Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 03-19-2017, 05:36 PM
Redsledhead Redsledhead is offline
Currently: Working on sleds awaiting snow
Basic Member
Redsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond reputeRedsledhead has a reputation beyond repute
Default Phazer Help
Need help on the grandkids 1991Phazer 2 sled. The belt is riding way to low in the secondary clutch. Was thinking about going to newer clutches on the sled that can adjust the drive belt (Sounds like you have to take the clutch apart and install shims). What are newer clutches that will work on the sled? Any help would be great the grandkids want to keep riding.
Rate this post: Yes | No
  #2
Old 03-20-2017, 09:49 AM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
You will have to remove a spacer to get the belt to ride higher in the secondary. Are you sure the correct belt is installed and is not worn? OEM belt is Yamaha part #89X-17641-01-00. Also the belt does not ride as high in the secondary on those sleds as they do on the newer sleds so it may be alright as it is. I did own a 1991 phazer with the YPZ clutch as well as a 1993 Phazer with the YXR clutch. They both had the spacers to adjust belt tension. The belts rode a bit below the top of the secondary sheaves. The spec for belt deflection is different than what you may be used to. The manual says to measure the width of the belt and then depending on that measurement you adjust the number of spacers. If you do have to remove a spacer it is pretty simple and you don't need special tools other than snap ring pliers. Simply push down on the helix and remove the circlip on the back side of the clutch. Take it apart and the spacer is between the two sheaves. Take note of which holes the spring tabs are in so you can reinstall them where they were. It helps to have another set of hands but you can do it yourself by pushing down on the helix with your knee. If you're fortunate enough to own the proper tool to push down on the helix it's even easier.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #3
Old 03-20-2017, 05:54 PM
Basic Member
Default
Thanks for the info will have to check belt number an try a new belt. It just seams to have a midrange bog.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Phazer or Phazer II for kids Thread Starter — chadincolo Forum — Youth Sleds Replies — 0 Last Post — 11-02-2015 02:41 PM
Thread — 07 phazer Thread Starter — HOTRODREDNECK Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 4 Last Post — 10-27-2011 09:45 PM
Thread — supercharged phazer vs turbo phazer Thread Starter — rymo84 Forum — Performance/Modified Replies — 27 Last Post — 02-19-2010 11:00 AM
Thread — Phazer help Thread Starter — jakecrank99 Forum — Vintage Replies — 19 Last Post — 11-08-2009 08:58 AM
Thread — 07 Phazer FX Thread Starter — farmer7407 Forum — Yamaha (Swapmeet) Replies — 0 Last Post — 12-30-2007 10:40 AM
