avatar
roughrider99 roughrider99 is offline
Currently: the stutter button on the tnytro is too much fun!
roughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond repute
Garage
Default
I opted to pull the turbo and remove the throttle bodies and set tps on the bench. It's so sensitive that doing it on the bench is nice vs having a hard time and multiple attempts, bending tools to fit etc just to set it in machine.
__________________
I ride where its steep n' deep
17' 800 T-axys LE
16' 600 axys pink ribbon (hers)
15' viper mtx 162 PC3
12' pro rmk (for sale)
97 wrx sti type r summer boosted toy!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — TPS check / adjust step by step. Thread Starter — SRXSRULE Forum — Polaris: AXYS Replies — 187 Last Post — 12-10-2018 08:13 PM
Thread — How to adjust tps on axys Thread Starter — HCR10 Forum — Polaris: AXYS Replies — 2 Last Post — 02-14-2016 11:28 AM
Thread — Pro TPS adjust Thread Starter — milo303 Forum — Colorado Replies — 14 Last Post — 02-16-2014 09:25 AM
Thread — How do you adjust the TPS? Thread Starter — Mjunkie Forum — Performance/Modified Replies — 1 Last Post — 08-25-2010 07:39 AM
Thread — '09 800...idle adjust and TPS Thread Starter — winter brew Forum — Polaris Replies — 1 Last Post — 11-18-2008 07:59 PM
no new posts
