Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 03-11-2017, 05:05 AM
goosemanx goosemanx is offline
Currently: Not set.
Basic Member
goosemanx is an unknown quantity at this point
Default 06 340 edge touring stator specs
Anyone have a link to a shop manual for 2006 340 edge touring? Don't mind paying but free is always better
I can find for 06 340 classic and 06 340 Indy touring but not the 06 340 edge touring
Even if someone has stator specs would be good
Rate this post: Yes | No
  #2
Old 03-29-2017, 11:43 PM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is offline
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
If you have stator problems, either the engine doesn't work or there no power for the accessories. A bad high low beam switch can screw up the engine so that you may think that you have a stator problem. You disconnect that switch and see if the engine runs, it order to check for whether it is bad. If you need serial numbers to by a used stator, go to Carl's Cycle website. A bad thermister on top of the engine will also cause the engine not to work. You can check whether that is bad by disconnecting the connector and inserting a wire that connects the two ends of the electrical harness connector that you just exposed. If the engine then runs, you need to buy a new thermister for about $22.
  #3
Old 03-30-2017, 02:11 PM
Currently: Not set.
Basic Member
Default
Quote:
What is a thermister? I have never heard of that term or know where to even look for it
  #4
Old 04-02-2017, 10:46 AM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
Stator specs should be the same as for the 2004 340 touring shown in attachment. The manufacturers don't tend to make electrical changes within the same chassis/ engine combinations year to year. The wiring diagram should be okay to follow too.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #5
Old 04-02-2017, 04:52 PM
Currently: Not set.
Basic Member
Default
Quote:
Thank you very much
  #6
Old 04-08-2017, 03:36 PM
Currently: Not set.
Default
Quote:
I am referring to the screw in plug on top of the cylinder head cap, with a lead wire that plugs into the main electrical harness, right in front of the coolant hose connection. When the engine over heats or the thermister gets old, then it breaks the electrical connection that either causes the engine to stutter or to not work at all.
  #7
Old 04-13-2017, 06:37 PM
Currently: Not set.
Basic Member
Default
My engine is a air cooled
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2004 340 edge touring w perc Thread Starter — Boosted Brad Forum — Polaris (Swapmeet) Replies — 1 Last Post — 10-19-2013 11:06 AM
Thread — 1987 indy sport 340 torque specs Thread Starter — mikey8873 Forum — Polaris Replies — 1 Last Post — 01-09-2012 08:17 PM
Thread — 1995 Polaris 340 Head torque specs Thread Starter — k.farns Forum — Polaris: GEN 1 and older Replies — 1 Last Post — 02-17-2010 09:26 PM
Thread — Stator Specs Thread Starter — catunder Forum — Arctic Cat Replies — 0 Last Post — 02-02-2009 09:38 PM
Thread — Polaris TX 340 /440 stator Thread Starter — MAD MATT Forum — Vintage Replies — 3 Last Post — 01-03-2009 10:41 AM
no new posts
